Home » Eclipse Projects » Eclipse RT (runtime) » Standalone Infocenter(Standalone Infocenter not starting completely)
Re: Standalone Infocenter [message #1238248 is a reply to message #1237824] |
Fri, 31 January 2014 19:54 |
Earl Bennett Messages: 29 Registered: July 2009 |
I figured out how to get my infoCenter to run the way I wanted. I finally just made a copy of my Eclipse directory, and started pulling things out until I ended up with a (hopefully) minimum set of plugins that seems to work.
My final list of plugins is:
ch.qos.logback.classic_1.0.7.v20121108-1250.jar
ch.qos.logback.core_1.0.7.v20121108-1250.jar
ch.qos.logback.slf4j_1.0.7.v20121108-1250.jar
com.ibm.icu_50.1.1.v201304230130.jar
javax.el_2.2.0.v201303151357.jar
javax.servlet.jsp_2.2.0.v201112011158.jar
javax.servlet_3.0.0.v201112011016.jar
org.apache.jasper.glassfish_2.2.2.v201205150955.jar
org.apache.lucene.analysis_3.5.0.v20120725-1805.jar
org.apache.lucene.core_3.5.0.v20120725-1805.jar
org.eclipse.core.contenttype_3.4.200.v20130326-1255.jar
org.eclipse.core.expressions_3.4.500.v20130515-1343.jar
org.eclipse.core.jobs_3.5.300.v20130429-1813.jar
org.eclipse.core.runtime_3.9.0.v20130326-1255.jar
org.eclipse.equinox.app_1.3.100.v20130327-1442.jar
org.eclipse.equinox.common_3.6.200.v20130402-1505.jar
org.eclipse.equinox.event_1.3.0.v20130327-1442.jar
org.eclipse.equinox.http.jetty_3.0.100.v20130327-1442.jar
org.eclipse.equinox.http.registry_1.1.300.v20130402-1529.jar
org.eclipse.equinox.http.servlet_1.1.400.v20130418-1354.jar
org.eclipse.equinox.jsp.jasper.registry_1.0.300.v20130327-1442.jar
org.eclipse.equinox.jsp.jasper_1.0.400.v20130327-1442.jar
org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
org.eclipse.equinox.preferences_3.5.100.v20130422-1538.jar
org.eclipse.equinox.registry_3.5.301.v20130717-1549.jar
org.eclipse.equinox.simpleconfigurator_1.0.400.v20130327-2119.jar
org.eclipse.equinox.util_1.0.500.v20130404-1337.jar
org.eclipse.help.base_4.0.0.v20130911-1000.jar
org.eclipse.help.ui_4.0.1.v20130708-1201.jar
org.eclipse.help.webapp_3.6.200.v20130514-1258.jar
org.eclipse.help_3.6.0.v20130326-1254.jar
org.eclipse.jetty.continuation_8.1.10.v20130312.jar
org.eclipse.jetty.http_8.1.10.v20130312.jar
org.eclipse.jetty.io_8.1.10.v20130312.jar
org.eclipse.jetty.security_8.1.10.v20130312.jar
org.eclipse.jetty.server_8.1.10.v20130312.jar
org.eclipse.jetty.servlet_8.1.10.v20130312.jar
org.eclipse.jetty.util_8.1.10.v20130312.jar
org.eclipse.jetty.xml_8.1.3.v20120522.jar
org.eclipse.osgi.services_3.3.100.v20130513-1956.jar
org.eclipse.osgi.util_3.2.300.v20130513-1956.jar
org.eclipse.osgi_3.9.1.v20130814-1242.jar
org.eclipse.update.configurator_3.3.200.v20130326-1319.jar
org.slf4j.api_1.7.2.v20121108-1250.jar
I also modified the config.ini in the configuration directory. It now looks like this:
#This configuration file was written by: org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxFwConfigFileParser
#Fri Jan 31 08:44:11 EST 2014
org.eclipse.update.reconcile=false
osgi.instance.area.default=@user.home/workspace
osgi.framework=file\:plugins/org.eclipse.osgi_3.9.1.v20130814-1242.jar
equinox.use.ds=true
eclipse.buildId=4.3.0.M20130911-1000
osgi.bundles=reference\:file\:org.eclipse.equinox.simpleconfigurator_1.0.400.v20130327-2119.jar@1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.eclipse.equinox.simpleconfigurator/bundles.info
eclipse.product=org.eclipse.platform.ide
osgi.bundles.defaultStartLevel=4
eclipse.application=org.eclipse.help.base.infocenterApplication
And I also reduced the content of bundles.info in the configuration/org.eclipse.equinox.simpleconfigurator directory.
#version=1
ch.qos.logback.classic,1.0.7.v20121108-1250,plugins/ch.qos.logback.classic_1.0.7.v20121108-1250.jar,4,false
ch.qos.logback.core,1.0.7.v20121108-1250,plugins/ch.qos.logback.core_1.0.7.v20121108-1250.jar,4,false
ch.qos.logback.slf4j,1.0.7.v20121108-1250,plugins/ch.qos.logback.slf4j_1.0.7.v20121108-1250.jar,4,false
com.compuware.common.web.platform.help,1.0.0,plugins/com.compuware.common.web.platform.help-1.0.0.jar,4,false
com.ibm.icu,50.1.1.v201304230130,plugins/com.ibm.icu_50.1.1.v201304230130.jar,4,false
javax.el,2.2.0.v201303151357,plugins/javax.el_2.2.0.v201303151357.jar,4,false
javax.servlet,3.0.0.v201112011016,plugins/javax.servlet_3.0.0.v201112011016.jar,4,false
javax.servlet.jsp,2.2.0.v201112011158,plugins/javax.servlet.jsp_2.2.0.v201112011158.jar,4,false
org.apache.jasper.glassfish,2.2.2.v201205150955,plugins/org.apache.jasper.glassfish_2.2.2.v201205150955.jar,4,false
org.apache.lucene.analysis,3.5.0.v20120725-1805,plugins/org.apache.lucene.analysis_3.5.0.v20120725-1805.jar,4,false
org.apache.lucene.core,3.5.0.v20120725-1805,plugins/org.apache.lucene.core_3.5.0.v20120725-1805.jar,4,false
org.eclipse.core.contenttype,3.4.200.v20130326-1255,plugins/org.eclipse.core.contenttype_3.4.200.v20130326-1255.jar,4,false
org.eclipse.core.expressions,3.4.500.v20130515-1343,plugins/org.eclipse.core.expressions_3.4.500.v20130515-1343.jar,4,false
org.eclipse.core.jobs,3.5.300.v20130429-1813,plugins/org.eclipse.core.jobs_3.5.300.v20130429-1813.jar,4,false
org.eclipse.core.runtime,3.9.0.v20130326-1255,plugins/org.eclipse.core.runtime_3.9.0.v20130326-1255.jar,4,true
org.eclipse.equinox.app,1.3.100.v20130327-1442,plugins/org.eclipse.equinox.app_1.3.100.v20130327-1442.jar,4,false
org.eclipse.equinox.common,3.6.200.v20130402-1505,plugins/org.eclipse.equinox.common_3.6.200.v20130402-1505.jar,2,true
org.eclipse.equinox.event,1.3.0.v20130327-1442,plugins/org.eclipse.equinox.event_1.3.0.v20130327-1442.jar,2,true
org.eclipse.equinox.http.jetty,3.0.100.v20130327-1442,plugins/org.eclipse.equinox.http.jetty_3.0.100.v20130327-1442.jar,4,false
org.eclipse.equinox.http.registry,1.1.300.v20130402-1529,plugins/org.eclipse.equinox.http.registry_1.1.300.v20130402-1529.jar,4,false
org.eclipse.equinox.http.servlet,1.1.400.v20130418-1354,plugins/org.eclipse.equinox.http.servlet_1.1.400.v20130418-1354.jar,4,false
org.eclipse.equinox.jsp.jasper,1.0.400.v20130327-1442,plugins/org.eclipse.equinox.jsp.jasper_1.0.400.v20130327-1442.jar,4,false
org.eclipse.equinox.jsp.jasper.registry,1.0.300.v20130327-1442,plugins/org.eclipse.equinox.jsp.jasper.registry_1.0.300.v20130327-1442.jar,4,false
org.eclipse.equinox.launcher,1.3.0.v20130327-1440,plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar,4,false
org.eclipse.equinox.preferences,3.5.100.v20130422-1538,plugins/org.eclipse.equinox.preferences_3.5.100.v20130422-1538.jar,4,false
org.eclipse.equinox.registry,3.5.301.v20130717-1549,plugins/org.eclipse.equinox.registry_3.5.301.v20130717-1549.jar,4,false
org.eclipse.equinox.simpleconfigurator,1.0.400.v20130327-2119,plugins/org.eclipse.equinox.simpleconfigurator_1.0.400.v20130327-2119.jar,1,true
org.eclipse.equinox.util,1.0.500.v20130404-1337,plugins/org.eclipse.equinox.util_1.0.500.v20130404-1337.jar,4,false
org.eclipse.help,3.6.0.v20130326-1254,plugins/org.eclipse.help_3.6.0.v20130326-1254.jar,4,false
org.eclipse.help.base,4.0.0.v20130911-1000,plugins/org.eclipse.help.base_4.0.0.v20130911-1000.jar,4,false
org.eclipse.help.ui,4.0.1.v20130708-1201,plugins/org.eclipse.help.ui_4.0.1.v20130708-1201.jar,4,false
org.eclipse.help.webapp,3.6.200.v20130514-1258,plugins/org.eclipse.help.webapp_3.6.200.v20130514-1258.jar,4,false
org.eclipse.jetty.continuation,8.1.10.v20130312,plugins/org.eclipse.jetty.continuation_8.1.10.v20130312.jar,4,false
org.eclipse.jetty.http,8.1.10.v20130312,plugins/org.eclipse.jetty.http_8.1.10.v20130312.jar,4,false
org.eclipse.jetty.io,8.1.10.v20130312,plugins/org.eclipse.jetty.io_8.1.10.v20130312.jar,4,false
org.eclipse.jetty.security,8.1.10.v20130312,plugins/org.eclipse.jetty.security_8.1.10.v20130312.jar,4,false
org.eclipse.jetty.server,8.1.10.v20130312,plugins/org.eclipse.jetty.server_8.1.10.v20130312.jar,4,false
org.eclipse.jetty.servlet,8.1.10.v20130312,plugins/org.eclipse.jetty.servlet_8.1.10.v20130312.jar,4,false
org.eclipse.jetty.util,8.1.10.v20130312,plugins/org.eclipse.jetty.util_8.1.10.v20130312.jar,4,false
org.eclipse.jetty.xml,8.1.3.v20120522,plugins/org.eclipse.jetty.xml_8.1.3.v20120522.jar,4,false
org.eclipse.osgi,3.9.1.v20130814-1242,plugins/org.eclipse.osgi_3.9.1.v20130814-1242.jar,-1,true
org.eclipse.osgi.services,3.3.100.v20130513-1956,plugins/org.eclipse.osgi.services_3.3.100.v20130513-1956.jar,4,false
org.eclipse.osgi.util,3.2.300.v20130513-1956,plugins/org.eclipse.osgi.util_3.2.300.v20130513-1956.jar,4,false
org.eclipse.platform,4.3.1.v20130911-1000,plugins/org.eclipse.platform_4.3.1.v20130911-1000/,4,false
org.eclipse.update.configurator,3.3.200.v20130326-1319,plugins/org.eclipse.update.configurator_3.3.200.v20130326-1319.jar,4,false
org.slf4j.api,1.7.2.v20121108-1250,plugins/org.slf4j.api_1.7.2.v20121108-1250.jar,4,false
In order to start the infoCenter from a Java class, I also had to copy org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
to the root of my webapp and rename it startup.jar.
Note that the list of plugins above contains no documentation (help) plugins. If you run with just this list, the infoCenter will have a blank table of contents. Be sure to add some help plugins to the plugins directory.
Earl
Current Time: Fri Apr 26 17:35:10 GMT 2024
Powered by FUDForum. Page generated in 0.03893 seconds
