Home » Language IDEs » ServerTools (WTP) » How to: Convert a org.apache.xerces.dom Node to org.eclipse.wst.html.core.internal.document Node
How to: Convert a org.apache.xerces.dom Node to org.eclipse.wst.html.core.internal.document Node [message #202316] Tue, 16 October 2007 05:40 Go to next message
Originally posted by: ranjeev.backbase.com
Hello Guys,
I am having a node that is type
(org.eclipse.wst.html.core.internal.document.ElementStyleImp l), I wish
to import this into org.eclipse.wst.html.core.internal.document, using
the code below:
Node importedNode = domModel.getDocument().importNode(newNode, true);
//domModel is of type
org.eclipse.wst.xml.core.internal.provisional.document.IDOMM odel
// and newNode is of type org.apache.xerces.dom.ElementStyleImpl, which
// giving me class cast exception!
Is there a way to convert a a org.apache.xerces.dom Node to
org.eclipse.wst.html.core.internal.document Node???
Ranjeev
Re: How to: Convert a org.apache.xerces.dom Node to org.eclipse.wst.html.core.internal.document Node [message #202404 is a reply to message #202316] Tue, 16 October 2007 17:32 Go to previous messageGo to next message
On Tue, 16 Oct 2007 05:40:16 -0400, Ranjeev <ranjeev@backbase.com> wrote:
> // and newNode is of type org.apache.xerces.dom.ElementStyleImpl, which // giving me class cast exception!
Sounds like a bug. I'm pretty sure I've heard of people doing this before, so you
might have to provide some unit-test-like code to demonstrate the problem with your
particular input.
But, I don't actually see an ElementStyleImpl in org.apache.xerces.dom. So ... either a typo? Or you have some
non-standard version of org.apache.xerces.dom?
Re: How to: Convert a org.apache.xerces.dom Node to org.eclipse.wst.html.core.internal.document Node [message #202592 is a reply to message #202404] Thu, 18 October 2007 06:37 Go to previous message
Thanks for your reply!
I changed my implementation, earlier I had two different types..
IDOMElement from wst and Element (from xerces), now I use IDOMElement
and it solved my problem.
> particular input.
> Thanks
Previous Topic:Design view of WSDL doesn't link to soap fault type
Next Topic:Preserving text editor caret position
Current Time: Wed Nov 05 12:28:28 EST 2025
Powered by FUDForum. Page generated in 0.04262 seconds
