| [3.1M6] can't open java default editor [message #202202] |
Fri, 29 April 2005 12:11  |
first I can open a java source with java default editor.
Then I installed VE with the requisites:
com.ibm.wtp.common.utilities_1.0.1
com.ibm.wtp.emf.integration.core_1.0.1
org.eclipse.emf.ecore.sdo_2.0.1
org.eclipse.emf.sdk_2.0.1
org.eclipse.emf_2.0.1
org.eclipse.gef.sdk_3.0.1
org.eclipse.gef_3.0.1
org.eclipse.jem.sdk_1.0.1
org.eclipse.jem_1.0.1
org.eclipse.team.extras_3.0.0
org.eclipse.ve_1.0.1
org.eclipse.xsd_2.0.1
And now I got, if I open a java file:
org.eclipse.jdt.internal.core.ClasspathEntry.validateClasspa thEntry(ClasspathEntry.java:1340)
org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspa th(JavaProject.java:2046)
org.eclipse.jdt.internal.core.DeltaProcessingState$ProjectUp dateInfo.updateProjectReferencesIfNecessary(DeltaProcessingS tate.java:98)
org.eclipse.jdt.internal.core.DeltaProcessingState.performCl asspathResourceChange(DeltaProcessingState.java:223)
org.eclipse.jdt.internal.core.SetClasspathOperation.updatePr ojectReferencesIfNecessary(SetClasspathOperation.java:784)
org.eclipse.jdt.internal.core.SetClasspathOperation.executeO peration(SetClasspathOperation.java:243)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:710)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1714)
org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOperation.java:771)
org.eclipse.jdt.internal.core.JavaProject.setRawClasspath(Ja vaProject.java:2739)
at org.eclipse.jdt.core.JavaCore$3.run(JavaCore.java:3852)
org.eclipse.jdt.internal.core.BatchOperation.executeOperatio n(BatchOperation.java:34)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:3665)
at org.eclipse.jdt.core.JavaCore.setClasspathContainer(JavaCore .java:3835)
org.eclipse.ve.internal.swt.SWTContainerInitializer.initiali ze(SWTContainerInitializer.java:23)
org.eclipse.jdt.internal.core.JavaModelManager.initializeCon tainer(JavaModelManager.java:1281)
org.eclipse.jdt.internal.core.JavaModelManager.getClasspathC ontainer(JavaModelManager.java:855)
at org.eclipse.jdt.core.JavaCore.getClasspathContainer(JavaCore .java:1313)
org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspa th(JavaProject.java:2033)
org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspa th(JavaProject.java:1941)
at org.eclipse.jdt.core.JavaCore.setClasspathContainer(JavaCore .java:3826)
org.eclipse.jdt.internal.launching.JREContainerInitializer.i nitialize(JREContainerInitializer.java:54)
org.eclipse.jdt.internal.core.DeltaProcessingState.initializ eRoots(DeltaProcessingState.java:260)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:708)
org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOperation.java:766)
org.eclipse.jdt.internal.core.CompilationUnit.becomeWorkingC opy(CompilationUnit.java:82)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitDocume ntProvider.createFileInfo(CompilationUnitDocumentProvider.ja va:854)
org.eclipse.ui.editors.text.TextFileDocumentProvider.connect (TextFileDocumentProvider.java:463)
org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:2993)
org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:173)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1253)
org.eclipse.jdt.internal.ui.javaeditor.JavaEditor.internalDo SetInput(JavaEditor.java:2236)
org.eclipse.jdt.internal.ui.javaeditor.JavaEditor.doSetInput (JavaEditor.java:2218)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .doSetInput(CompilationUnitEditor.java:1500)
org.eclipse.ui.texteditor.AbstractTextEditor$16.run(Abstract TextEditor.java:2345)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:624)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:621)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:1975)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:2363)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:2390)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:857)
org.eclipse.ui.internal.EditorManager.busyRestoreEditorHelpe r(EditorManager.java:1223)
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:1102)
at org.eclipse.ui.internal.EditorManager$7.run(EditorManager.ja va:1064)
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:1062)
org.eclipse.ui.internal.EditorManager$Editor.getEditor(Edito rManager.java:1648)
org.eclipse.ui.internal.EditorManager$Editor.getPart(EditorM anager.java:1639)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:26 0)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.newapi.LeftToRightTabO rder.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.newapi.TabbedStackPres entation.selectPart(TabbedStackPresentation.java:391)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1070)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1019)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 23)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:406)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:109 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:267)
at org.eclipse.ui.internal.EditorManager$4.run(EditorManager.ja va:829)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:809)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:697)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:660)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2236)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2165)
at org.eclipse.ui.internal.WorkbenchPage.access$7(WorkbenchPage .java:2157)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2143)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2138)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
at org.eclipse.ui.actions.OpenWithMenu$3.handleEvent(OpenWithMe nu.java:306)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
mfg Thomas Richter
Thomas Richter 'Codito ergo sum' Diplominformatiker Softwareentwickler
tr@ariva.de http://www.ariva.de
+(49) 0431/97108-27
Börse Kurse Charts Aktien Zertifikate Anleihen Fonds Devisen
FUDForum. Page generated in 0.03429 seconds
