Home » Modeling » GMF (Graphical Modeling Framework) » Need to customise .gmfgen generation template
Need to customise .gmfgen generation template [message #201970] Thu, 14 August 2008 07:22 Go to next message
Originally posted by: knakov.scopeset.de
I need to customize the template that generates .gmfgen file out of the
gmfmap file. I need this because the current generator overrides my
manual changes to the .gmfgen file. Where is this template located and
how can I modify it?
Thanks in advance,
Kalin
Re: Need to customise .gmfgen generation template [message #202024 is a reply to message #201970] Thu, 14 August 2008 21:01 Go to previous messageGo to next message
Hi Kalin,
If you can't find the answer to this, I just use diff in Eclipse to
merge my changes manually. It's not ideal but it will suffice until the
GMF team addresses this problem (or adds more parameters to the
generation files perhaps?)
Jevon
Kalin Nakov wrote:
> Thanks in advance,
> Kalin
Re: Need to customise .gmfgen generation template [message #202072 is a reply to message #201970] Fri, 15 August 2008 04:38 Go to previous messageGo to next message
Hello Kalin,
For now you have to extens DiagramGenModelTransformer class. In future we
will use .qvto transformation script for it.
Alex Shatalin
Re: Need to customise .gmfgen generation template [message #235401 is a reply to message #202072] Mon, 06 July 2009 07:59 Go to previous messageGo to next message
> we will use .qvto transformation script for it.
Hey Alex,
is this problem now solved in Galileo? As I understand, you now use
there real model transformations with QVTO, don't you?
Does this anyhow affect the merging of a customized gmfgen model and a
mapping model?
I still have the problem that I have a customized gmfgen and have to
reapply the transformation of the mapping model to the gmfgen. This
usually destroys most of my customizations and I have to do them again...
Hauke
Re: Need to customise .gmfgen generation template [message #235408 is a reply to message #202072] Mon, 06 July 2009 07:59 Go to previous messageGo to next message
Hey Alex,
mapping model?
Hauke
Re: Need to customise .gmfgen generation template [message #235558 is a reply to message #235408] Tue, 07 July 2009 09:40 Go to previous messageGo to next message
Hello Hauke,
Yes, it is possible to use QVTO in the latest released GMF - see "Map to
Gen transformation/Use QVTO transformation" option in .gmfmap->.gmfgen transformation
wizard + org.eclipse.gmf.bridge/transforms/Map2Gen.qvto
Alex Shatalin
Re: Need to customise .gmfgen generation template [message #236400 is a reply to message #235558] Fri, 17 July 2009 14:20 Go to previous message
> transformation wizard + org.eclipse.gmf.bridge/transforms/Map2Gen.qvto
Is there an example somewhere that uses such an in-place transformation?
Hauke
Previous Topic:Convert RelativeBendpoints to absolute points?
Next Topic:Workflow runner having trouble finding packages
Current Time: Wed Nov 05 19:01:34 EST 2025
Powered by FUDForum. Page generated in 0.03936 seconds
