Home » Modeling » QVT-OML » Setting a configuration property from Java
Setting a configuration property from Java [message #1235519] Fri, 24 January 2014 10:11 Go to next message
Hello everyone,
I'm writing a Operational QVT which will use a "configuration property"
In Eclipse's run Configuration for the transformation i can see my configuration property and i can set the value as expected.
Now i'm stuck trying to find a way to set this configuration property from Java, since i need to call the transformation from Java code.
I'm showing you my attempt, hoping that it's enough clear. I've reused an already available (and working) code:
private static void launchTransformation(String trURI, String trName,
			boolean generateTrace, Resource chessModel, Resource feiModel, IProgressMonitor monitor) throws Exception{
		String chessModelURIString = chessModel.getURI().toString();
		String feiModelURIString = feiModel.getURI().toString();
		String qvtTraceURIString = generateTrace ? chessModelURIString.substring(0,
				chessModelURIString.lastIndexOf('.') + 1) + "qvtotrace" : null;
		String trURIString = trURI;
		ILaunchManager manager = DebugPlugin.getDefault().getLaunchManager();
		ILaunchConfigurationType c = manager
				.getLaunchConfigurationType(QvtLaunchConfigurationDelegate.LAUNCH_CONFIGURATION_TYPE_ID);
		ILaunchConfigurationWorkingCopy instance = c.newInstance(null, trName);
		instance.setAttribute(IQvtLaunchConstants.CLEAR_CONTENTS + "1", true);
		instance.setAttribute(IQvtLaunchConstants.CLEAR_CONTENTS + "2", true);
		instance.setAttribute(IQvtLaunchConstants.ELEM_COUNT, 2);
		instance.setAttribute(IQvtLaunchConstants.FEATURE_NAME + "1", "");
		instance.setAttribute(IQvtLaunchConstants.FEATURE_NAME + "2", "");
		instance.setAttribute(IQvtLaunchConstants.MODULE, trURIString);
		instance.setAttribute(IQvtLaunchConstants.TARGET_MODEL + "1", chessModelURIString);
		instance.setAttribute(IQvtLaunchConstants.TARGET_TYPE + "1", "NEW_MODEL");
		instance.setAttribute(IQvtLaunchConstants.TARGET_MODEL + "2", feiModelURIString);
		instance.setAttribute(IQvtLaunchConstants.TARGET_TYPE + "2", "NEW_MODEL");
		if (generateTrace){
			instance.setAttribute(IQvtLaunchConstants.TRACE_FILE, qvtTraceURIString);
			instance.setAttribute(IQvtLaunchConstants.USE_TRACE_FILE, generateTrace);
		QvtTransformation qvtTransformation = new QvtInterpretedTransformation(
				QvtLaunchConfigurationDelegateBase.getQvtModule(instance));
		IStatus status = QvtLaunchConfigurationDelegateBase.validate(
				qvtTransformation, instance);
		if (status.getSeverity() > IStatus.WARNING) {
			throw new CoreException(status);
		EvaluationMonitor execMonitor = createMonitor();
		Context context = QvtLaunchUtil.createContext(instance);
		OutputStreamWriter s = new OutputStreamWriter(CHESSProjectSupport.CHESS_CONSOLE);
		context.setLog(new WriterLog(s));
		context.setMonitor(execMonitor);
		//begin attempt
		Map<String, String> configMap = new HashMap<String, String>();
		Set<QvtConfigurationProperty> configProps = qvtTransformation.getConfigurationProperties();
		for (QvtConfigurationProperty qvtConfProp : configProps) {
			if(qvtConfProp.getName().equals("systemName")){
				configMap.put(qvtConfProp.getName(), "attempt");
				 * "attempt" will be a String selected by a user through a dialog
				 * at run-time passed as parameter to this function
		instance.setAttribute(IQvtLaunchConstants.CONFIGURATION_PROPERTIES, configMap);
		//end attempt
		QvtLaunchConfigurationDelegateBase.doLaunch(qvtTransformation,instance, context);
		qvtTransformation.cleanup();
unfortunately the configuration property called "systemName" is null when i read it in the transformation.
I know i'm asking a lot, but it would be great if someone notices something wrong or missing in my attempt and could point it to me.
If you need further information, please tell me.
I apologize in advance if it has been already discussed, but i haven't found anything
Nicholas
Re: Setting a configuration property from Java [message #1235527 is a reply to message #1235519] Fri, 24 January 2014 10:37 Go to previous messageGo to next message
You can study the code just as well as I can. Or you can use a debugger
to conmopare what works.
But you're more likely to get takers if you provide a useable repro. See
http://wiki.eclipse.org/OCL/ForumNetiquette
Ed Willink
On 24/01/2014 15:11, nicholas pacini wrote:
> Hello everyone,
> "qvtotrace" : null;
> trName);
> "1", true);
> "2", true);
> "NEW_MODEL");
> feiModelURIString);
> "NEW_MODEL");
> if (generateTrace){
> qvtTraceURIString);
> //begin attempt
> through a dialog * at run-time passed as parameter to
> this function
> configMap);
> //end attempt
> found anything
> Nicholas
Re: Setting a configuration property from Java [message #1236447 is a reply to message #1235527] Mon, 27 January 2014 03:40 Go to previous messageGo to next message
Hello Ed,
thanks for your reply, sure i see your point.
but before trying to provide a usable repro, please allow me to ask some generic question (to you and/or anyone else):
first of all, is it possible to set a configuration property from java code?
then, if so, are there some examples or tutorials which explain how to do it? because i can't seem to find any
thanks for your time,
Nicholas
Re: Setting a configuration property from Java [message #1236519 is a reply to message #1235519] Mon, 27 January 2014 07:07 Go to previous messageGo to next message
It is possible. Have a look at the classes TransformationExecutor and ExecutionContextImpl.
Re: Setting a configuration property from Java [message #1236846 is a reply to message #1236519] Tue, 28 January 2014 02:57 Go to previous message
Hi Christopher,
thanks for the advice, I've always used different classes to launch the transformations, so i had to re-write almost everything but now it works!
thanks again,
Nicholas
Previous Topic:Transforming two model instances into a single model instance
Next Topic:Stereotype not applied to the xmi output file !
Current Time: Fri Oct 31 21:50:12 EDT 2025
Powered by FUDForum. Page generated in 0.05249 seconds
