Home » Eclipse Projects » EclipseLink » Got PropertyException when using MOXy
Got PropertyException when using MOXy [message #1234708] Wed, 22 January 2014 16:33 Go to next message
Paul G is currently offline Paul GFriend
Hey Forum!
I'm trying to use EclipseLink MOXy to marshal some models into XML. Therefor I would like to use ObjectGraphs to have a custom and different output of what is serialized into xml.
But when I try to implement the good examples of Blaise Doughan's blog (title: MOXy's Object Graphs - Input/Output Partial Models to XML & JSON) with Maven, I got following exception:
javax.xml.bind.PropertyException: name: eclipselink.object-graph value: contact info
Thats the used pom.xml:
<project xmlns="..." xmlns:xsi="..."
  xsi:schemaLocation="... ...">
  <modelVersion>4.0.0</modelVersion>
  <groupId>main</groupId>
  <artifactId>eclipselink_test</artifactId>
  <version>0.0.1-SNAPSHOT</version>
  <packaging>jar</packaging>
  <name>eclipselink_test</name>
  <url>link-to-maven</url>
  <properties>
    <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
  </properties>
  <dependencies>
    <dependency>
      <groupId>junit</groupId>
      <artifactId>junit</artifactId>
      <version>3.8.1</version>
      <scope>test</scope>
    </dependency>
	<dependency>
		<groupId>org.eclipse.persistence</groupId>
		<artifactId>org.eclipse.persistence.moxy</artifactId>
		<version>2.5.1</version>
	</dependency>
    <dependency>
		<groupId>javax.xml.bind</groupId>
		<artifactId>jaxb-api</artifactId>
		<version>2.2.11</version>
	</dependency>
  </dependencies>
</project>
This is the model (Model.java):
package main.eclipselink_test;
import javax.xml.bind.annotation.XmlAccessType;
import javax.xml.bind.annotation.XmlAccessorType;
import javax.xml.bind.annotation.XmlAttribute;
import javax.xml.bind.annotation.XmlRootElement;
import org.eclipse.persistence.oxm.annotations.XmlNamedAttributeNode;
import org.eclipse.persistence.oxm.annotations.XmlNamedObjectGraph;
@XmlNamedObjectGraph(
	    name="contact info",
	    attributeNodes={
	        @XmlNamedAttributeNode("name")
@XmlRootElement
@XmlAccessorType(XmlAccessType.FIELD)
public class Model {
	public Model() {
	public Model(int id, String name) {
		this.id = id;
		this.name = name;
    @XmlAttribute
    private int id;
    @XmlAttribute
    private String name;
Thats the Application (App.java):
import javax.xml.bind.JAXBContext;
import javax.xml.bind.JAXBException;
import javax.xml.bind.Marshaller;
import org.eclipse.persistence.jaxb.MarshallerProperties;
public class App
    public static void main( String[] args ) throws JAXBException
    	JAXBContext jc = JAXBContext.newInstance(Model.class);
    	Model model = new Model(0, "testing");
        // Output XML
        Marshaller marshaller = jc.createMarshaller();
        marshaller.setProperty(Marshaller.JAXB_FORMATTED_OUTPUT, true);
        marshaller.marshal(model, System.out);
        // Output XML - Based on Object Graph
        marshaller.setProperty(MarshallerProperties.OBJECT_GRAPH, "contact info");
As you may see, I get the error message in App.java:
Exception in thread "main" javax.xml.bind.PropertyException: name: eclipselink.object-graph value: contact info
	at javax.xml.bind.helpers.AbstractMarshallerImpl.setProperty(Unknown Source)
	at com.sun.xml.internal.bind.v2.runtime.MarshallerImpl.setProperty(Unknown Source)
	at main.eclipselink_test.App.main(App.java:28)
(Sorry for the masses of code. I don't have the permission to post links.)
Does anybody have some suggestions what went wrong? Thanks!
Re: Got PropertyException when using MOXy [message #1235094 is a reply to message #1234708] Thu, 23 January 2014 15:07 Go to previous messageGo to next message
Matt MacIvor is currently offline Matt MacIvorFriend
Hi Paul,
The problem here is that you're not picking up the EclipseLink MOXy JAXB implementation. The class com.sun.xml.internal.bind.v2.runtime.MarshallerImpl if from the JAXB reference implementation included in the JDK.
In order to use the MOXy implementation, you will need to include a jaxb.properties file in the package with your domain classes.
The jaxb.properties file should contain:
javax.xml.bind.context.factory=org.eclipse.persistence.jaxb.JAXBContextFactory
This should trigger the EclipseLink implementation to be used instead of the RI.
I hope this helps
-Matt
[Updated on: Thu, 23 January 2014 15:08]
Report message to a moderator
Re: Got PropertyException when using MOXy [message #1235125 is a reply to message #1234708] Thu, 23 January 2014 16:18 Go to previous message
Blaise Doughan is currently offline Blaise DoughanFriend
Hi Paul,
Here is a link to a Maven project I have on GitHub that you could use as a model:
- https://github.com/bdoughan/blog20110322
You need to make sure the jaxb.properties file is in the following location:
src/main/resources/main/eclipselink_test/
-Blaise
Previous Topic:Performance Question - eclipselink.jdbc.cache-statements
Next Topic:Add entities programmatically
Current Time: Sat Apr 27 05:22:25 GMT 2024
Powered by FUDForum. Page generated in 0.03249 seconds
