Home » Eclipse Projects » Eclipse Platform » plugins don't work in Eclipse 3.0?
plugins don't work in Eclipse 3.0? [message #201551] Tue, 24 February 2004 23:09 Go to next message
Plugins that work in 2.1 don't seem to work in 3.0. Is there a secret?
Re: plugins don't work in Eclipse 3.0? [message #201776 is a reply to message #201551] Wed, 25 February 2004 15:29 Go to previous messageGo to next message
These are really plugin specific...I ran into the same problem with a
plugin called EclipseColorer...The developer had a patch available
(reaplacing the <requires> segment of the plugin.xml) that corrected the
problems...
Thing is, if the developer for the plugin you wish to use hasn't updated
that plugin for 3.0...You really only have two choices...
1. Try and correct it yourself if you have the plugin source code.
2. Stay at 2.1
hth,
adym
Re: plugins don't work in Eclipse 3.0? [message #202785 is a reply to message #201551] Thu, 26 February 2004 23:57 Go to previous message
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
Our goal is that they do work. The porting guide outlines the problem areas.
If you are finding problems with things not mentioned in the porting guide,
please enter bug reports against the relevant component. We need to know
about this stuff NOW!
Jeff
"Michael Stover" <mstover1@apache.org> wrote in message
news:pan.2004.02.25.04.09.47.36186@apache.org...
Previous Topic:problem running RCP app in M7
Next Topic:Plugin Editors...RuleBasedPartitionScanner or RuleBasedScanner...
Current Time: Sun Nov 09 01:29:03 EST 2025
Powered by FUDForum. Page generated in 0.23362 seconds
