Re: RichText on Windows7 64bits issue [message #1232561 is a reply to message #1232298] |
Fri, 17 January 2014 02:56   |
One complement I've discovered in the log file at the very begining of the session start part, I can see this:
!SESSION 2014-01-17 08:47:07.740 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_39
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86 -data @user.home/EPF/workspace.151
!ENTRY org.eclipse.epf.rcp.ui 1 0 2014-01-17 08:47:23.819
!MESSAGE INFO: Application start directory =C:\nils.laumaille\utils\EPF-composer-1.5.1.5-win32
!ENTRY org.eclipse.ui.workbench 2 0 2014-01-17 08:47:28.036
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-01-17 08:47:28.036
!MESSAGE Conflict for 'AUTOGEN:::org.eclipse.ui.cheatsheets.actionSet/org.eclipse.ui.cheatsheets.actions.CheatSheetHelpMenuAction':
HandlerActivation(commandId=AUTOGEN:::org.eclipse.ui.cheatsheets.actionSet/org.eclipse.ui.cheatsheets.actions.CheatSheetHelpMenuAction,
handler=ActionDelegateHandlerProxy(null,org.eclipse.ui.internal.cheatsheets.actions.CheatSheetHelpMenuAction),
expression=AndExpression(ActionSetExpression(org.eclipse.ui.cheatsheets.actionSet,org.eclipse.ui.internal.WorkbenchWindow@3cbb4b),WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@3cbb4b)),sourcePriority=16640)
handler=ActionDelegateHandlerProxy(null,org.eclipse.ui.cheatsheets.CheatSheetExtensionFactory:helpMenuAction),
Perhaps this exception is the root cause.
Any ideas?
Re: RichText on Windows7 64bits issue [message #1232699 is a reply to message #1232561] |
Fri, 17 January 2014 09:25  |
I finally solved my issue.
The cause was IE9 ... indeed I don't know how I found that but it seems that the RichText uses IE but on my computer the 32bits version of IE9 was not working.
So I reinstalled it and registered the ddl back ... and small miracle in my day, EPF richtext now works.
I hope this feedback could help some users in the same situation.
Greetings
FUDForum. Page generated in 0.24424 seconds
