Home » Modeling » EMF » assign value to model element automatically (assign value to model element automatically )
assign value to model element automatically [message #1232181] Thu, 16 January 2014 06:22 Go to next message
HelLo,
Is there is a way where i can assign a value to a model elements automatically. for instance when I have an element(A) with attribute that reference another model element (B), i need to build the other attributse of elemnt(A) based on some attribute of element (B)...
Can we achieve that through OCL , or I need to modify the generated code ...
Salwa
Re: assign value to model element automatically [message #1240916 is a reply to message #1232181] Fri, 07 February 2014 03:20 Go to previous message
Salwa,
Comments below.
On 16/01/2014 12:22 PM, Salwa Alzahmi wrote:
> HelLo,
> code ...
This is probably something you want to do in the editor, not directly in
the model. But then again, it sounds a little bit like such other
attributes are derived (should not be modified in a way that's
inconsistent with the reference to B). Is that the case? You can
express the logic for derived attributes using OCL (or with Xcore)...
> Salwa
Previous Topic:Create own PropertyDescriptor
Next Topic:Why code shows class as interface
Current Time: Mon Nov 10 00:17:50 EST 2025
Powered by FUDForum. Page generated in 0.03491 seconds
