Home » Modeling » OCL » Query over association instead of the classes (classifiers) with OCL
Query over association instead of the classes (classifiers) with OCL [message #1231452] Tue, 14 January 2014 13:09 Go to next message
suppose I have a simple Ecore as bellow:
   ----  (0..3)          (0..*)  ---------
  | A  | ---------------------- |   B     |               // AB is association name
   ----         AB              |-------- |
                                |age:EInt |
I would like to write a query that its output is as below:
 | A  | ---------------------- |   B'    |                // AB' is  association name
  ----         AB'             |-------- |                // B' is subset of B where age > 20
                               |age:EInt |                // and AB' is subset of AB
I can write a query to get B' like
B'=B->select(b:B | B.age>20)
I would like to write a query in OCL to get AB'. Semi-formal definition of AB' would be:
AB'=  all AB which its B side is restricted to B'
, in other words AB' is the same association as AB, but its target(co-domain) is restricted to B'.
I looked at OCL reference, but it seems that it is intended to work on Classes (like A and B here) rather than associations (like AB) in terms of query results. Am I right?
Any suggestion is appreciated.
Re: Query over association instead of the classes (classifiers) with OCL [message #1231458 is a reply to message #1231452] Tue, 14 January 2014 13:22 Go to previous messageGo to next message
You are very vague about the relationship of B and B' but it seems that
where you write query but actually you are performing a transformation.
OCL as specified cannot create objects so a query cannot help. The new
Pivot binding of Eclipse OCL has an experimental implementation of type
constructors, so you might be able to do what you want. But it doesn;'t
seem right at all.
You should use a transformation language, nearly all of which use OCL as
theuir underlying query foundation.
Ed Willink
> association name ---- AB |-------- |
> |age:EInt |
> association name
> subset of AB ---------
> I can write a query to get B' like B'=B->select(b:B | B.age>20)
> definition of AB' would be: AB'= all AB which its B side is
> restricted to B', in other words AB' is the same association as AB,
> Thanks
Re: Query over association instead of the classes (classifiers) with OCL [message #1231485 is a reply to message #1231458] Tue, 14 January 2014 14:51 Go to previous message
B' here is subset of B, in OO terms we can consider B' is a new Type which inherits B so:
B' extends B
http://s29.postimg.org/3w7mtmucn/Screen_Shot_2014_01_14_at_2_21_49_PM.png
Actually I don't intend to create a new type ( I know that is another story). I intend to query association. As I wrote I can write to get B':
My question is that can I write a query on associations like AB-> select (ab:AB | AB->codomain()=B'). so the query returns me association instead of class.
As you see I am not questioning creation of the types and association, but just having query on associations.
Previous Topic:union two sets of different classifier
Next Topic:change in the use of environmentView from juno to kepler
Current Time: Fri Nov 07 15:00:06 EST 2025
Powered by FUDForum. Page generated in 0.04378 seconds
