InvokerServlet cannot be loaded in Tomcat 6.0.14 in Eclipse SDK 3.3.0 [message #200769] |
Sun, 30 September 2007 21:37 |
a Messages: 75 Registered: July 2009 |
Member |
Problem: InvokerServlet cannot be loaded in Tomcat 6.0.14 in Eclipse SDK
3.3.0
Error: "org.apache.catalina.servlets.InvokerServlet is privileged and cannot
be loaded by this web application"
Software:
Eclipse SDK, Version: 3.3.0, Build id: I20070621-1340
wtp-all-in-one-sdk-R-2.0-200706260303-win32.zip
jdk-6u2-windows-i586-p.exe
apache-tomcat-6.0.14.exe
Window XP Pro SP2
Procedure:
In Servers view, define a new server for Tomcat 6.0.14 using jdk1.6.0_02.
Enabled servlet invoker by uncommenting the following lines in web.xml.
<servlet>
<servlet-name>invoker</servlet-name>
<servlet-class>
</servlet-class>
<init-param>
<param-name>debug</param-name>
<param-value>0</param-value>
</init-param>
<load-on-startup>2</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>/servlet/*</url-pattern>
</servlet-mapping>
In Servers view, start server.
The following error appears in the Console view:
Sep 30, 2007 2:26:50 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The Apache Tomcat Native library which allows optimal performance in
production environments was not found on the java.library.path: C:\Program
Files\Java\jdk1.6.0_02\bin;.;C:\WINDOWS\Sun\Java\bin;C:\WIND OWS\system32;C:\WINDOWS;C:\DOS\Perl\site\bin;C:\DOS\Perl\bin ;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\ Program
Files\ATI Technologies\ATI Control Panel;"C:\Program Files\Common
Files\Roxio Shared\DLLShared";C:\Program Files\Common Files\Roxio
Shared\DLLShared;C:\Program Files\Common Files\Adobe\AGL;"C:\Program
Files\Zone Labs\ZoneAlarm\MailFrontier";C:\Program Files\Microsoft\Support
Tools\;C:\Program Files\ATI Technologies\ATI.ACE\;C:\Program Files\CVSNT\
Sep 30, 2007 2:26:50 PM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Sep 30, 2007 2:26:50 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1215 ms
Sep 30, 2007 2:26:50 PM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Sep 30, 2007 2:26:50 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.14
java.lang.reflect.InvocationTargetException
org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
Caused by: java.lang.SecurityException: Servlet of class
org.apache.catalina.servlets.InvokerServlet is privileged and cannot be
org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:1134)
org.apache.catalina.core.StandardWrapper.load(StandardWrappe r.java:981)
org.apache.catalina.core.StandardContext.loadOnStartup(Stand ardContext.java:4045)
org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4351)
org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1045)
org.apache.catalina.core.StandardHost.start(StandardHost.jav a:719)
org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
org.apache.catalina.core.StandardService.start(StandardServi ce.java:516)
org.apache.catalina.core.StandardServer.start(StandardServer .java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:566 )
... 6 more
Re: InvokerServlet cannot be loaded in Tomcat 6.0.14 in Eclipse SDK 3.3.0 [message #200847 is a reply to message #200769] |
Mon, 01 October 2007 13:38 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
Why do want to enable the InvokerServlet? There are different ways of
handling this, depending on the reason.
Larry
> 3.3.0
> Software:
> Window XP Pro SP2
> Procedure:
> <servlet>
> <servlet-class>
> </servlet-class>
> <init-param>
> </init-param>
> </servlet>
> <servlet-mapping>
> </servlet-mapping>
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 6 more
Re: InvokerServlet cannot be loaded in Tomcat 6.0.14 in Eclipse SDK 3.3.0 [message #200905 is a reply to message #200769] |
Mon, 01 October 2007 19:06 |
Originally posted by: hall.coreservlets.com
I personally find the invoker servlet very useful when learning,
experimenting, and testing out capabilities. But of course you should
never have the invoker servlet enabled in projects you are going to deploy.
Anyhow, when you use your own version of Tomcat 6.x with MyEclipse, it
automatically uses the configuration files in the install_dir/conf folder.
You have to edit two of these to enable the invoker servlet (the servlet
and servlet-mapping entries in web.xml, and you have to change 'Context'
to 'Context reloadable="true" privileged="true"' in context.xml). But
regular Eclipse uses its own deployment and configuration folders. You can
copy the files from the standard "conf" folder, or you can double click on
the server and tell it to use your existing folders.
Again, I want to stress that you should not use the invoker servlet for
deployed applications. But, I find it very useful when learning and
experimenting with temporary projects.
Re: InvokerServlet cannot be loaded in Tomcat 6.0.14 in Eclipse SDK 3.3.0 [message #201078 is a reply to message #200943] |
Tue, 02 October 2007 16:57 |
John wrote:
> Marty - I appreciate your help. Your solution worked!
> It is unclear why Eclipse does not automatically import the context.xml file
> to path
> /Servers/Tomcat v6.0 Server at localhost-config
> or
> MyWorkspace.metadata.pluginsorg.eclipse.wst.server.coretmp0c onf
> Do you know why it doesn't?
I am not sure either. But in one (of the many) hats that I wear, I teach
Java Web app programming in the Johns Hopkins part-time graduate program
in Computer Science. Students are free to use any IDE they want, and some
use MyEclipse, some use regular Eclipse, and others use whatever they are
used to (NetBeans or IDEA, perhaps). A common problem from the regular
Eclipse users is that they make changes to the Tomcat configuration files
(such as the entry for context.xml for the invoker servlet), and don't
know why it is not picked up.
Now, if I could only make projects that would be recognized by BOTH
MyEclipse and regular Eclipse as dynamic Web projects, I would be happy.
That way for each topic that I cover at Hopkins, I could distribute a
single sample project to my JHU students. Similarly, in my "real" work, I
also have clients that are split between MyEclipse and regular Eclipse,
and I want to distribute projects to them as well.
Finally, again, please remember that the invoker servlet is for testing
and experimenting only: never for deployed apps.
Cheers-
- Marty
JSP/servlet/Struts/JSF/AJAX/GWT/Java training:
http://courses.coreservlets.com/
FUDForum. Page generated in 0.03776 seconds
