Home » Modeling » OCL » oclinecore editor - removes genmodel annotation entries
oclinecore editor - removes genmodel annotation entries [message #1230294] Sat, 11 January 2014 10:37 Go to next message
I've noticed that OCLInEcore editor removes the body entry of genmodel annotations.
Is this correct ?
Vlad
Re: oclinecore editor - removes genmodel annotation entries [message #1230300 is a reply to message #1230294] Sat, 11 January 2014 10:55 Go to previous messageGo to next message
There has been steady evolution making OCL in Ecore steadily more
useable. As you note OCL inCDATA is not really tenable.
As part of the evolution, Helios introduced a namespace for OCL embedded
in Ecore. Unfortunately this was different to that used by UML to export
OCL to Ecore. In Kepler this discrepancy was fixed and you should just
be noticing the OCLinEcore editor picking up the old namesapce and
translating it to the new.
Ed Willink
On 11/01/2014 15:37, Vlad Gheorghe wrote:
> Hello,
> annotations.
> Is this correct ?
> Regards
> Vlad
Re: oclinecore editor - removes genmodel annotation entries [message #1230621 is a reply to message #1230300] Sun, 12 January 2014 10:49 Go to previous messageGo to next message
Hi Ed,
Sorry for not being specific enough.
Given the following ecore file:
<ecore:EPackage xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="p">
  <eClassifiers xsi:type="ecore:EClass" name="A">
    <eOperations name="f">
      <eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
        <details key="documentation" value="function doc"/>
        <details key="body" value="return 1;"/>
      </eAnnotations>
    </eOperations>
  </eClassifiers>
</ecore:EPackage>
Opening it with OCLInEcore editor, insert a blank line, save results in the removal of the key="body" details object.
I think this should not happen, as the user might want to have some of the operations implemented in java like this, while having others in ocl.
Vlad Gheorghe
Re: oclinecore editor - removes genmodel annotation entries [message #1230653 is a reply to message #1230621] Sun, 12 January 2014 12:56 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=425506
> </eAnnotations>
> </eOperations>
> </eClassifiers>
> </ecore:EPackage>
Previous Topic:using includes and excludes returns unexpected result using interactive Xtext OCL
Next Topic:Type casting of query.evaluate() and ocl.evaluate()
Current Time: Fri Nov 07 15:00:11 EST 2025
Powered by FUDForum. Page generated in 0.02669 seconds
