Home » Newcomers » Newcomers » getResourceAsStream
getResourceAsStream [message #1229786] Fri, 10 January 2014 03:07 Go to next message
I am using eclipse-indigo.
I download a file from internet then use that in eclipse by copying that file to my working place then create a new java project with that same name. In that program there is a line to read a file by using
classname.class.getResourceAsStream("textfilename");
but it throws a NullPointerException.
Then, I create a new java project in eclipse and check that reading this file as a small program,that executes successfully. The files are within the same package in both cases.
Please guide me the above, and also I am looking for advice on how to link a file in eclipse indigo.
Thanks in advance.
Re: getResourceAsStream [message #1230237 is a reply to message #1229786] Sat, 11 January 2014 06:46 Go to previous messageGo to next message
If the file copied to the bin folder? You can use the Navigator view to
inspect what's in the bin folder.
> Thanks in advance.
Re: getResourceAsStream [message #1231496 is a reply to message #1229786] Tue, 14 January 2014 15:33 Go to previous message
> Thanks in advance.
Sometimes it's helpful to write a test file where
you are trying to read the original file from then
locate the test file on disk to see where it actually
got written to.
Previous Topic:sunJCE_provider problem
Next Topic:Setting a local osgi.configuration.area for a Windows multi-user install
Current Time: Sun Oct 19 09:47:24 EDT 2025
Powered by FUDForum. Page generated in 0.09966 seconds
