connection-editing via properties is incorrect [message #200351] |
Tue, 05 August 2008 09:48 |
Thomas Beyer Messages: 47 Registered: July 2009 |
Member |
Hi Community,
I am troubling a bit about the default functionality in the
Properties-View, which is generated for connections resp. relations.
Selecting source or target of my Connections on the prop-tab results in a
popup-menu, that shows ALL diagram nodes (I assume them to be of the type
org.eclipse.gmf.runtime.notation.Node, since Edges arent shown).
So I can set multiple Sources and Targets of my connections, regardless of
the OCL, set in my mapping model, or even the logic structure of the
underlying dsl (ecore-model).
Incorrect source or target changes (i also tried multiple source- and
target elements) are reflected in the domain model, but of
course not in the diagram resp. notation model.
Is that the intended behavior or a known issue?
I would love a generated functionality in the property tab, that does this
in a correct manner. (Allow a correct selection according to the dsl and
OCL-constraints and reflcting changes in domain and notation model).
The current implementation invalidates my diagram model. Therefore I
cannot allow my clients to use this functionality.
Hope for help or explanations
Regards Thomas
FUDForum. Page generated in 0.03126 seconds
