Home » Eclipse Projects » EclipseLink » Attributes in the default namespace?
Re: Attributes in the default namespace? [message #1229949 is a reply to message #1229172] |
Fri, 10 January 2014 16:22 |
Hi Nate,
Here is what I did to get your example to work:
XML Schemas
I changed the xmlns:xs declaration to be the namespace http://www.w3.org/2001/XMLSchema instead of http://eclipse.org/2001/XMLSchema.
Generated a JAXB Model
I generated a JAXB model from the Login.xsd using the all the defaults:
Demo Code
Here is some code to read/write the JSON:
package org.eclipse.schemas.api.achilles.v1;
import java.io.File;
import java.util.*;
import javax.xml.bind.*;
import org.eclipse.persistence.jaxb.JAXBContextProperties;
public class Demo {
public static void main(String[] args) throws Exception {
Map<String, Object> properties = new HashMap<String, Object>(2);
properties.put(JAXBContextProperties.MEDIA_TYPE, "application/json");
properties.put(JAXBContextProperties.JSON_ATTRIBUTE_PREFIX, "@");
JAXBContext jc = JAXBContext.newInstance("org.eclipse.schemas.api.achilles.v1", ObjectFactory.class.getClassLoader(), properties);
Unmarshaller unmarshaller = jc.createUnmarshaller();
File json = new File("src/org/eclipse/schemas/api/achilles/v1/input.json");
LoginRequest loginRequest = (LoginRequest) unmarshaller.unmarshal(json);
Marshaller marshaller = jc.createMarshaller();
marshaller.setProperty(Marshaller.JAXB_FORMATTED_OUTPUT, true);
marshaller.marshal(loginRequest, System.out);
Input/Output
Here is the JSON document I used for this example:
"LoginRequest" : {
"UserCredentials" : {
"@name" : "username",
"@password" : "password"
-Blaise
Re: Attributes in the default namespace? [message #1230009 is a reply to message #1229949] |
Fri, 10 January 2014 19:45 |
nate roe Messages: 8 Registered: January 2014 |
Thanks, Blaise. It seems I left out a crucial detail, however: I have schema validation enabled and the exception that I'm seeing stems from com.sun.org.apache.xerces.internal.jaxp.validation.ValidatorHandlerImpl
First, I load my XSDs:
private Schema getSchema(final String schemaPath, final String[] schemaNames) throws SAXException
final SchemaFactory sf = new XMLSchemaFactory();
sf.setFeature(Constants.XERCES_FEATURE_PREFIX + Constants.NAMESPACE_GROWTH_FEATURE, true);
sf.setProperty(XMLSchemaLoader.ENTITY_RESOLVER, new XMLEntityResolver()
public XMLInputSource resolveEntity(XMLResourceIdentifier resourceIdentifier)
throws XNIException, IOException
return new XMLInputSource(null, resourceIdentifier.getLiteralSystemId(), resourceIdentifier
.getLiteralSystemId(), getClass().getResourceAsStream(
schemaPath + "/" + resourceIdentifier.getLiteralSystemId()), null);
final StreamSource[] sources = new StreamSource[schemaNames.length];
for (int i = 0; i < schemaNames.length; i++)
sources[i] = new StreamSource(getClass().getResourceAsStream(
schemaPath + "/" + schemaNames[i]), schemaNames[i]);
return sf.newSchema(sources);
And then I set the schema and namespace map on my Unmarshaller:
unmarshaller.setSchema(schema);
unmarshaller.setProperty(MarshallerProperties.NAMESPACE_PREFIX_MAPPER, namespaceMap)
The namespace map includes an entry mapping from the namespace "http://eclipse.org/schemas/api/achilles/v1.0" to the prefix
And then when I unmarshal a document with an empty namespace prefix (as in my OP), an exception is thrown from the XMLSchemaValidator:
Caused by: org.xml.sax.SAXParseException; cvc-complex-type.3.2.2: Attribute 'name' is not allowed to appear in element 'UserCredentials'.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:198)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.error(ErrorHandlerWrapper.java:134)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:437)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:368)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:325)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator$XSIErrorReporter.reportError(XMLSchemaValidator.java:453)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.reportSchemaError(XMLSchemaValidator.java:3232)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.processAttributes(XMLSchemaValidator.java:2709)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.handleStartElement(XMLSchemaValidator.java:2051)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.startElement(XMLSchemaValidator.java:741)
at com.sun.org.apache.xerces.internal.jaxp.validation.ValidatorHandlerImpl.startElement(ValidatorHandlerImpl.java:565)
at org.eclipse.persistence.internal.oxm.record.XMLReader$ValidatingContentHandler.startElement(XMLReader.java:431)
at org.eclipse.persistence.internal.oxm.record.XMLReaderAdapter$ExtendedContentHandlerAdapter.startElement(XMLReaderAdapter.java:178)
at org.eclipse.persistence.internal.oxm.record.json.JSONReader.parse(JSONReader.java:302)
at org.eclipse.persistence.internal.oxm.record.json.JSONReader.parse(JSONReader.java:436)
at org.eclipse.persistence.internal.oxm.record.json.JSONReader.parse(JSONReader.java:303)
at org.eclipse.persistence.internal.oxm.record.json.JSONReader.parseRoot(JSONReader.java:166)
at org.eclipse.persistence.internal.oxm.record.json.JSONReader.parse(JSONReader.java:125)
at org.eclipse.persistence.internal.oxm.record.SAXUnmarshaller.unmarshal(SAXUnmarshaller.java:972)
... 46 more
Re: Attributes in the default namespace? [message #1230110 is a reply to message #1230109] |
Sat, 11 January 2014 01:51 |
Here is the output:
xml (prefixed:qualified) passed
xml (prefixed:unqualified) failed
xml (default:qualified) failed
xml (default:unqualified) passed
json (prefixed:qualified) failed
json (prefixed:unqualified) passed
json (default:qualified) passed
json (default:unqualified) failed
So what this is saying is that when unmarshalling JSON, if there is a default namespace and the attributeFormDefault="qualified", then there is no error. In this case, however, XML unmarshalling will fail. Basically it seems like XML and JSON are handled inconsistently in this case.
[Updated on: Sat, 11 January 2014 01:56] Report message to a moderator
Re: Attributes in the default namespace? [message #1230111 is a reply to message #1230110] |
Sat, 11 January 2014 01:52 |
Here is the code producing the above output:
import java.io.StringReader;
import java.util.HashMap;
import java.util.Map;
import javax.ws.rs.core.MediaType;
import javax.xml.bind.JAXBContext;
import javax.xml.bind.Unmarshaller;
import javax.xml.bind.annotation.XmlAccessType;
import javax.xml.bind.annotation.XmlAccessorType;
import javax.xml.bind.annotation.XmlAttribute;
import javax.xml.bind.annotation.XmlRootElement;
import javax.xml.transform.stream.StreamSource;
import javax.xml.validation.Schema;
import org.eclipse.persistence.jaxb.JAXBContextFactory;
import org.eclipse.persistence.jaxb.MarshallerProperties;
import org.eclipse.persistence.jaxb.UnmarshallerProperties;
import com.sun.org.apache.xerces.internal.jaxp.validation.XMLSchemaFactory;
public class MoxyTest5
@XmlRootElement(name = "CatalogRequest", namespace = "http://ws.cyllenius.com/schemas/api/platform/v1.0")
@XmlAccessorType(XmlAccessType.FIELD)
public static class CatalogRequest
@XmlAttribute(name = "IncludeContent")
protected Boolean includeContent;
public boolean isIncludeContent()
if (includeContent == null)
return true;
else
return includeContent;
public void setIncludeContent(boolean value)
this.includeContent = value;
public boolean isSetIncludeContent()
return (this.includeContent != null);
public void unsetIncludeContent()
this.includeContent = null;
private static final String schemaWithAttributesQualified = "" //
+ "<?xml version=\"1.0\" encoding=\"utf-8\" standalone=\"no\"?>" //
+ "<xs:schema xmlns:cyllenius=\"http://ws.cyllenius.com/schemas/api/platform/v1.0\" xmlns:xs=\"http://www.w3.org/2001/XMLSchema\" elementFormDefault=\"qualified\" attributeFormDefault=\"qualified\" id=\"Cyllenius2010001A\" targetNamespace=\"http://ws.cyllenius.com/schemas/api/platform/v1.0\" version=\"1.1\">" //
+ " <xs:element name=\"CatalogRequest\" type=\"cyllenius:CatalogRequest\"/>" //
+ " <xs:complexType name=\"CatalogRequest\">" //
+ " <xs:attribute default=\"true\" name=\"IncludeContent\" type=\"xs:boolean\" use=\"optional\">" //
+ " </xs:attribute>" //
+ " </xs:complexType>" //
+ "</xs:schema>";
private static final String schemaWithoutAttributesQualified = "" //
+ "<xs:schema xmlns:cyllenius=\"http://ws.cyllenius.com/schemas/api/platform/v1.0\" xmlns:xs=\"http://www.w3.org/2001/XMLSchema\" elementFormDefault=\"qualified\" id=\"Cyllenius2010001A\" targetNamespace=\"http://ws.cyllenius.com/schemas/api/platform/v1.0\" version=\"1.1\">" //
+ "</xs:schema>";
private static CatalogRequest parseJSON(final Map<String, String> namespaceMap,
final String json, final String schemaString) throws Exception
final JAXBContext context = JAXBContextFactory.createContext(
new Class[] { CatalogRequest.class }, new HashMap<String, String>());
final Unmarshaller unmarshaller = context.createUnmarshaller();
unmarshaller.setProperty(UnmarshallerProperties.MEDIA_TYPE, MediaType.APPLICATION_JSON);
unmarshaller.setProperty(UnmarshallerProperties.JSON_ATTRIBUTE_PREFIX, "@");
unmarshaller.setProperty(MarshallerProperties.NAMESPACE_PREFIX_MAPPER, namespaceMap);
final Schema schema = new XMLSchemaFactory().newSchema(new StreamSource(new StringReader(
schemaString)));
return (CatalogRequest) unmarshaller.unmarshal(new StringReader(json));
private static CatalogRequest parseXML(final String xml, final String schemaString)
throws Exception
unmarshaller.setProperty(UnmarshallerProperties.MEDIA_TYPE, MediaType.APPLICATION_XML);
schemaString)));
return (CatalogRequest) unmarshaller.unmarshal(new StringReader(xml));
public static void main(final String[] argv)
try
final String xml = "<cyllenius:CatalogRequest xmlns:cyllenius=\"http://ws.cyllenius.com/schemas/api/platform/v1.0\" cyllenius:IncludeContent=\"true\" />";
parseXML(xml, schemaWithAttributesQualified);
System.out.println("xml (prefixed:qualified) passed");
catch (final Exception e)
System.err.println("xml (prefixed:qualified) failed");
// e.printStackTrace();
try
parseXML(xml, schemaWithoutAttributesQualified);
System.out.println("xml (prefixed:unqualified) passed");
System.err.println("xml (prefixed:unqualified) failed");
try
final String xml = "<CatalogRequest xmlns=\"http://ws.cyllenius.com/schemas/api/platform/v1.0\" IncludeContent=\"true\" />";
System.out.println("xml (default:qualified) passed");
System.err.println("xml (default:qualified) failed");
try
System.out.println("xml (default:unqualified) passed");
System.err.println("xml (default:unqualified) failed");
try
final Map<String, String> namespaceMap = new HashMap<String, String>();
namespaceMap.put("http://ws.cyllenius.com/schemas/api/platform/v1.0", "cyllenius");
final String json = "{\"cyllenius.CatalogRequest\":{\"@IncludeContent\":\"true\"}}";
parseJSON(namespaceMap, json, schemaWithAttributesQualified);
System.out.println("json (prefixed:qualified) passed");
System.err.println("json (prefixed:qualified) failed");
try
parseJSON(namespaceMap, json, schemaWithoutAttributesQualified);
System.out.println("json (prefixed:unqualified) passed");
System.err.println("json (prefixed:unqualified) failed");
try
namespaceMap.put("http://ws.cyllenius.com/schemas/api/platform/v1.0", "");
final String json = "{\"CatalogRequest\":{\"@IncludeContent\":\"true\"}}";
System.out.println("json (default:qualified) passed");
System.err.println("json (default:qualified) failed");
try
System.out.println("json (default:unqualified) passed");
System.err.println("json (default:unqualified) failed");
Current Time: Fri Apr 26 21:39:58 GMT 2024
Powered by FUDForum. Page generated in 0.03551 seconds
