Home » Eclipse Projects » Eclipse 4 » Odd behavior if E4 application closed via 'X' button
Odd behavior if E4 application closed via 'X' button [message #1228237] Mon, 06 January 2014 13:45 Go to next message
I am exploring developing an eclipse 4 RCP application, using JavaFX (efxclipse) as the renderer on a linux (CentOS 6.5) system. The app window consists of a main menu and single part stack that is initially empty. The user makes choices from the menu and the controller logic configures the part to be displayed in the part stack. One of the menu choices is used to exit the application and its handler simply closes the workbench.
I was testing the application and noticed that one time the application opened up with the parts already opened on the part stack. This was completely unexpected as I'm not doing anything to preserve any state as far as what was open when the application was exited. I did some experiments and noticed that if I exit the application via my exit menu (and command/handler), when it is run again, it comes up "empty" like I would expect. However, if I exit the application by just clicking the "X" button in the upper-right, the next time the application is run, it comes up with whatever parts I had open when it was last closed. Obviously there is some sort of preservation of state going on behind the scenes.
I'd like to know what's happening here and if it can be controlled - I may want to preserve the user's last "part configuration" so that it comes up the next time without their having to select the menu choices again. In the meantime, I'd like the application to come up in its initial empty state when it's run, regardless of how it was last shut down.
Re: Odd behavior if E4 application closed via 'X' button [message #1228296 is a reply to message #1228237] Mon, 06 January 2014 17:33 Go to previous messageGo to next message
> the workbench.
> the scenes.
Perserving the state is the default. If you always want it come up with
a clean state you can pass -clearPersistedState as a program argument or
set it to true using the product extension point.
How does your handler close the application? If the shutdown process is
running in its normal way it will *ALWAYS* save the state.
Tom
Re: Odd behavior if E4 application closed via 'X' button [message #1228555 is a reply to message #1228296] Tue, 07 January 2014 08:50 Go to previous messageGo to next message
Ah. I did not have -clearPersistedState set as a run-time argument, so that explains that.
I have a command and handler set up to be activated from a menu choice. The handler is as follows:
import org.eclipse.e4.core.di.annotations.Execute;
import org.eclipse.e4.ui.workbench.IWorkbench;
public class ExitHandler {
  @Execute
  public void execute(IWorkbench workbench) {
    System.out.println("ExitHandler called");
    workbench.close();
Is this the correct thing to do?
So, when I select exit from the menu the app closes and when I re-run it no state was preserved. However, if I just click the standard "X" button, state is preserved.
Is there a way to detect and handle the user clicking the "X" button?
Re: Odd behavior if E4 application closed via 'X' button [message #1228578 is a reply to message #1228555] Tue, 07 January 2014 09:29 Go to previous messageGo to next message
> that explains that.
> @Execute
> workbench.close();
Yes! So the bug is the other way round. There's a bug in workbench.close
:-( Please file a bug against e(fx)clipse!
Tom
Re: Odd behavior if E4 application closed via 'X' button [message #1229522 is a reply to message #1228578] Thu, 09 January 2014 11:17 Go to previous messageGo to next message
How do I file a bug report?
Re: Odd behavior if E4 application closed via 'X' button [message #1229527 is a reply to message #1229522] Thu, 09 January 2014 11:34 Go to previous message
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Efxclipse
Previous Topic:Issue with minimized PartStacks as replacement for FastViews
Next Topic:Add a Project Explorer in Eclipse 4 RCP Application
Current Time: Fri Sep 26 15:37:34 EDT 2025
Powered by FUDForum. Page generated in 0.05584 seconds
