Home » Modeling » EMF » [CDO] loading resources and package registration.
| [CDO] loading resources and package registration. [message #1227430] |
Sat, 04 January 2014 08:22  |
Hi (Eike),
In my effort to make Edapt support CDO model evolution, I need so help
understanding CDO and EPackages.
In the test case I work on I have this scenario:
Repo1 (source)
- Native packages
- Many resources conforming to native packages.
Repo2 (target)
- Empty
When I read a resource from Repo1 and I get an exception when calling
EcoreUtil.resolveAll(resource)
This is a Junit testcase, so the platform is not running and the native
EPackages are not registered by the platform. (The generated EMF code
for these packages is not present/available in the test case).
Now I gather that the EPackage should be registered, so I make sure the
EPackages are registered by the CDOViewProvider when unknown in the code
below. (Note: The EPackages are created from the .ecore file and added
to the resource set). However the CDO packageRegistry will report the
nsURI is already a known key, so adding is not allowed.
Thank You!
Christophe
Exception:
Registry packageRegistry = resourceSet.getPackageRegistry();
if (!packageRegistry.isEmpty()) {
CDOPackageRegistry cdoPackageRegistry = session
..getPackageRegistry();
for (String nsURI : packageRegistry.keySet()) {
EPackage packageToAdd = packageRegistry.getEPackage(nsURI);
if(!cdoPackageRegistry.containsKey(nsURI)){
cdoPackageRegistry.putEPackage(packageToAdd);
So now I am slightly confused, why will I get the exception below, while
the CDO Package registry reports it knows the nsURI?
Is it possible to work with resources with native packages
in a CDO repo, while the generated EPackage code is not available?
what does type=UNKNOWN mean?
Also, I tried this option:
session.options().setGeneratedPackageEmulationEnabled(true);
With this the Exception is gone, but later on I get a commit exception,
NPE on a missing EPackage. (I will report this Exception if needed later
on).
org.eclipse.emf.cdo.common.util.CDOException: Generated packages locally
not available:
CDOPackageUnit[id=http://www.netxforge.com/13042011/generics,
state=PROXY, type=UNKNOWN, originalType=NATIVE, timeStamp=2012-04-19
15:47:22.133]
org.eclipse.emf.internal.cdo.session.CDOSessionImpl.loadPackages(CDOSessionImpl.java:559)
org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl.load(CDOPackageUnitImpl.java:239)
org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl.load(CDOPackageUnitImpl.java:228)
org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl.getEPackage(CDOPackageInfoImpl.java:116)
org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl.getEPackage(CDOPackageInfoImpl.java:109)
org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage(EPackageRegistryImpl.java:127)
org.eclipse.emf.cdo.common.model.CDOClassifierRef.resolve(CDOClassifierRef.java:113)
org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOClassifierRefAndResolve(CDODataInputImpl.java:170)
org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.readSystemValues(BaseCDORevision.java:186)
org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.read(BaseCDORevision.java:160)
org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDORevision(CDODataInputImpl.java:427)
org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDORevision(CDODataInputImpl.java:418)
org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.readRevision(RevisionInfo.java:226)
org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.readResult(RevisionInfo.java:165)
org.eclipse.emf.cdo.internal.net4j.protocol.LoadRevisionsRequest.confirming(LoadRevisionsRequest.java:143)
org.eclipse.emf.cdo.internal.net4j.protocol.LoadRevisionsRequest.confirming(LoadRevisionsRequest.java:1)
org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequest.confirming(CDOClientRequest.java:97)
org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:442)
org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:502)
org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:535)
org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.loadRevisions(CDOClientProtocol.java:172)
org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.loadRevisions(CDORevisionManagerImpl.java:387)
org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevisions(CDORevisionManagerImpl.java:292)
org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevision(CDORevisionManagerImpl.java:275)
org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevision(CDORevisionManagerImpl.java:268)
org.eclipse.emf.internal.cdo.view.CDOViewImpl.getRevision(CDOViewImpl.java:729)
org.eclipse.emf.internal.cdo.view.AbstractCDOView.createObject(AbstractCDOView.java:1094)
org.eclipse.emf.internal.cdo.view.AbstractCDOView.getObject(AbstractCDOView.java:993)
org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.getObject(CDOTransactionImpl.java:1152)
org.eclipse.emf.internal.cdo.view.AbstractCDOView.convertIDToObject(AbstractCDOView.java:1327)
org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertIDToObject(CDOStoreImpl.java:691)
org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertToEMF(CDOStoreImpl.java:659)
org.eclipse.emf.internal.cdo.view.CDOStoreImpl.get(CDOStoreImpl.java:191)
org.eclipse.emf.ecore.impl.EStoreEObjectImpl$BasicEStoreEList.delegateGet(EStoreEObjectImpl.java:241)
org.eclipse.emf.common.util.DelegatingEList.get(DelegatingEList.java:230)
org.eclipse.emf.common.util.AbstractEList$EIterator.doNext(AbstractEList.java:703)
org.eclipse.emf.common.util.AbstractEList$EIterator.next(AbstractEList.java:690)
at org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(EcoreUtil.java:280)
org.eclipse.emf.edapt.common.ResourceUtils.resolveAll(ResourceUtils.java:289)
org.eclipse.emf.edapt.common.ResourceUtils.loadResourceSet(ResourceUtils.java:106)
org.eclipse.emf.edapt.cdo.migration.execution.CDOPersistency.loadModel(CDOPersistency.java:63)
org.eclipse.emf.edapt.cdo.migration.execution.CDOMigrationReconstructor.loadRepository(CDOMigrationReconstructor.java:35)
org.eclipse.emf.edapt.cdo.migration.execution.CDOMigrationReconstructor.endRelease(CDOMigrationReconstructor.java:55)
org.eclipse.emf.edapt.history.reconstruction.CompositeReconstructorBase.endRelease(CompositeReconstructorBase.java:173)
org.eclipse.emf.edapt.history.reconstruction.ForwardReconstructorBase.doReconstruct(ForwardReconstructorBase.java:83)
org.eclipse.emf.edapt.history.reconstruction.ForwardReconstructorBase.doReconstruct(ForwardReconstructorBase.java:58)
org.eclipse.emf.edapt.history.reconstruction.CompositeReconstructorBase.reconstruct(CompositeReconstructorBase.java:75)
org.eclipse.emf.edapt.cdo.migration.execution.CDOMigrator.migrate(CDOMigrator.java:365)
org.eclipse.emf.edapt.cdo.migration.execution.CDOMigrator.migrateAndCopy(CDOMigrator.java:269)
org.eclipse.emf.edapt.cdo.tests.CDOMigrationTestBase.testMigration(CDOMigrationTestBase.java:183)
org.eclipse.emf.edapt.cdo.tests.CDOMigrationTestCase.testMigration(CDOMigrationTestCase.java:73)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at junit.framework.TestCase.runTest(TestCase.java:176)
at junit.framework.TestCase.runBare(TestCase.java:141)
at junit.framework.TestResult$1.protect(TestResult.java:122)
at junit.framework.TestResult.runProtected(TestResult.java:142)
at junit.framework.TestResult.run(TestResult.java:125)
at junit.framework.TestCase.run(TestCase.java:129)
at junit.framework.TestSuite.runTest(TestSuite.java:255)
at junit.framework.TestSuite.run(TestSuite.java:250)
org.eclipse.emf.edapt.cdo.tests.CDOMigrationTestSuite.run(CDOMigrationTestSuite.java:80)
org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38ClassRunner.java:84)
org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
| Re: [CDO] loading resources and package registration. [message #1227482 is a reply to message #1227430] |
Sat, 04 January 2014 12:19   |
Hi Christophe,
If the original type of a model is NATIVE then either the current type must also be NATIVE or you must set
session.options().setGeneratedPackageEmulationEnabled(true).
The rest of your post was a little vague so I'm unsure what else to say.
Cheers
/Eike
http://www.esc-net.de
Am 04.01.2014 14:22, schrieb Christophe Bouhier:
> Hi (Eike),
> In my effort to make Edapt support CDO model evolution, I need so help understanding CDO and EPackages.
> Repo1 (source)
> - Native packages
> Repo2 (target)
> - Empty
> When I read a resource from Repo1 and I get an exception when calling EcoreUtil.resolveAll(resource)
> This is a Junit testcase, so the platform is not running and the native EPackages are not registered by the platform.
> (The generated EMF code for these packages is not present/available in the test case).
> Now I gather that the EPackage should be registered, so I make sure the EPackages are registered by the
> CDOViewProvider when unknown in the code below. (Note: The EPackages are created from the .ecore file and added to the
> resource set). However the CDO packageRegistry will report the nsURI is already a known key, so adding is not allowed.
> Thank You!
> Christophe
> Exception:
> So now I am slightly confused, why will I get the exception below, while the CDO Package registry reports it knows the
> nsURI?
> With this the Exception is gone, but later on I get a commit exception, NPE on a missing EPackage. (I will report this
> Exception if needed later on).
> org.eclipse.emf.cdo.common.util.CDOException: Generated packages locally not available:
> CDOPackageUnit[id=http://www.netxforge.com/13042011/generics, state=PROXY, type=UNKNOWN, originalType=NATIVE,
> timeStamp=2012-04-19 15:47:22.133]
> at org.eclipse.emf.internal.cdo.session.CDOSessionImpl.loadPackages(CDOSessionImpl.java:559)
> at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl.load(CDOPackageUnitImpl.java:239)
> at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl.load(CDOPackageUnitImpl.java:228)
> at org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl.getEPackage(CDOPackageInfoImpl.java:116)
> at org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl.getEPackage(CDOPackageInfoImpl.java:109)
> at org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage(EPackageRegistryImpl.java:127)
> at org.eclipse.emf.cdo.common.model.CDOClassifierRef.resolve(CDOClassifierRef.java:113)
> at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOClassifierRefAndResolve(CDODataInputImpl.java:170)
> at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.readSystemValues(BaseCDORevision.java:186)
> at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.read(BaseCDORevision.java:160)
> at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDORevision(CDODataInputImpl.java:427)
> at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDORevision(CDODataInputImpl.java:418)
> at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.readRevision(RevisionInfo.java:226)
> at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.readResult(RevisionInfo.java:165)
> at org.eclipse.emf.cdo.internal.net4j.protocol.LoadRevisionsRequest.confirming(LoadRevisionsRequest.java:143)
> at org.eclipse.emf.cdo.internal.net4j.protocol.LoadRevisionsRequest.confirming(LoadRevisionsRequest.java:1)
> at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequest.confirming(CDOClientRequest.java:97)
> at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
> at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
> at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:442)
> at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
> at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
> at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:502)
> at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:535)
> at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.loadRevisions(CDOClientProtocol.java:172)
> at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.loadRevisions(CDORevisionManagerImpl.java:387)
> at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevisions(CDORevisionManagerImpl.java:292)
> at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevision(CDORevisionManagerImpl.java:275)
> at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevision(CDORevisionManagerImpl.java:268)
> at org.eclipse.emf.internal.cdo.view.CDOViewImpl.getRevision(CDOViewImpl.java:729)
> at org.eclipse.emf.internal.cdo.view.AbstractCDOView.createObject(AbstractCDOView.java:1094)
> at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getObject(AbstractCDOView.java:993)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.getObject(CDOTransactionImpl.java:1152)
> at org.eclipse.emf.internal.cdo.view.AbstractCDOView.convertIDToObject(AbstractCDOView.java:1327)
> at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertIDToObject(CDOStoreImpl.java:691)
> at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertToEMF(CDOStoreImpl.java:659)
> at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.get(CDOStoreImpl.java:191)
> at org.eclipse.emf.ecore.impl.EStoreEObjectImpl$BasicEStoreEList.delegateGet(EStoreEObjectImpl.java:241)
> at org.eclipse.emf.common.util.DelegatingEList.get(DelegatingEList.java:230)
> at org.eclipse.emf.common.util.AbstractEList$EIterator.doNext(AbstractEList.java:703)
> at org.eclipse.emf.common.util.AbstractEList$EIterator.next(AbstractEList.java:690)
> at org.eclipse.emf.edapt.common.ResourceUtils.resolveAll(ResourceUtils.java:289)
> at org.eclipse.emf.edapt.common.ResourceUtils.loadResourceSet(ResourceUtils.java:106)
> at org.eclipse.emf.edapt.cdo.migration.execution.CDOPersistency.loadModel(CDOPersistency.java:63)
> at
> at
> at
> at
> at
> at
> at org.eclipse.emf.edapt.cdo.migration.execution.CDOMigrator.migrate(CDOMigrator.java:365)
> at org.eclipse.emf.edapt.cdo.migration.execution.CDOMigrator.migrateAndCopy(CDOMigrator.java:269)
> at org.eclipse.emf.edapt.cdo.tests.CDOMigrationTestBase.testMigration(CDOMigrationTestBase.java:183)
> at org.eclipse.emf.edapt.cdo.tests.CDOMigrationTestCase.testMigration(CDOMigrationTestCase.java:73)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at org.eclipse.emf.edapt.cdo.tests.CDOMigrationTestSuite.run(CDOMigrationTestSuite.java:80)
> at org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38ClassRunner.java:84)
> at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
> at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
> at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
> at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
> at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
> at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
| Re: [CDO] loading resources and package registration. [message #1227530 is a reply to message #1227482] |
Sat, 04 January 2014 15:20   |
On 04-01-14 18:19, Eike Stepper wrote:
> Hi Christophe,
Sorry about being vague,
How do I interpret 'original' and 'current'? Is this in relation to the
Session which 'was' and 'is' used?
My question boils down to this, I want to work with a repo which has
NATIVE packages, but.... I don't have the NATIVE package. (assume, I
don't have the .genmodel which was migrated to CDO and used to generated
native CDO code). So I can't do MYPACKAGE.eInstance to retrieve it, add
it to GlobalRepo or put in the CDO package registry. So which options do
I have? (besides setGeneratedPackageEmulationEnabled(true))
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Hi (Eike),
>> Repo1 (source)
>> - Native packages
>> Repo2 (target)
>> - Empty
>> native EPackages are not registered by the platform. (The generated
>> the EPackages are registered by the CDOViewProvider when unknown in
>> and added to the resource set). However the CDO packageRegistry will
>> Thank You!
>> Christophe
>> Exception:
>> while the CDO Package registry reports it knows the nsURI?
>> exception, NPE on a missing EPackage. (I will report this Exception if
>> needed later on).
>> 15:47:22.133]
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
| Re: [CDO] loading resources and package registration. [message #1227679 is a reply to message #1227530] |
Sun, 05 January 2014 02:55   |
Am 04.01.2014 21:20, schrieb Christophe Bouhier:
>> Hi Christophe,
Sorry, I should have been clearer. The "original type" of a model is the type it had in the client that committed this
model originally (and at the time of that commit). The (current) type of a model is the type that's currently valid in a
client. The type can change when generated packages come and go.
> Is this in relation to the Session which 'was' and 'is' used?
> My question boils down to this, I want to work with a repo which has NATIVE packages, but.... I don't have the NATIVE
> package. (assume, I don't have the .genmodel which was migrated to CDO and used to generated native CDO code). So I
> can't do MYPACKAGE.eInstance to retrieve it, add it to GlobalRepo or put in the CDO package registry. So which options
> do I have? (besides setGeneratedPackageEmulationEnabled(true))
Why besides? I think that setGeneratedPackageEmulationEnabled(true) is the way to go. The general behaviour is the
following:
When a CDOSession is opened the server sends a list of all registered nsURIs, or more exactly a list of CDOPackageInfos,
which are then put as EPackage.Registry.Descriptors into the session's package registry. When their EPackages are needed
they're are resolved. That means that first an attempt is made to "load" them from the global package registry. If that
fails and GeneratedPackageEmulationEnabled==true the XMI of that package is loaded from the server and used to emulate
the originally generated package.
Cheers
/Eike
>> Cheers
>> /Eike
>>> Hi (Eike),
>>> Repo1 (source)
>>> - Native packages
>>> Repo2 (target)
>>> - Empty
>>> Thank You!
>>> Christophe
>>> Exception:
>>> needed later on).
>>> 15:47:22.133]
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
| Re: [CDO] loading resources and package registration. [message #1227851 is a reply to message #1227679] |
Sun, 05 January 2014 15:29   |
>>> Hi Christophe,
> type it had in the client that committed this model originally (and at
> that's currently valid in a client. The type can change when generated
>> generated native CDO code). So I can't do MYPACKAGE.eInstance to
>> So which options do I have? (besides
> the way to go. The general behaviour is the following:
Ok, when I turn it on it all resolves, so it seems to work.
I get another Exception when commiting the resource to the target repo.
though. I am not sure this exception is related. It seems the ePackage
is not set in a Package unit. I did call:
session.getPackageRegistry().putEPackage(packageToAdd);
....before trying to commit the resource.
From the server trace (further down below) , I see it tries to register
the evolved EPackage as a Dynamic package.. but failing with the
exception.
To summarize:
Edapt <-- Source repo with Native Packages, read Resource A.
| (EPackage and model transformation).
V
Edapt --> Target repo with Dynamic evolved EPackage write resource A.
(Evolved EPackages are registered on the target repo).
org.eclipse.net4j.util.transaction.TransactionException:
org.eclipse.emf.cdo.util.CommitException:
org.eclipse.net4j.signal.RemoteException: java.lang.NullPointerException
org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.save(CDOResourceImpl.java:1222)
org.eclipse.emf.edapt.common.ResourceUtils.saveResourceSet(ResourceUtils.java:202)
org.eclipse.emf.edapt.cdo.migration.execution.CDOPersistency.saveModel(CDOPersistency.java:52)
org.eclipse.emf.edapt.cdo.migration.execution.CDOMigrator.migrateAndCopy(CDOMigrator.java:276)
Caused by: org.eclipse.emf.cdo.util.CommitException:
org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commitSynced(CDOTransactionImpl.java:1237)
org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1184)
org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.save(CDOResourceImpl.java:1218)
... 27 more
Caused by: org.eclipse.net4j.signal.RemoteException:
org.eclipse.net4j.signal.RequestWithConfirmation.getRemoteException(RequestWithConfirmation.java:141)
org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteException(RequestWithConfirmation.java:130)
org.eclipse.net4j.signal.SignalProtocol.handleRemoteException(SignalProtocol.java:465)
org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:66)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:57)
at org.eclipse.net4j.signal.Indication.execute(Indication.java:51)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
Caused by: java.lang.NullPointerException
org.eclipse.emf.cdo.internal.server.TransactionCommitContext$TransactionPackageRegistry.putPackageUnit(TransactionCommitContext.java:1445)
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:149)
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:99)
org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:110)
org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:87)
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:92)
org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:66)
... 5 more
Server trace:
net4j-Thread-32 [debug.buffer] Retaining Buffer@51[RELEASED]
net4j-Thread-32 [debug.buffer] Retaining Buffer@52[RELEASED]
net4j-Thread-32 [debug.buffer] Retaining Buffer@53[RELEASED]
net4j-Thread-32 [debug.buffer] Retaining Buffer@54[RELEASED]
net4j-Thread-32 [debug] Read
CDOPackageInfo[packageURI=http://www.netxforge.com/16042013/generics,
parentURI=null]
CDOPackageUnit[id=http://www.netxforge.com/16042013/generics,
state=LOADED, type=DYNAMIC, originalType=DYNAMIC, timeStamp=*]
[ERROR] NullPointerException
> nsURIs, or more exactly a list of CDOPackageInfos, which are then put as
> their EPackages are needed they're are resolved. That means that first
> that fails and GeneratedPackageEmulationEnabled==true the XMI of that
> package is loaded from the server and used to emulate the originally
> generated package.
> Cheers
> /Eike
>>> Cheers
>>> /Eike
>>>> Hi (Eike),
>>>> Repo1 (source)
>>>> - Native packages
>>>> Repo2 (target)
>>>> - Empty
>>>> Thank You!
>>>> Christophe
>>>> Exception:
>>>> needed later on).
>>>> 15:47:22.133]
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
| Re: [CDO] loading resources and package registration. [message #1228035 is a reply to message #1227851] |
Mon, 06 January 2014 03:54   |
Am 05.01.2014 21:29, schrieb Christophe Bouhier:
> I get another Exception when commiting the resource to the target repo. though. I am not sure this exception is
> related. It seems the ePackage is not set in a Package unit. I did call:
What type does this packageToAdd have and where does it come from?
> From the server trace (further down below) , I see it tries to register the evolved EPackage as a Dynamic package..
> but failing with the exception.
> To summarize:
> V
I would try to read the old model with dynamic (also NATIVE!) packages and write to the target repo with the generated
evolved packages. Can you try that?
Cheers
/Eike
> org.eclipse.net4j.util.transaction.TransactionException: org.eclipse.emf.cdo.util.CommitException:
> at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.save(CDOResourceImpl.java:1222)
> at org.eclipse.emf.edapt.common.ResourceUtils.saveResourceSet(ResourceUtils.java:202)
> at org.eclipse.emf.edapt.cdo.migration.execution.CDOPersistency.saveModel(CDOPersistency.java:52)
> at org.eclipse.emf.edapt.cdo.migration.execution.CDOMigrator.migrateAndCopy(CDOMigrator.java:276)
> Caused by: org.eclipse.emf.cdo.util.CommitException: org.eclipse.net4j.signal.RemoteException:
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commitSynced(CDOTransactionImpl.java:1237)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1184)
> at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.save(CDOResourceImpl.java:1218)
> ... 27 more
> Caused by: org.eclipse.net4j.signal.RemoteException: java.lang.NullPointerException
> at org.eclipse.net4j.signal.RequestWithConfirmation.getRemoteException(RequestWithConfirmation.java:141)
> at org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteException(RequestWithConfirmation.java:130)
> at org.eclipse.net4j.signal.SignalProtocol.handleRemoteException(SignalProtocol.java:465)
> at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:66)
> at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
> at
> at
> at
> at
> at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:87)
> at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:92)
> at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:66)
> ... 5 more
> Server trace:
> net4j-Thread-32 [debug] Read CDOPackageInfo[packageURI=http://www.netxforge.com/16042013/generics, parentURI=null]
> net4j-Thread-32 [debug] Read CDOPackageUnit[id=http://www.netxforge.com/16042013/generics, state=LOADED, type=DYNAMIC,
> at
> at
> at
> at
>> generated package.
>> Cheers
>> /Eike
>>>> Cheers
>>>> /Eike
>>>>> Hi (Eike),
>>>>> Repo1 (source)
>>>>> - Native packages
>>>>> Repo2 (target)
>>>>> - Empty
>>>>> Thank You!
>>>>> Christophe
>>>>> Exception:
>>>>> needed later on).
>>>>> 15:47:22.133]
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
| Re: [CDO] loading resources and package registration. [message #1228093 is a reply to message #1228035] |
Mon, 06 January 2014 06:48   |
Hi Eike,
See inline response below.
Cheers Christophe
ps. As discussed earlier, the scenario I am testing is only one of the
two envisaged 'solutions'. Scenario 2 is apply a History on the DBStore
directly. I would like to discuss scenario 2as well. Perhaps not in the
forum...
>> repo. though. I am not sure this exception is related. It seems the
Ok, this package is the evolved EPackage. It is created by Edapt when
walking the history. The first release of an Edapt history is considered
to be the base EPackage, then following releases modify this EPackage.
It's important to understand, that during these migrations, code is not
generated. (So the Native packages are not available).
I blogged about how this works here:
http://modelmoo.blogspot.nl/2013/12/how-edapt-works.html
>> register the evolved EPackage as a Dynamic package.. but failing with
>> the exception.
>> To summarize:
>> V
> and write to the target repo with the generated evolved packages. Can
> you try that?
I can likely load with the NATIVE packages, but writing with NATIVE is
going to be tricky. In the Edapt evolution, code is not generated based
on the new EPackage. BTW this scenario works well:
Regular XMI Resource --> Source repo with Dynamic EPackage, write
Resource A.
V
Edapt <-- Source repo with Dynamic EPackage, read Resource A.
V
> Cheers
> /Eike
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 27 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 5 more
>> Server trace:
>> parentURI=null]
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> generated package.
>>> Cheers
>>> /Eike
>>>>> say.
>>>>> Cheers
>>>>> /Eike
>>>>>> Hi (Eike),
>>>>>> help
>>>>>> Repo1 (source)
>>>>>> - Native packages
>>>>>> Repo2 (target)
>>>>>> - Empty
>>>>>> case).
>>>>>> Thank You!
>>>>>> Christophe
>>>>>> Exception:
>>>>>> Exception if
>>>>>> needed later on).
>>>>>> 15:47:22.133]
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
| Re: [CDO] loading resources and package registration. [message #1228111 is a reply to message #1228093] |
Mon, 06 January 2014 07:42   |
Am 06.01.2014 12:48, schrieb Christophe Bouhier:
> Ok, this package is the evolved EPackage. It is created by Edapt when walking the history. The first release of an
> Edapt history is considered to be the base EPackage, then following releases modify this EPackage. It's important to
> understand, that during these migrations, code is not generated.
Why not? The clients will use exactly that generated package to work with the repo.
Cheers
/Eike
>>> the exception.
>>> To summarize:
>>> V
>> you try that?
> I can likely load with the NATIVE packages, but writing with NATIVE is going to be tricky. In the Edapt evolution,
> code is not generated based on the new EPackage. BTW this scenario works well:
> Regular XMI Resource --> Source repo with Dynamic EPackage, write Resource A.
> V
> V
>> Cheers
>> /Eike
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 27 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 5 more
>>> Server trace:
>>> parentURI=null]
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>> generated package.
>>>> Cheers
>>>> /Eike
>>>>>> say.
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> Hi (Eike),
>>>>>>> help
>>>>>>> Repo1 (source)
>>>>>>> - Native packages
>>>>>>> Repo2 (target)
>>>>>>> - Empty
>>>>>>> case).
>>>>>>> Thank You!
>>>>>>> Christophe
>>>>>>> Exception:
>>>>>>> Exception if
>>>>>>> needed later on).
>>>>>>> 15:47:22.133]
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
| Re: [CDO] loading resources and package registration. [message #1228272 is a reply to message #1228111] |
Mon, 06 January 2014 15:47   |
>> this EPackage. It's important to understand, that during these
> with the repo.
This is just the way Edapt works. Edapt did not envision needing the
generated packages, as they can be constructed from the .ecore. I guess
it would complicate things, considering various Releases of a History,
meaning various code generation cycles for one migration.
> Cheers
> /Eike
>>>> the exception.
>>>> To summarize:
>>>> V
>>> you try that?
>> Resource A.
>> V
>> V
>>> Cheers
>>> /Eike
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 27 more
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 5 more
>>>> Server trace:
>>>> parentURI=null]
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>> put as
>>>>> When
>>>>> generated package.
>>>>> Cheers
>>>>> /Eike
>>>>>>> say.
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> Hi (Eike),
>>>>>>>> help
>>>>>>>> Repo1 (source)
>>>>>>>> - Native packages
>>>>>>>> Repo2 (target)
>>>>>>>> - Empty
>>>>>>>> calling
>>>>>>>> case).
>>>>>>>> file
>>>>>>>> will
>>>>>>>> Thank You!
>>>>>>>> Christophe
>>>>>>>> Exception:
>>>>>>>> Exception if
>>>>>>>> needed later on).
>>>>>>>> 15:47:22.133]
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
Current Time: Wed Nov 05 18:17:01 EST 2025
Powered by FUDForum. Page generated in 0.04792 seconds
