Failed to build the e(fx)clipse Tutorial 5. [message #1227230] |
Fri, 03 January 2014 18:02  |
Hi!
I was trying to get the "Efxclipse/Tutorials/Tutorial5" tutorial working. I followed the instructions, with one exception: I am using Java 7 instead of Java 8.
When it comes to step 13, the following error occurs after executing the Ant task:
Buildfile: /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/robovm-ant.xml
setup-staging-area:
[delete] Deleting directory /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/externalLibs
[delete] Deleting directory /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/project
[delete] Deleting directory /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/projectRefs
[mkdir] Created dir: /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/externalLibs
[copy] Copying 1 file to /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/externalLibs
[mkdir] Created dir: /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/project
[copy] Copying 5 files to /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/project
[mkdir] Created dir: /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/projectRefs
[copy] Copying 2 files to /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/project/src
do-compile:
[delete] Deleting directory /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/build
[mkdir] Created dir: /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/build/src
[mkdir] Created dir: /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/build/libs
[mkdir] Created dir: /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/build/classes
[copy] Copying 2 files to /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/build/libs
[copy] Copying 7 files to /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/build/src
[javac] Compiling 4 source files to /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/build/classes
[fxml-compiler] Compiling /Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/build/src/application/Sample.fxml
BUILD FAILED
/Users/stefan/Projekte/RoboFX/MyMobileProject/robovm-build/robovm-ant.xml:83: java.lang.NoSuchMethodError: java.lang.reflect.Type.getTypeName()Ljava/lang/String;
Total time: 6 seconds
Unfortunately, I cannot have a look into the FXMLCompileTask, so any help is kindly appreciated. Thanks!!!
Stefan
Re: Failed to build the e(fx)clipse Tutorial 5. [message #1228113 is a reply to message #1227396] |
Mon, 06 January 2014 07:43  |
Thanks for the follow up - I've updated the wiki to state that both
JDK7u45 and JDK8beta are needed.
Tom
On 04.01.14 12:08, Stefan Hennig wrote:
> I was able to get the tutorial working by using Java JDK 8.
> Thanks, Tom, for this hint (via twitter).
> Cheers,
> Stefan
FUDForum. Page generated in 0.04205 seconds
