Home » Eclipse Projects » GEF » Drag and drop an EditPart
Drag and drop an EditPart [message #199718] Tue, 18 October 2005 11:32 Go to next message
Originally posted by: prashanto.chatterjee.softwareag.com
Hi All,
I am trying to drag an object(ServiceEditPart) with the following edit
policy:
protected void createEditPolicies() {
installEditPolicy(EditPolicy.COMPONENT_ROLE, new
StandardGUIAppComponentEditPolicy());
into a different editor altogether.
Now this particular object sits inside a section(ServiceSectionEditPart)
that has the following editpolicy:
installEditPolicy(EditPolicy.LAYOUT_ROLE, new LayoutEditPolicy(){
protected EditPolicy createChildEditPolicy(EditPart child) {
// TODO Auto-generated method stub
return null;
protected Command getCreateCommand(CreateRequest request) {
Object newType = request.getNewObjectType();
if(newType == Service.class){
ServiceAddCommand singlePageCommand = new
ServiceAddCommand((Shape)request.getNewObject(),
(ServiceSection)getHost().getModel(), new Rectangle(0, 0, 80, 64));
return singlePageCommand;
}else{
return null;
protected Command getDeleteDependantCommand(Request request) {
return null;
protected Command getMoveChildrenCommand(Request request) {
return null;
I can assume that I require another policy:
installEditPolicy(EditPolicy.PRIMARY_DRAG_ROLE, new
NonResizableEditPolicy());
to allow drag (Plz correct me if I am wrong).
Now I have the following questions:
1. Can I have edit-policies that allow dragging across editors?
2. If yes then which editpolicy do I use for the drag-source and the
drag-target?
Appreciate any help in this regard,
Prashanto Chatterjee
Re: Drag and drop an EditPart [message #199733 is a reply to message #199718] Tue, 18 October 2005 17:08 Go to previous messageGo to next message
You must use native Drag-and-Drop to drag from one Canvas to another SWT
control or another application.
See TransferDragSourceListener.
"Prashanto" <prashanto.chatterjee@softwareag.com> wrote in message
news:a8456d407d00397361c54f28d2aca934$1@www.eclipse.org...
> Hi All,
> policy:
> return null;
> }else{
> return null;
> return null;
> return null;
> }); installEditPolicy(EditPolicy.COMPONENT_ROLE, new
> drag-target?
Re: Drag and drop an EditPart [message #199795 is a reply to message #199733] Wed, 19 October 2005 07:17 Go to previous message
Your suggestion worked. Thanks a lot.
I actually based my TransferDragSourceListener to something similar to
TemplateTransferDragSourceLIstener as follows:
private class ServiceDragSourceListener implements
TransferDragSourceListener {
private EditPartViewer viewer;
private Transfer transfer;
ServiceDragSourceListener(EditPartViewer p_viewer, Transfer p_transfer){
this.viewer = p_viewer;
this.transfer = p_transfer;
public Transfer getTransfer() {
return this.transfer;
public void dragStart(DragSourceEvent event) {
Object template = getTemplate();
if (template == null)
event.doit = false;
TemplateTransfer.getInstance().setTemplate(template);
public void dragSetData(DragSourceEvent event) {
event.data = getTemplate();
public void dragFinished(DragSourceEvent event) {
TemplateTransfer.getInstance().setTemplate(null);
* A helper method that returns <code>null</code> or the <i>template</i>
Object from the
* currently selected EditPart.
* @return the template
protected Object getTemplate() {
return ((Service)(ServiceEditPart.this.getModel())).getClass();
and there I had a perfectly working code.
Thanks once again. Kudos to you guys that we, who are new to GEF, are
getting such wonderful support.
Hoping to trouble you again with more queries,
Previous Topic:How to display the figure's location when it moving
Next Topic:How to add Legend to GEF Layer
Current Time: Sat Jul 26 10:37:08 EDT 2025
Powered by FUDForum. Page generated in 0.03428 seconds
