Home » Language IDEs » Java Development Tools (JDT) » Headless feature export
Headless feature export [message #199675] Tue, 29 March 2005 09:48 Go to next message
Originally posted by: test.feiner-fug.net
today i tried to export a feature. To do this i used
org.eclipse.ant.core.antRunner and the following build file:
<project name="build"
default="feature_export"
basedir="D:\\Kalypso/KalypsoFeature"
<target name="feature_export">
<eclipse.buildScript elements="feature@org.kalypso.enterprise"
install="D:/Kalypso/KalypsoFeature"
children="true"
recursivegeneration="true"
</target>
</project>
But when i started the build, i got the Output you can see below.
What wents wrong? The the Feature.xml is correct and the Feature is in the
given location.
Thanks for your help!
Greets
Gregor
D:\Kalypso\KlaypsoBuild>java -cp C:\programme\eclipse3.0\startup.jar
org.eclipse.core.launcher.Main -application org.eclipse.ant.core.antRunner
-buildfile build.xml -debug
Install location:
file:/c:/Programme/eclipse3.0/
Configuration file:
file:/c:/Programme/eclipse3.0/configuration/config.ini loaded
Configuration location:
Configuration file:
Framework located:
file:/c:/Programme/eclipse3.0/plugins/org.eclipse.osgi_3.0.1 /
Loading framework classpath from:
file:/c:/Programme/eclipse3.0/plugins/org.eclipse.osgi_3.0.1 /eclipse.properties
Framework classpath:
file:/c:/Programme/eclipse3.0/plugins/org.eclipse.osgi_3.0.1 /core.jar
file:/c:/Programme/eclipse3.0/plugins/org.eclipse.osgi_3.0.1 /console.jar
file:/c:/Programme/eclipse3.0/plugins/org.eclipse.osgi_3.0.1 /osgi.jar
file:/c:/Programme/eclipse3.0/plugins/org.eclipse.osgi_3.0.1 /resolver.jar
file:/c:/Programme/eclipse3.0/plugins/org.eclipse.osgi_3.0.1 /defaultAdaptor.jar
file:/c:/Programme/eclipse3.0/plugins/org.eclipse.osgi_3.0.1 /eclipseAdaptor.jar
Debug options:
file:/D:/Kalypso/KlaypsoBuild/.options not found
Time to load bundles: 170
Starting application: 3074
Apache Ant version 1.6.2 compiled on July 16 2004
Setting ro project property: ant.file -> build.xml
Buildfile: build.xml
+Datatype eclipse.convertPath org.eclipse.core.resources.ant.ConvertPath
+Datatype eclipse.incrementalBuild
org.eclipse.core.resources.ant.IncrementalBuild
+Datatype eclipse.refreshLocal
org.eclipse.core.resources.ant.RefreshLocalTask
+Datatype eclipse.checkDebugAttributes
org.eclipse.jdt.core.CheckDebugAttributes
+Datatype eclipse.fetch org.eclipse.pde.internal.build.tasks.FetchTask
+Datatype eclipse.buildScript
org.eclipse.pde.internal.build.tasks.BuildScriptGeneratorTas k
+Datatype eclipse.buildManifest
org.eclipse.pde.internal.build.tasks.BuildManifestTask
+Datatype eclipse.assembler
org.eclipse.pde.internal.build.tasks.AssemblerTask
+Datatype eclipse.idReplacer
org.eclipse.pde.internal.build.tasks.IdReplaceTask
+Datatype eclipse.unzipperBuilder
org.eclipse.pde.internal.build.tasks.UnzipperGeneratorTask
+Datatype eclipse.fetchFilesGenerator
org.eclipse.pde.internal.build.tasks.FetchFileGeneratorTask
+Datatype eclipse.versionReplacer
org.eclipse.pde.internal.build.tasks.GenericVersionReplacer
+Datatype pde.exportPlugins
org.eclipse.pde.internal.ui.ant.PluginExportTask
+Datatype pde.exportFeatures
org.eclipse.pde.internal.ui.ant.FeatureExportTask
+Datatype pde.convertSchemaToHTML org.eclipse.pde.ant.ConvertSchemaToHTML
Adding reference: ant.projectHelper
Adding reference: ant.parsing.context
Adding reference: ant.targets
parsing buildfile D:\Kalypso\KlaypsoBuild\build.xml with URI =
file:///D:/Kalypso/KlaypsoBuild/build.xml
Setting ro project property: ant.project.name -> build
Adding reference: build
Setting ro project property: ant.file.build ->
Project base dir set to: D:\Kalypso\KalypsoFeature
+Target:
+Target: feature_export
Build sequence for target `feature_export' is [feature_export]
Complete build sequence is [feature_export, ]
feature_export:
BUILD FAILED
D:\Kalypso\KlaypsoBuild\build.xml:19:
org.eclipse.core.runtime.CoreException: Unable to find feature:
org.kalypso.enterprise.
org.eclipse.pde.internal.build.tasks.BuildScriptGeneratorTas k.execute(BuildScriptGeneratorTask.java:73)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
at org.apache.tools.ant.Task.perform(Task.java:364)
at org.apache.tools.ant.Target.execute(Target.java:341)
at org.apache.tools.ant.Target.performTasks(Target.java:369)
at org.apache.tools.ant.Project.executeTarget(Project.java:1214 )
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:635)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:539)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:488)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Caused by: org.eclipse.core.runtime.CoreException: Unable to find feature:
org.eclipse.pde.internal.build.site.BuildTimeSite.findFeatur e(BuildTimeSite.java:126)
org.eclipse.pde.internal.build.builder.FeatureBuildScriptGen erator.initializeVariables(FeatureBuildScriptGenerator.java: 756)
org.eclipse.pde.internal.build.builder.FeatureBuildScriptGen erator.generate(FeatureBuildScriptGenerator.java:175)
org.eclipse.pde.internal.build.BuildScriptGenerator.generate Features(BuildScriptGenerator.java:125)
org.eclipse.pde.internal.build.BuildScriptGenerator.generate (BuildScriptGenerator.java:62)
org.eclipse.pde.internal.build.tasks.BuildScriptGeneratorTas k.run(BuildScriptGeneratorTask.java:78)
org.eclipse.pde.internal.build.tasks.BuildScriptGeneratorTas k.execute(BuildScriptGeneratorTask.java:71)
... 22 more
--- Nested Exception ---
Total time: 0 seconds
Re: Headless feature export [message #199693 is a reply to message #199675] Tue, 29 March 2005 12:59 Go to previous messageGo to next message
Are the number of slashed correct in the install= line?
"Gregor Weckbecker" <test@feiner-fug.net> wrote in message
news:a66bb12002f83504e8344af652db9fd0$1@www.eclipse.org...
> Hello,
> children="true"
> </target>
> </project>
> given location.
> Greets
> Gregor
> org.eclipse.ant.core.antRunner -buildfile build.xml -debug Install
> location:
> Configuration file:
> Configuration file:
> Framework located:
> Debug options:
> +Target: +Target: feature_export
> feature_export:
> BUILD FAILED
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 22 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Headless feature export [message #199725 is a reply to message #199693] Wed, 30 March 2005 01:06 Go to previous message
Hello!
Yes, i tried it and it didn't work with more, less, other(\) Slashes.
Gregor
Previous Topic:Automating JUnit Plugin Test, returns java result 13
Next Topic:Generic Method override compatibility
Current Time: Wed Oct 22 03:51:44 EDT 2025
Powered by FUDForum. Page generated in 0.04138 seconds
