Re: remember pallete selection ? [message #199481 is a reply to message #199424] |
Wed, 30 July 2008 04:24 |
Originally posted by: lifesting.gmail.com
Jorge wrote:
> Is it possible to remember pallette selection ? If yes, how do we do it ?
> Thanks in advance
Hi, Jorge, try the below test.
1 Open class XXXPaletteFactory in the generated diagram editor plug-in.
XXX is equivalent to the EMF package you used in most time.
2 In the method createYYYTool, YYY is the name of the tool you want to
remember, which is defined in XXX.gmftool, set annotation "generated" to
"generated NOT" and add a statement above the last return, e.g:
* @generated NOT
private ToolEntry createDistrict1CreationTool() {
//Remember tool selection
entry.setToolProperty(AbstractTool.PROPERTY_UNLOAD_WHEN_FINI SHED,
Boolean.TRUE);
return entry;
Re: remember pallete selection ? [message #199487 is a reply to message #199481] |
Wed, 30 July 2008 04:27 |
David BY Chan wrote:
>> Thanks in advance
> * @generated NOT
> Boolean.TRUE);
> return entry;
Sorry, I set the wrong value ,try
Boolean.FALSE);
Re: remember pallete selection ? [message #199704 is a reply to message #199487] |
Thu, 31 July 2008 22:05 |
Shilpa Toraskar Messages: 65 Registered: July 2009 |
Member |
Thanks David. It works !
"David BY Chan" <lifesting@gmail.com> wrote in message
news:g6oqk1$th$2@build.eclipse.org...
>>> Thanks in advance
>> * @generated NOT
>> Boolean.TRUE);
>> return entry;
> Boolean.FALSE);
FUDForum. Page generated in 0.03489 seconds
