Home » Newcomers » Newcomers » Custom Editor with standard Java features
Custom Editor with standard Java features [message #199230] Tue, 13 March 2007 11:53 Go to next message
Originally posted by: sgannon200.hotmail.com
Hi all,
I know this may be a basic question to ask here but I'm fairly desperate.
I've created a custom Eclipse editor and I now want to add the standard
Java features, such as error detection and syntax highlighting, provided
by the Eclipse IDE.
In my mind this should be easy enough to achieve, but I've come to a stand
still.
My editor extends TextEditor and as far as I know all I need is to set the
SourceViewerConfiguration. This has proven difficult.
My code is as follows:
public class PPIMEditor extends TextEditor
private UIAccessor uiAccessor; // My own class which accesses the UI.
public PPIMEditor()
super();
public void createPartControl(final Composite parent)
super.createPartControl(parent);
uiAccessor = new UIAccessor(parent, this);
protected void initializeEditor()
super.initializeEditor();
IPreferenceStore myStore = new PreferenceStore();
JavaTextTools myTools = new JavaTextTools( myStore );
SourceViewerConfiguration myCfg = new
JavaSourceViewerConfiguration(myTools.getColorManager(), myStore, this,
null);
setSourceViewerConfiguration( myCfg );
// Handles a control-z issue, but is not a part of the problem - I think?
protected IOperationApprover getUndoRedoOperationApprover(IUndoContext
undoContext)
approver = new
PPIMOperationApprover(super.getUndoRedoOperationApprover(und oContext));
return approver;
From what I have read I think this should create the editor (but it may
not have the colour highlighting and syntax correction features because of
IPreferenceStore myStore = new PreferenceStore()).
However when I run this application from the testing feature of plugin.xml
I get the following error message:
Unable to create this part due to an internal error. Reason for the
failure: An unexpected exception was thrown.
And after choosing "<<Details":
org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrateg y. <init>(JavaReconcilingStrategy.java:63)
org.eclipse.jdt.internal.ui.text.JavaCompositeReconcilingStr ategy. <init>(JavaCompositeReconcilingStrategy.java:45)
org.eclipse.jdt.ui.text.JavaSourceViewerConfiguration.getRec onciler(JavaSourceViewerConfiguration.java:442)
org.eclipse.jface.text.source.SourceViewer.configure(SourceV iewer.java:353)
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:2553)
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:367)
at editor.PPIMEditor.createPartControl(PPIMEditor.java:84)
In the PPIMEditor the problem is traced to
super.createPartControl(parent);// Source of error
This error is really causing me problems. I don't know why an Eclipse
method such as super.createPartControl should cause this failure.
I also tried to use:
JavaTextTools jTools = JavaPlugin.getDefault().getJavaTextTools();
setSourceViewerConfiguration(new
JavaSourceViewerConfiguration(jTools.getColorManager(),
JavaPlugin.getDefault().getPreferenceStore(), this,
IJavaPartitions.JAVA_PARTITIONING));
but everytime I used JavaPlugin.getDefault().* it gave an error. Is there
some way to initialize JavaPlugin so it will work? Could this be the cause
of the problem?
I'm currently using Eclipse 3.2 and Java 1.5.
Any help would be greatly appreciated as I need this feature to work.
Re: Custom Editor with standard Java features [message #199247 is a reply to message #199230] Tue, 13 March 2007 12:14 Go to previous messageGo to next message
Shane Gannon wrote:
> Hi all,
> standard Java features, such as error detection and syntax
> highlighting, provided by the Eclipse IDE.
> stand still.
> the SourceViewerConfiguration. This has proven difficult.
> public PPIMEditor()
> super();
> this, null);
> think?
> getUndoRedoOperationApprover(IUndoContext undoContext)
> approver = new
> return approver;
> may not have the colour highlighting and syntax correction features
> because of IPreferenceStore myStore = new PreferenceStore()).
> plugin.xml I get the following error message:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
This NPE happens because the JDT UI plug-in wasn't loaded. There are
various reasons for that:
- you missed to declare it as required
- you are not launching as Eclipse Application but a normal Java Application
- some other issue
Dani
> there some way to initialize JavaPlugin so it will work? Could this be
> the cause of the problem?
Re: Custom Editor with standard Java features [message #199385 is a reply to message #199247] Wed, 14 March 2007 07:19 Go to previous messageGo to next message
Application
- some other issue
Dani
Hi Daniel
You were right. I had "org.eclipse.jdt.ui" declared in plugin.xml on the
Runtime - Classpath section, when it should really have been declared in
Dependencies - Required Plug-ins.
Thank you, this problem has bugged me for weeks.
For anybody else interested in getting their editor to use the standard
Java features you can use:
as the previous code will not provide error correction and syntax
highlighting.
Re: Custom Editor with standard Java features [message #1050685 is a reply to message #199385] Sat, 27 April 2013 11:35 Go to previous message
Hi Shane,
I am trying to do the same thing as you have described. I have a custom text editor that I have written ( which extends the TextEditor class ), and wanted to get the standard java features (syntax highlighting, error correction etc.) from JDT.
I tried it the way you indicated in your above post, but no success there. Can you provide me with some more detailed steps or some sample code.
Thanks!
Previous Topic:How to "finalize" a project
Next Topic:Problem with Whitespaces / MacOSX (Illegal Character)
Current Time: Thu Nov 06 21:16:38 EST 2025
Powered by FUDForum. Page generated in 0.09546 seconds
