Home » Language IDEs » ServerTools (WTP) » cleaning deployment
cleaning deployment [message #198981] Mon, 27 August 2007 09:10 Go to next message
Originally posted by: adam.hardy.no.spam.cyberspaceroad.spam
What does the 'Clean' option on the WTP server view context menu do?
I thought it would clean out the deployment from the webserver for my webapp
(and possibly redeploy).
Adam
Re: cleaning deployment [message #198987 is a reply to message #198981] Mon, 27 August 2007 11:04 Go to previous messageGo to next message
Normally the publish operation will try to avoid copying project files
that have already been copied to the server and haven't changed since
the last publish. The "Clean..." command will delete cached information
used to determine what has previously been copied to that server. This
will cause the next publish to copy all files for all projects on that
server.
Larry
> webapp (and possibly redeploy).
> Thanks
> Adam
Re: cleaning deployment [message #199003 is a reply to message #198987] Mon, 27 August 2007 11:46 Go to previous messageGo to next message
Larry, thanks for the info. Is this on a FAQ or wiki or help somewhere? If not,
it should be - I'd be happy to add to a wiki or something.
> server.
> Cheers,
> Larry
>> Thanks
>> Adam
Re: cleaning deployment [message #199040 is a reply to message #199003] Tue, 28 August 2007 08:51 Go to previous message
You might open a Bugzilla enhancement request for some F1 help for the
dialog or suggest clearer explanation for the dialog text. That would
be the easiest for the user to find.
Larry
> If not, it should be - I'd be happy to add to a wiki or something.
>> information used to determine what has previously been copied to that
>> server. This will cause the next publish to copy all files for all
>> projects on that server.
>> Cheers,
>> Larry
>>> Thanks
>>> Adam
Previous Topic:Exploded EAR / hot swapping
Next Topic:Beginner problem with develoing an EAR
Current Time: Sun Nov 09 01:20:08 EST 2025
Powered by FUDForum. Page generated in 0.24203 seconds
