Home » Eclipse Projects » GEF » Access restriction error EMF classes in GEF example projects
Access restriction error EMF classes in GEF example projects [message #198778] Wed, 12 October 2005 13:19 Go to next message
I start getting wierd errors in the GEF example projects I got from CVS:
Access restriction: The type Notification is not accessible due to
restriction on required library
C:\java\eclipse-3.1\plugins\org.eclipse.emf.common_2.1.0.jar
But I didn't put any restrictions on the EMF plugin. Also if I select Quick
Fix for the error, it takes me to the Java Build Path:Libraries tab in the
the project properties which shows that there are no access rules.
How can I get rid of this error message?
Re: Access restriction error EMF classes in GEF example projects [message #198801 is a reply to message #198778] Wed, 12 October 2005 13:33 Go to previous messageGo to next message
I think this is a bug in the PDE. I've seen this before and usually
restarting eclipse makes it go away.
"Felix L J Mayer" <felix.mayer@objectaid.com> wrote in message
news:dijgi9$b90$1@news.eclipse.org...
> Quick Fix for the error, it takes me to the Java Build Path:Libraries tab
> in the the project properties which shows that there are no access rules.
Re: Access restriction error EMF classes in GEF example projects [message #198821 is a reply to message #198801] Wed, 12 October 2005 15:46 Go to previous message
A restart doesn't fix it, but looks like Eclipse 3.1.1 does.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:dijhco$cbk$1@news.eclipse.org...
Previous Topic:UI conventions
Next Topic:logicdesigner example testsuite available?
Current Time: Thu Nov 06 13:52:12 EST 2025
Powered by FUDForum. Page generated in 0.03521 seconds
