Home » Modeling » EMF » [XCore] extending XCore
[XCore] extending XCore [message #1223428] |
Mon, 23 December 2013 10:56 |
Joel Greenyer Messages: 170 Registered: July 2009 |
my idea is to extend XCore and I need some pointers on how to start and what I have to consider.
I've been using XCore and have some knowledge of XText, but I don't know much about XBase and how XCore works exactly.
I sketched my idea in the attached PDF. I want to build a language that I call XSpec. The idea is that developers should be able to model a class model in XCore (see lower part of middle column), but intead of --or in addition to-- implementing the operations in XBase, it should be possible to specify behavior in a sequence diagram fashion (see top part of middle column). This XSpec model should then be translated automatically into an XCore model that consists of (1) Classes that represent the scenarios (2) the class model, which is 1-to-1 the class model as modeled previously. The scenarios classes contain XBase code for executing the scenarios. The details of how that should work are not relevant here.
So, my questions are:
1. Has anybody done anything similar, i.e., extended XCore? Are there any projects that I could have a look at?
2. How do I get started with defining "XSpec"? Do I create a new XText grammar, e.g.
grammar org.example.xspec.XSpec with org.eclipse.emf.ecore.xcore.Xcore
3. If so, how can I specify that a package can contain not only classes, data types, enums, but also "scenarios"?
Is it wise to override the XText rule, e.g.
XClassifier:
XClass |
XDataType |
XEnum |
XScenario
4. How can I extend/hook into/trigger the generator workflow of XCore? I think what I want is, whenever one saves an XSpec, do <translate XSpec->XCore> then <trigger existing XCore generator process>
5. Any recommendations for setting up my development environment to get started?
Sorry for so many nooby questions.
Any pointers on how to get started are welcome!
Best
Joel
Re: [XCore] extending XCore [message #1223466 is a reply to message #1223428] |
Mon, 23 December 2013 13:26 |
Ed Merks Messages: 33142 Registered: July 2009 |
Joel,
Comments below.
On 23/12/2013 11:56 AM, Joel Greenyer wrote:
The incquery folks have done that, but nothing in Xcore is API, so keep
in mind that arbitrary changes can and are likely to appear in the code...
It's not trivial, that's for sure.
Like the incquery guy want derived features to be computed with an
incremental query that then supports notification for the derived
feature just like you get for a normal feature...
Yes, IncQuery. But they literally extend the Xcore grammar to create a
new language, must as Xcore extends Xbase's grammar...
> grammar, e.g.
Yes...
That's more of an Xtext question...
> XClassifier:
> XClass |
> XDataType |
> XEnum |
> XScenario
Yes, that's the general idea...
Xcore's generator really is mostly just EMF's generator, but we have
hooks to compile Xbase's XBlockExpressions into text that are then added
as annotations to the Ecore model so that the normal EMF generator
generates them... If you really need additional files EMF doesn't
normally generate, you'd need to look a generator extensions.
> get started?
Eike has been creating a tool to set up development environments
automatically. Maybe you can figure out how to use it from the wiki:
https://wiki.eclipse.org/Setup-Eclipse
I created a project description for Xtext that will provision a
workspace with all of Xtext and Xcore as source, so that might be a good
starting point for exploration.
> Best
> Joel
Ed Merks
Current Time: Fri Apr 26 07:03:06 GMT 2024
Powered by FUDForum. Page generated in 0.02891 seconds
