Home » Modeling » EMF » [CDO] Can different idGenerationLocations be used on a same server ?
[CDO] Can different idGenerationLocations be used on a same server ? [message #1222388] Fri, 20 December 2013 04:40 Go to next message
Hi everyone,
CDO allows to provide our own strategy for generating CDOIDs (see
http://wiki.eclipse.org/CDO/Server_Configuration_Reference#Property_idGenerationLocation
In case of a migration, it could be very interesting for us to apply the
following strategy:
- Use "STORE" generated CDOIDs
- When we want to migrate, we download the models in xmi files locally
and keep a traceability between CDOID and the corresponding xmiID for
each downloaded element
- We then perform the model migration locally
- We start a new repository with idGenerationLocation="CLIENT"
- We export the migrated models, using the traceability infos to set the
correct CDOID for each element
- We restart a new repository with idGenerationLocation="STORE"
Is this something that could work ? Would the CDO Server be able to work
with a "STORE" idGenerationLocation after this import ?
Alex
Re: [CDO] Can different idGenerationLocations be used on a same server ? [message #1222438 is a reply to message #1222388] Fri, 20 December 2013 07:15 Go to previous messageGo to next message
Am 20.12.2013 10:40, schrieb Alex Lagarde:
> Hi everyone,
> http://wiki.eclipse.org/CDO/Server_Configuration_Reference#Property_idGenerationLocation ).
> In case of a migration, it could be very interesting for us to apply the following strategy:
> - When we want to migrate, we download the models in xmi files locally and keep a traceability between CDOID and the
> corresponding xmiID for each downloaded element
> - We export the migrated models, using the traceability infos to set the correct CDOID for each element
> Is this something that could work ? Would the CDO Server be able to work with a "STORE" idGenerationLocation after
> this import ?
No, it's not possible. The ID generation location value has influence on how (with what data type) the DB columns for
IDs get created. After that point it will lead to failure if you change the original value.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Can different idGenerationLocations be used on a same server ? [message #1231714 is a reply to message #1222438] Wed, 15 January 2014 03:41 Go to previous messageGo to next message
To achieve the same result, would it be possible to customize the ID generator on the server side so it can generate ID based on the traceability informations for migrated elements and fall back to a default generated ID for new elements ?
Stéphane.
Re: [CDO] Can different idGenerationLocations be used on a same server ? [message #1242244 is a reply to message #1231714] Sun, 09 February 2014 02:58 Go to previous message
Am 15.01.2014 09:41, schrieb Stéphane Thibaudeau:
On the server side the ID generation (handling, more generally) has a lot more responsibilities and is always
IStore-specific. The DBStore uses an instance of org.eclipse.emf.cdo.server.db.IIDHandler, typically LongIDHandler to
deal with IDs, meta IDs, external IDs and their column types in the database.
I've not heard of anybody trying it out but in theory you can play with it by changing how
org.eclipse.emf.cdo.server.internal.db.DBStore.doActivate() initializes the ID handler. Currently this is done:
if (idGenerationLocation == IDGenerationLocation.CLIENT)
idHandler = new UUIDHandler(this);
else
idHandler = new LongIDHandler(this);
If your scenario is reasonable and you can make it work in a prototype we can probably introduce an IDHandlerFactory so
that you don't have to fork the whole DBStore.
Cheers
/Eike
Previous Topic:[EMF] [CDO] ConcurrentModificationException when setting setTrackingModification(true)
Next Topic:[CDO] Ecore lazy-loading
Current Time: Mon Nov 10 02:26:47 EST 2025
Powered by FUDForum. Page generated in 0.03816 seconds
