TPTP launcher [message #18896] |
Thu, 02 June 2005 08:09 |
Originally posted by: dev2null.hotmail.com
I'm using Build 3.3.0_20050410_1154 on Windows 2000 with Eclipse 3.0.2.
When starting a runtime workbench from the TPTP profiler launcher the
process seems to run on a system account rather than as the user running
eclipse. Is it possible to run the profiled workbench on the user
account (as the standard eclipse launcher does) ?
/Per
Re: TPTP launcher [message #18960 is a reply to message #18939] |
Thu, 02 June 2005 14:24 |
TPTP runs the workbench on the system account. I need to run the
workbench on my user account.
//Per
Holger Machens wrote:
> Hi Per (Gynt? :P),
> This is interesting, but what do you mean by
> "rather than". Does it run on the user account or not?
> Or how did you realize it?
> Greetings
> Holger
> Per wrote:
>> Hi,
>> running eclipse. Is it possible to run the profiled workbench on the
>> user account (as the standard eclipse launcher does) ?
>> Regards,
>> /Per
Re: TPTP launcher [message #18980 is a reply to message #18960] |
Thu, 02 June 2005 19:44 |
Problem solved simply by running the Agent Contoller under a user account.
//Per
> //Per
>> Hi Per (Gynt? :P),
>> Greetings
>> Holger
>> Per wrote:
>>> Hi,
>>> Regards,
>>> /Per
FUDForum. Page generated in 0.03282 seconds
