Re: Buckminster headless SVN not working (Juno) [message #1220495 is a reply to message #1220466] |
Thu, 12 December 2013 08:18 |
Looks like a bug. Can you run with loglevel DEBUG and get a full stack trace?
- thomas
On 2013-12-12 00:23, Philip Bedingfield wrote:
> I'm trying to setup buckminster headless 4.2 but I can't get svn working.
> Here is my headless ->
> D:\buckminster-headless-4.2-NEW>buckminster listsite
> Features:
> org.eclipse.buckminster.core.headless.feature (%featureName)
> org.eclipse.buckminster.cvs.headless.feature (%featureName)
> org.eclipse.buckminster.pde.headless.feature (%featureName)
> org.eclipse.buckminster.product (%featureName)
> org.eclipse.buckminster.subversive.headless.feature (%featureName)
> org.eclipse.equinox.p2.core.feature (%featureName)
> org.eclipse.equinox.p2.director.feature (%featureName)
> Am I missing something?
> I'm using Jenkins, the out put is ->
> ERROR [0001] : Rejecting provider
> svn(http://{0}:{1}@tmb-s6-buildsrv:81/svn/ssdi/head/ssdi/{2}[http://buck:svn@tmb-s6-buildsrv:81/svn/ssdi/head/ssdi/au.gov.nsw.rms.ssdi.client.releng]):
> No component match was found
> ERROR java.lang.NullPointerException
> Any help much appreciated.
Re: Buckminster headless SVN not working (Juno) [message #1220665 is a reply to message #1220661] |
Fri, 13 December 2013 00:01 |
The message of interest here is probably:
ERROR [0001] : Resolution attempt ended with exception: Provider local(D:/Jenkins/jobs/SSDI
Continuous/workspace/au.gov.nsw.rms.ssdi.client.releng): Missing CSpec source required by component type buckminster
which indiciates that Buckminster was unable to find a buckminster.cspec file at the root of
au.gov.nsw.rms.ssdi.client.releng. Is there such a file? If there is, is it syntactically correct and have required
attributes such as the name and version?
- thomas
On 2013-12-13 00:11, Philip Bedingfield wrote:
> This is with debug on ->
> au.gov.nsw.rms.ssdi.client.releng:buckminster: Using search path svn.ssdi
> au.gov.nsw.rms.ssdi.client.releng:buckminster: Trying provider
> svn(http://{0}:{1}svn_hostname:port/svn/ssdi/head/ssdi/{2}[http://username:password@svn_hostname:port/svn/ssdi/head/ssdi/au.gov.nsw.rms.ssdi.client.releng])
> INFO: System property http.proxyHost is not set but should be proxy-hostname.
> INFO: System property http.proxyPort is not set but should be portnumber.
> au.gov.nsw.rms.ssdi.client.releng:buckminster: trunk/head will be searched
> Listing remote folder http://svn_hostname:port/svn/ssdi/head/ssdi#HEAD
> au.gov.nsw.rms.ssdi.client.releng:buckminster: Rejecting provider
> svn(http://{0}:{1}@svn_hostname:port/svn/ssdi/head/ssdi/{2}[http://username:password@svn_hostname:port/svn/ssdi/head/ssdi/au.gov.nsw.rms.ssdi.client.releng]):
> au.gov.nsw.rms.ssdi.client.releng:buckminster: No provider was found that could resolve the request
> ERROR [0001] : No suitable provider for component au.gov.nsw.rms.ssdi.client.releng:buckminster was found in
> resourceMap file:/D:/Jenkins/jobs/SSDI%20Continuous/workspace/ssdi.rmap
> searchPath localsources
> ERROR Provider local(D:/Jenkins/jobs/SSDI Continuous/workspace/au.gov.nsw.rms.ssdi.client.releng): Missing CSpec
> searchPath eclipse
> ERROR [0001] : Rejecting provider p2({0}[http://tmb-bs-tmis01/targetPlatform/juno]): Components of type
> buckminster are not supported
> searchPath svn.ssdi
> svn(http://{0}:{1}@tmb-s6-buildsrv:81/svn/ssdi/head/ssdi/{2}[http://username:password@svn_hostname:port/svn/ssdi/head/ssdi/au.gov.nsw.rms.ssdi.client.releng]):
> INFO: TAG-ID 0001 = Query for au.gov.nsw.rms.ssdi.client.releng:buckminster
> Doing full workspace refresh
> Waiting for jobs to end
> Build step 'Run Buckminster' marked build as failure
> Archiving artifacts
> An attempt to send an e-mail to empty list of recipients, ignored.
> Notifying upstream projects of job completion
> Finished: FAILURE
Re: Buckminster headless SVN not working (Juno) [message #1220672 is a reply to message #1220665] |
Fri, 13 December 2013 01:46 |
Philip Bedingfield Messages: 43 Registered: August 2011 |
Member |
To answer your question, NO it doesn't exist and neither does the project "D:/Jenkins/jobs/SSDI Continuous/workspace/au.gov.nsw.rms.ssdi.client.releng"
ERROR [0001] : Resolution attempt ended with exception: Provider local(D:/Jenkins/jobs/SSDI Continuous/workspace/au.gov.nsw.rms.ssdi.client.releng): Missing CSpec source required by component type buckminster
So why is it complaining about a missing CSpec?
[Updated on: Fri, 13 December 2013 03:21] Report message to a moderator
Re: Buckminster headless SVN not working (Juno) [message #1220678 is a reply to message #1220672] |
Fri, 13 December 2013 03:12 |
Member |
I've got Jenkins to explicitly checkout releng into "au.gov.nsw.rms.ssdi.client.releng" and now it gets past that point, however it fails on the very next project which is the main feature ->
No materialization found for org.eclipse.help:eclipse.feature/[1.4.1.v20120912-144938-8R7xFOXFLWUl7PpNBh_HIGkb4,1.4.1.v20120912-144938-8R7xFOXFLWUl7PpNBh_HIGkb4]
org.eclipse.ui.views.properties.tabbed:osgi.bundle/[3.5.300.v20120912-132807,3.5.300.v20120912-132807]: Using search path localsources
org.eclipse.help:eclipse.feature/[1.4.1.v20120912-144938-8R7xFOXFLWUl7PpNBh_HIGkb4,1.4.1.v20120912-144938-8R7xFOXFLWUl7PpNBh_HIGkb4]: Trying provider local(workspace)
No open workspace project found that corresponds to org.eclipse.help:eclipse.feature/[1.4.1.v20120912-144938-8R7xFOXFLWUl7PpNBh_HIGkb4,1.4.1.v20120912-144938-8R7xFOXFLWUl7PpNBh_HIGkb4]
ERROR [0002] : No suitable provider for component au.gov.nsw.rms.ssdi.client.product.feature:eclipse.feature was found in resourceMap file:/D:/Jenkins/jobs/SSDITest/workspace/au.gov.nsw.rms.ssdi.client.releng/ssdi.rmap
ERROR [0002] : No suitable provider for component au.gov.nsw.rms.ssdi.client.product.feature:eclipse.feature was found in searchPath localsources
ERROR [0002] : Resolution attempt ended with exception: Provider local(D:/Jenkins/jobs/SSDITest/workspace/au.gov.nsw.rms.ssdi.client.product.feature): Missing CSpec source required by component type eclipse.feature
ERROR Provider local(D:/Jenkins/jobs/SSDITest/workspace/au.gov.nsw.rms.ssdi.client.product.feature): Missing CSpec source required by component type eclipse.feature
ERROR [0002] : No suitable provider for component au.gov.nsw.rms.ssdi.client.product.feature:eclipse.feature was found in searchPath eclipse
ERROR [0002] : Rejecting provider p2({0}[http://tmb-bs-tmis01/targetPlatform/juno]): No component match was found
ERROR [0002] : No suitable provider for component au.gov.nsw.rms.ssdi.client.product.feature:eclipse.feature was found in searchPath svn.ssdi
ERROR [0002] : Rejecting provider svn(http://{0}:{1}@tmb-s6-buildsrv:81/svn/ssdi/head/ssdi/{2}[http://buck:svn@tmb-s6-buildsrv:81/svn/ssdi/head/ssdi/au.gov.nsw.rms.ssdi.client.product.feature]): No component match was found
It's like buckminster expects it to be local. My rmap looks like this ->
<rm:locator searchPathRef="localsources" failOnError="false"/>
<rm:locator searchPathRef="eclipse" failOnError="false"/>
<rm:locator pattern="^jashkel$" searchPathRef="svn.jashkel" />
<rm:locator pattern="^jcodelib$" searchPathRef="svn.jcodelib" />
<rm:locator pattern="^jpdobjectslibrary$" searchPathRef="svn.jpdobjectslibrary" />
<rm:locator pattern="^org.apache.commons$" searchPathRef="svn.tsb.common" />
<rm:locator searchPathRef="svn.ssdi" />
BTW
http://tmb-s6-buildsrv:81/svn/ssdi/head/ssdi/au.gov.nsw.rms.ssdi.client.product.feature/
does exit. I can put it into a browser and it works fine.
[Updated on: Fri, 13 December 2013 03:18] Report message to a moderator
Re: Buckminster headless SVN not working (Juno) [message #1220699 is a reply to message #1220672] |
Fri, 13 December 2013 07:36 |
> But the project "D:/Jenkins/jobs/SSDI Continuous/workspace/au.gov.nsw.rms.ssdi.client.releng" doesn't exist in the
> workspace. So why is it complaining about a missing CSpec?
Because it tries to obtain metadata about the project from its remote location. Does it contain a buckminster.cspec file?
- thomas
Re: Buckminster headless SVN not working (Juno) [message #1220840 is a reply to message #1220699] |
Sat, 14 December 2013 03:32 |
Member |
Thomas Hallgren wrote on Fri, 13 December 2013 02:36On 2013-12-13 02:46, Philip Bedingfield wrote:
- thomas
No the project doesn't exist in that location, so why is it looking for the metadata? Shouldn't it try the next location?
[Updated on: Sat, 14 December 2013 03:33] Report message to a moderator
FUDForum. Page generated in 0.04781 seconds
