Home » Modeling » MoDisco » Running Modisco discoverer programmatically and standalone
Running Modisco discoverer programmatically and standalone [message #1220104] Mon, 09 December 2013 12:54 Go to next message
I evaluating if Modisco is a good tool to deal with my project. I need
to do some checks to a set of Java projects . There are a lot of them
(around 500), and although they are small projects, it is not feasible
to import these projects manually into a running Eclipse environment to
check them.
I was thinking in creating a batch process to do the checking and
generating a report (initially a .txt file) with the results.
My question is: Can I run the Modisco java discoverer from the command
line, without running an Eclipse instance?
Toñi Reina
Re: Running Modisco discoverer programmatically and standalone [message #1221712 is a reply to message #1220104] Wed, 18 December 2013 04:23 Go to previous messageGo to next message
I encourage you to take a look to the Generic Discoverer Benchmark that is available from the MoDisco source code repository (cf. org.eclipse.modisco.infra.discovery.benchmark.*** plugins).
This should help you to elaborate on your own benchmark.
Re: Running Modisco discoverer programmatically and standalone [message #1223182 is a reply to message #1221712] Sun, 22 December 2013 12:35 Go to previous messageGo to next message
I'll take a look, and tell you if I can use it.
El 18/12/2013 10:23, Hugo Bruneliere escribió:
Re: Running Modisco discoverer programmatically and standalone [message #1535505 is a reply to message #1220104] Mon, 29 December 2014 14:10 Go to previous messageGo to next message
In order to run Modisco programatically and from command line, you must create a headless Plugin Project, which is a "lightweight" eclipse instance that can be run without UI.
Re: Running Modisco discoverer programmatically and standalone [message #1691278 is a reply to message #1535505] Sat, 04 April 2015 08:36 Go to previous message
Any progress on that? Any code available? Tutorials?
Previous Topic:Discoverer doesn't set xmi:id
Next Topic:Enumeration Type in MediniQVT
Current Time: Wed Oct 15 04:20:35 EDT 2025
Powered by FUDForum. Page generated in 0.04427 seconds
