Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » EcoreUtil.getURI(feature)(EcoreUtil.getURI(feature) returns an unusable uri)
| EcoreUtil.getURI(feature) [message #1219575] |
Wed, 04 December 2013 12:28  |
All,
I have an EMF document that I'm trying to persist. At one point in the persistence process, a FeatureMap is encountered where we loop through the contained entries to get a uri for each entry:
EStructuralFeature feature = entry.getEStructuralFeature();
EcoreUtil.getURI(feature);
The call to EcoreUtil.getURI(feature) returns a usable uri until a feature that contains embedded XML is encountered. At this point, a uri is returned that starts with "#///DocumentRoot/"<name of embedded xml node>.
Why does this happen?
What I would really like is to get this embedded xml returned as a string. Is there a way of getting this result?
| Re: EcoreUtil.getURI(feature) [message #1219633 is a reply to message #1219620] |
Thu, 05 December 2013 01:04   |
Geoffry,
When processing wildcards, the deserializer is using things like
org.eclipse.emf.ecore.util.ExtendedMetaData.demandFeature(String,
String, boolean) to create a feature and such demand created metadata
has no enclosing resource. You might consider using
org.eclipse.emf.ecore.util.ExtendedMetaData.getNamespace(EStructuralFeature)
in the case that the URI you get from EcoreUtil.getURI returns the empty
URI, but keep in mind that you "find" that feature again, you have to
demand create it again, and for that you need to know if it's an element
or an attribute to call demandFeature with the right arguments.
On 05/12/2013 1:26 AM, Geoffry Roberts wrote:
> Ed,
> Thanks for being so patient. I appreciate it.
> The application stores and EMF document into a document oriented
> database. When it stores data it also stores a uri(s) so the data can
> be retrieved into the proper EMF class(es). When I wrote that
> EcoreUtil.getURI(feature) was returning #///DocumentRoot I called it
> unusable because #///DocumentRoot normalizes into file:///<whatever>,
> which is not a uri for an EMF class. At store time all appears to be
> working, but at retrieval time #///DocumentRoot cannot be interpreted
> successfully and errors ensue. A FileNotFoundException is thrown with
> the message that file:///<whatever> is a directory. I have included
> two examples of usable uris so you see what they look like.
> http://www.eclipse.org/emf/2003/XMLType#//XMLTypeDocumentRoot/text
> http://www.openhealthtools.org/mdht/uml/hl7/datatypes#//EN/given
> Perhaps my question should be why, when processing this embedded xml,
> am I not getting a usable uri?
> Thanks again
| Re: EcoreUtil.getURI(feature) [message #1220086 is a reply to message #1219575] |
Mon, 09 December 2013 10:35   |
Hi Ed,
Geoffry is attempting to use MongoEMF to serialize / deserialize his model. The code in question from MongoEMF is:
protected void buildFeatureMap(DBObject dbObject, EAttribute attribute, Object value)
FeatureMap.Internal featureMap = (FeatureMap.Internal) value;
Iterator<FeatureMap.Entry> iterator = featureMap.basicIterator();
ArrayList<DBObject> dbFeatureMap = new ArrayList<DBObject>();
while (iterator.hasNext())
DBObject dbEntry = new BasicDBObject();
FeatureMap.Entry entry = iterator.next();
dbEntry.put("key", EcoreUtil.getURI(feature).toString()); <<<-------------------- Get the URI here
if (feature instanceof EAttribute)
EDataType eDataType = ((EAttribute) feature).getEAttributeType();
if (!MongoUtils.isNativeType(eDataType))
dbEntry.put("value", convertEMFValueToMongoDBValue(eDataType, entry.getValue()));
else
dbEntry.put("value", entry.getValue());
else
dbEntry.put("value", buildReferencedObject((EReference) feature, (EObject) entry.getValue()));
dbFeatureMap.add(dbEntry);
dbObject.put(attribute.getName(), dbFeatureMap);
Can we improve upon this solution to handle his case generically, or is this something that is model specific?
Bryan
| Re: EcoreUtil.getURI(feature) [message #1220139 is a reply to message #1220086] |
Tue, 10 December 2013 00:14   |
Bryan,
I assume you're using this URI so that later you can use
ResourceSet.getEObject to load the feature again, but this only works if
the feature isn't a demand created one. If it's demand created, you'll
really need to remember the namespace, the name, and whether it's an
element or an attribute, so you can call
org.eclipse.emf.ecore.util.BasicExtendedMetaData.demandFeature(String,
String, boolean) with the appropriate arguments. Note there are even
cases (an xsi:type within a wildcard's feature map's contents) where you
could end up with an EObject whose eClass() is created using
org.eclipse.emf.ecore.util.BasicExtendedMetaData.demandType(String, String).
On 09/12/2013 4:35 PM, Bryan Hunt wrote:
> Hi Ed,
> entry.getValue()));
> else
> else
> Bryan
| Re: EcoreUtil.getURI(feature) [message #1220256 is a reply to message #1220237] |
Tue, 10 December 2013 11:50   |
Geoffry,
Comments below.
On 10/12/2013 3:32 PM, Geoffry Roberts wrote:
> Ed,
> By "demand created" do you mean created at runtime? If so, this is
> not the case in my situation.
Yes it is.
> What I have are XML tags that are embedded within an element but are
> supposed to be treated as a String.
Treated by what?
> This is what the designers (not me) envisioned. As a result, when
> EMF is used to process these documents (a very attractive thing to do
> from a technical standpoint), EMF creates a feature map treating them
> as elements.
Because they are.
> In the corresponding ecore, these embedded elements are not given a
> datatype.
They're instances of AnyType.
> <thinking out loud>I wonder if this problem would go a way if they
> were given a type.
No.
> We have ST, which, in Java, is implemented as String.</thinking out loud>
If you saved such a thing as XML, the things like < would be encoded as
< so they would not be embedded elements, they'd just be a value that
happens to look like XML when it's decoded.
> Thanks
| Re: EcoreUtil.getURI(feature) [message #1220264 is a reply to message #1220256] |
Tue, 10 December 2013 12:56  |
Hi Ed,
Here's the other half of the MongoEMF code ...
protected void buildFeatureMap(DBCollection collection, Resource resource, EObject eObject, EAttribute attribute, List<DBObject> values)
FeatureMap.Internal featureMap = (FeatureMap.Internal) eObject.eGet(attribute);
for (DBObject entry : values)
EStructuralFeature feature = (EStructuralFeature) resource.getResourceSet().getEObject(URI.createURI((String) entry.get("key")), true);
featureMap.add(feature, convertMongoDBValueToEMFValue(eDataType, entry.get("value")));
else
EReference reference = (EReference) feature;
DBObject dbReference = (DBObject) entry.get("value");
EObject target = buildReferencedObject(collection, dbReference, resource, reference.isResolveProxies());
featureMap.add(feature, target);
Current Time: Thu Nov 06 13:52:18 EST 2025
Powered by FUDForum. Page generated in 0.05797 seconds
