Problem with DefinitionLoader since Sapphire 0.7 Build #418 [message #1219488] |
Wed, 04 December 2013 08:25  |
Hazem ELRAFFIEE Messages: 61 Registered: September 2012 |
Member |
Hello All
I've been using Sapphire 0.7 till build #417 with no problems. Starting from build #418, the below stack trace comes when I try to use my MXML Editor to launch my *.mxml files.
My Editor is someway special. I'm following the Contacts/Calendar integrated editor; in order to view my XML file and the appropriate project_xxx.xml file, where xxx is a field in my MXML file.
I've attached my MXMLEditor.java
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at java.util.ArrayList.RangeCheck(ArrayList.java:547)
at java.util.ArrayList.get(ArrayList.java:322)
at org.eclipse.sapphire.ElementList.get(ElementList.java:679)
at org.eclipse.sapphire.ui.forms.WithImpliedPart$1.init(WithImpliedPart.java:83)
at org.eclipse.sapphire.ui.forms.ContainerPart$Children.all(ContainerPart.java:169)
at org.eclipse.sapphire.ui.forms.ContainerPart$Children.refreshVisibleChildren(ContainerPart.java:229)
at org.eclipse.sapphire.ui.forms.ContainerPart$Children.visible(ContainerPart.java:213)
at org.eclipse.sapphire.ui.forms.ContainerPart$1$1.evaluate(ContainerPart.java:78)
at org.eclipse.sapphire.modeling.el.FunctionResult.refresh(FunctionResult.java:271)
at org.eclipse.sapphire.modeling.el.FunctionResult.<init>(FunctionResult.java:94)
at org.eclipse.sapphire.ui.forms.ContainerPart$1$1.<init>(ContainerPart.java:57)
at org.eclipse.sapphire.ui.forms.ContainerPart$1.evaluate(ContainerPart.java:57)
at org.eclipse.sapphire.modeling.el.FunctionResult.initOperands(FunctionResult.java:115)
at org.eclipse.sapphire.modeling.el.FunctionResult.<init>(FunctionResult.java:75)
at org.eclipse.sapphire.modeling.el.FailSafeFunction$1.<init>(FailSafeFunction.java:91)
at org.eclipse.sapphire.modeling.el.FailSafeFunction.evaluate(FailSafeFunction.java:91)
at org.eclipse.sapphire.ui.SapphirePart.initExpression(SapphirePart.java:250)
at org.eclipse.sapphire.ui.SapphirePart.initExpression(SapphirePart.java:230)
at org.eclipse.sapphire.ui.SapphirePart.visible(SapphirePart.java:485)
at org.eclipse.sapphire.ui.forms.ContainerPart$Children.refreshVisibleChildren(ContainerPart.java:231)
at org.eclipse.sapphire.ui.forms.MasterDetailsContentNodePart.computeValidation(MasterDetailsContentNodePart.java:689)
at org.eclipse.sapphire.ui.SapphirePart.refreshValidation(SapphirePart.java:453)
at org.eclipse.sapphire.ui.forms.MasterDetailsContentNodePart.refreshNodes(MasterDetailsContentNodePart.java:663)
at org.eclipse.sapphire.ui.forms.MasterDetailsContentNodePart.init(MasterDetailsContentNodePart.java:287)
at org.eclipse.sapphire.ui.SapphirePart.initialize(SapphirePart.java:206)
at org.eclipse.sapphire.ui.forms.MasterDetailsContentNodePart.init(MasterDetailsContentNodePart.java:271)
at org.eclipse.sapphire.ui.forms.MasterDetailsContentOutline.getRoot(MasterDetailsContentOutline.java:58)
at org.eclipse.sapphire.ui.forms.MasterDetailsEditorPagePart.init(MasterDetailsEditorPagePart.java:57)
at org.eclipse.sapphire.ui.SapphirePart.create(SapphirePart.java:1094)
at org.eclipse.sapphire.ui.forms.swt.SapphireEditorFormPage.<init>(SapphireEditorFormPage.java:68)
at org.eclipse.sapphire.ui.forms.swt.MasterDetailsEditorPage.<init>(MasterDetailsEditorPage.java:218)
at org.eclipse.sapphire.ui.forms.swt.MasterDetailsEditorPage.<init>(MasterDetailsEditorPage.java:210)
at com.home.myself.mxmleditor.ui.MXMLEditor.createFormPages(MXMLEditor.java:145)
at org.eclipse.sapphire.ui.SapphireEditor.addPages(SapphireEditor.java:489)
at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEditor.java:138)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2756)
at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1155)
at org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run(OpenLocalFileAction.java:107)
at org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run(OpenLocalFileAction.java:76)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at com.home.myself.myapp.plugin.MyApplication.start(MyApplication.java:30)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Any ideas why this happens to me?
Note: I've tested my Editor vs. all builds starting from #418 till the latest build. All the same!
[Updated on: Wed, 04 December 2013 08:26] Report message to a moderator
Re: Problem with DefinitionLoader since Sapphire 0.7 Build #418 [message #1219660 is a reply to message #1219654] |
Thu, 05 December 2013 10:28   |
Member |
Here's a complete unique sorted list of all XML Tags inside my SDEF file. Is there any of them that needs to be migrated?
<action-handler>
<action-id>
<action>
<actuator>
<block>
<case>
<child-property>
<collapsed-initially>
<collapsible>
<composite>
<content>
<context>
<default-panel>
<definition>
<description>
<editor-page>
<element-type>
<group>
<height>
<hint>
<horizontal-align>
<id>
<image>
<impl>
<import>
<include>
<key-binding-behavior>
<key-binding>
<label>
<location>
<name>
<node-factory>
<node>
<package>
<page-header-text>
<path>
<property-editor>
<property>
<related-content-width>
<related-content>
<root-node>
<scale-vertically>
<section>
<show-image>
<show-label>
<size>
<spacer>
<span>
<split-form>
<style>
<tooltip>
<value>
<width>
<with>
[Updated on: Thu, 05 December 2013 10:29] Report message to a moderator
FUDForum. Page generated in 0.03006 seconds
