Home » Eclipse Projects » e(fx)clipse » Dialogs in JavaFX(How do I create a dialog in JavaFX/e(fx)clipse?)
Dialogs in JavaFX [message #1219354] Tue, 03 December 2013 08:57 Go to next message
I am experimenting developing an Eclipse 4 application, using JavaFX as the UI toolkit. I have eclipse Kepler and e(fx)clipse installed. I need to be able to display dialogs (modal or modeless) and have not been able to figure out nor find good examples for doing this. Any help would be appreciated.
Re: Dialogs in JavaFX [message #1219359 is a reply to message #1219354] Tue, 03 December 2013 09:15 Go to previous messageGo to next message
There's a bundle named org.eclipse.fx.ui.dialogs and there multi classes:
* Dialog: The base class of the Dialog system
* TitleAreaDialog: Similar to JFace counter part
* MessageDialog: A simple dialog similar to the JFace MessageDialog
* MessageTitleDialog: Similar to above but a subclass of TitleAreaDialog
* PromptInputDialog: I guess the name tells everything
* FontDialog: I guess the name speak for itself
Tom
> appreciated.
Re: Dialogs in JavaFX [message #1219360 is a reply to message #1219359] Tue, 03 December 2013 09:20 Go to previous messageGo to next message
Hmm, I'm missing something in my setup. I have access to many org.eclipse.fx.* packages, but org.eclipse.fx.ui.dialogs is not among them.
Ah ha, there it is!
[Updated on: Tue, 03 December 2013 09:22] by Moderator
Re: Dialogs in JavaFX [message #1219361 is a reply to message #1219360] Tue, 03 December 2013 09:28 Go to previous messageGo to next message
well if you've written e4-javafx applications you have to have it - at
least you stated this over in the e4 forum! The workbench dialogs in
javafx implementation are making use of it.
So how did you managed to create a pure javafx / e4 application? You
should have setup your target platform appropriately.
Tom
Re: Dialogs in JavaFX [message #1219365 is a reply to message #1219359] Tue, 03 December 2013 09:36 Go to previous messageGo to next message
OK, found the FX dialogs package. It was sitting there all along and I had no idea. Embarrassed
Now, for example with the MessageDialog.open... methods, it wants a Window object passed as the parent. How can I obtain a reference to that? Below is an example.
public class MessageViewerPart {
  private MessagePane             msgPane;
  @Inject
  private MessageViewerModel      model;
  @Inject
  private MessageViewerController controller;
  @PostConstruct
  public void init(final MApplication app, BorderPane parent) {
    parent.setPadding(new Insets(5));
    parent.setCenter(createPane());
    bindControls();
  private Node createPane() {
    BorderPane pane = new BorderPane();
    msgPane = new MessagePane();
    pane.setCenter(msgPane);
    pane.setBottom(createControlsPane());
    return pane;
  private Node createControlsPane() {
    HBox pane = new HBox();
    pane.setSpacing(5);
    pane.setAlignment(Pos.CENTER);
    Button navFirstButton = new Button("First");
    pane.getChildren().add(navFirstButton);
    navFirstButton.setOnAction(new EventHandler<ActionEvent>() {
      public void handle(ActionEvent event) {
        MessageDialog.openInformationDialog(<<need Window reference>>, "Title", "Message");
    return pane;
Passing the BorderPane "parent" (injected in the PostContruct method init) did not work.
Re: Dialogs in JavaFX [message #1219366 is a reply to message #1219361] Tue, 03 December 2013 09:37 Go to previous messageGo to next message
I did have to add it to the plugin.xml required plug-ins list.
Re: Dialogs in JavaFX [message #1219369 is a reply to message #1219365] Tue, 03 December 2013 09:45 Go to previous messageGo to next message
window is the base class of stage. You can get it from
node.getScene().getWindow() IIRC or in an e4 context you can do:
class MyPart {
@Inject
Stage stage
Tom
> had no idea. :blush:
> @Inject
> @Inject
> @PostConstruct
> bindControls();
> return pane;
> pane.setSpacing(5);
> @Override
> return pane;
> init) did not work.
Re: Dialogs in JavaFX [message #1219370 is a reply to message #1219366] Tue, 03 December 2013 09:46 Go to previous messageGo to next message
Sure it is not mandatory and you can use any other lib as well so - yes
you need to require it actively.
Tom
Re: Dialogs in JavaFX [message #1219371 is a reply to message #1219369] Tue, 03 December 2013 09:47 Go to previous messageGo to next message
Just out of curiosity, what is IIRC you reference?
Re: Dialogs in JavaFX [message #1219374 is a reply to message #1219359] Tue, 03 December 2013 10:06 Go to previous messageGo to next message
Sweet! It looks like this will do what I need quite nicely. I will do some more experimenting, implementing a more involved dialog, but I don't foresee any problems at this point. Thanks a lot Tom.
Re: Dialogs in JavaFX [message #1219419 is a reply to message #1219371] Tue, 03 December 2013 12:51 Go to previous messageGo to next message
http://www.internetslang.com/IIRC-meaning-definition.asp
Tom
Re: Dialogs in JavaFX [message #1815616 is a reply to message #1219371] Mon, 07 October 2019 05:23 Go to previous message
Joseph Gagnon wrote on Tue, 03 December 2013 14:47
IIRC means "If I Remember Correctly".
Previous Topic:Eclipse + Tycho + Maven + OSGI + Java FX + Java >= 11?
Next Topic:Enable fxml parsing in existing JavaFX/Maven project
Current Time: Thu Nov 06 04:41:05 EST 2025
Powered by FUDForum. Page generated in 0.50139 seconds
