Home » Language IDEs » PHP Development Tools (PDT) » Can't install PDT under Linux (dependency issue)(PDT installation problem.)
Can't install PDT under Linux (dependency issue) [message #1219262] Mon, 02 December 2013 19:42 Go to next message
I'm new to Eclipse and PHP. I'm trying to install Eclipse and PDT as part of my effort to teach myself PHP.
Platform is Linux Mint 13 Maya.
Eclipse installed without issue.
I get this message when tring to install PDT from the "Help -> Install New Software.." menu.
Cannot complete the install because one or more required items could not be found.
Software being installed: PHP Development Tools (PDT) 3.1.2.201212211235 (org.eclipse.php.feature.group 3.1.2.201212211235)
Missing requirement: PDT Server UI Plug-in 3.1.2.201212211235 (org.eclipse.php.server.ui 3.1.2.201212211235) requires 'bundle org.eclipse.dltk.ui [4.0.0,5.0.0)' but it could not be found
Cannot satisfy dependency:
From: PHP Development Tools (PDT) 3.1.2.201212211235 (org.eclipse.php.feature.group 3.1.2.201212211235)
To: org.eclipse.php.server.ui [3.1.2.201212211235]
Any ideas?
Thanks - Pete
Re: Can't install PDT under Linux (dependency issue) [message #1219435 is a reply to message #1219262] Tue, 03 December 2013 15:38 Go to previous messageGo to next message
Update: I just downloaded Eclipse for Windows XP 32 bit and then installed PDT per the instructions. That went fine on that platform. It appears that the problem is limited to the Linux platform.
Re: Can't install PDT under Linux (dependency issue) [message #1219624 is a reply to message #1219435] Wed, 04 December 2013 20:14 Go to previous messageGo to next message
For the installation,
1) Download eclipse 4.3.1(Kepler) from //www.eclipse.org/downloads, extract it, start eclipse.
2) Install PDT thru 'Install New Software' from preconfigured Kepler repository.(//download.eclipse.org/releases/kepler)
That's all. What kind of difficulty is there.
Even if you choosed the eclipse package in Ubuntu repository,(note that it is 3.7.2(Indigo) based)
1) Install eclipse with Software Manager or Package Manager, start eclipse.
2) Install PDT thru 'Install New Software' from preconfigured Indigo repository.(//download.eclipse.org/releases/indigo)
That's all. What kind of difficulty is there. Even though you'll get PDT 3.0.1 in this case.
You are going to install PDT 3.1.2, and it is for/in Eclipse 3.8/4.2(Juno). You need to add Juno repository in 'Available Software Sites'.
If you had installed eclipse from Ubuntu repository and you had added the abandoned update site //download.eclipse.org/tools/pdt/updates/release (in accordance with the abandoned page //www.eclipse.org/pdt/downloads/), you'll encounter this dependency problem. Because it is wrong.
Re: Can't install PDT under Linux (dependency issue) [message #1231039 is a reply to message #1219624] Mon, 13 January 2014 12:19 Go to previous message
Try this http://download.eclipse.org/tools/pdt/updates/3.2-nightly
Previous Topic:Workspace is Self-replicating
Next Topic:add to the Code Assist for PHP Dev Tools?
Current Time: Fri Nov 07 06:48:06 EST 2025
Powered by FUDForum. Page generated in 0.03871 seconds
