Connection creation throws exception [message #1219067] |
Sat, 30 November 2013 17:13  |
Hi all,
I'm developing a GMF editor and I have an annoying problem.
I'm modeling a component based system. This is the hierarchy:
A System contains Composites and Containers.
Containers and Composites can contains AbstractComponents and EndPoints.
Component and Composite are two subclasses of AbstractComponent, which is an abstract class.
Components have input and output ports, which can be connected by means of the class Connection, which holds a reference to an input port and an output port.
Connection are stored in the classes Composite and Container, according to the connected components.
Composite and Container figures have a compartment in which I can insert the components and endpoint figures.
When I launch the editor
- I'm able to create and visualize connection between components created into a composite. The connection is stored in the composite and drawn.
- however when I try to create a connection between ports of components created into a container it throws an exception. Despite the exception the connection is actually created in the model and stored in the container, but it is not drawn in the diagram. Also if I close and reopen the diagram the connection is not visible.
This is the exception:
org.eclipse.core.commands.ExecutionException: While executing the operation, an exception occurred
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:521)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:206)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:169)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:156)
at org.eclipse.gef.tools.AbstractTool.executeCommand(AbstractTool.java:425)
at org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(AbstractTool.java:438)
at org.eclipse.gmf.runtime.diagram.ui.tools.ConnectionCreationTool.handleCreateConnection(ConnectionCreationTool.java:342)
at org.eclipse.gmf.runtime.diagram.ui.tools.ConnectionCreationTool.handleButtonUp(ConnectionCreationTool.java:182)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java:1200)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:301)
at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouseReleased(DomainEventDispatcher.java:380)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(LightweightSystem.java:548)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:220)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4166)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1489)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1474)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1279)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4012)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:failed to create a view
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.gmf.runtime.diagram.ui.commands.CreateCommand.doExecuteWithResult(CreateCommand.java:96)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.gmf.runtime.common.core.command.CompositeCommand.doExecuteWithResult(CompositeCommand.java:403)
at org.eclipse.gmf.runtime.common.core.command.AbstractCommand.execute(AbstractCommand.java:134)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
... 42 more
This is the part of the xml which model the connections between ports:
<links>
<domainMetaElement
href="../models/componentModel.ecore#//Connection"/>
<labelMappings>
<diagramLabel
href="../../xyz/diagrams/componentModels.gmfgraph#SolidWireConnectionName"/>
</labelMappings>
<containmentFeature
href="../models/componentModel.ecore#//Composite/compositeConnections"/>
<tool
xsi:type="gmftool:CreationTool"
href="componentModel.gmftool#//@palette/@tools.1/@tools.1"/>
<diagramLink
href="../../xyz/diagrams/componentModels.gmfgraph#SolidWireConnection"/>
<sourceMetaFeature
xsi:type="ecore:EReference"
href="../models/componentModel.ecore#//Connection/client"/>
<linkMetaFeature
href="../models/componentModel.ecore#//Connection/server"/>
<creationConstraints>
<sourceEnd
body="eContainer().eContainer().oclIsKindOf(Composite)"/>
<targetEnd
</creationConstraints>
</links>
<links>
<domainMetaElement
<labelMappings>
<diagramLabel
</labelMappings>
<containmentFeature
href="../models/componentModel.ecore#//Container/containerConnections"/>
<tool
<diagramLink
<sourceMetaFeature
<linkMetaFeature
<sourceEnd
body="eContainer().eContainer().oclIsKindOf(Container)"/>
<targetEnd
</links>
Please tell me if you need further information. I really don't know what could be and couldn't be useful in the amount of information I have defined for this editor.
Thanks in advance.
[Updated on: Sun, 01 December 2013 10:25] by Moderator
Re: Connection creation throws exception [message #1219304 is a reply to message #1219067] |
Tue, 03 December 2013 04:06  |
Hi all,
I found at that the issue can be resolved by using two different entities for the connections.
In other words, I have defined two specializations of the class Connection and I use them, one for the composite connections and the other for the container connections.
While it works, I don't understand why I have to define two classes for representing the same exact information.
Thanks!
FUDForum. Page generated in 0.04865 seconds
