How to turn ON XInclude support in WTP? [message #197693] |
Tue, 31 July 2007 16:57 |
Originally posted by: farrukh.wellfleetsoftware.com
I am a newbie to eclipse and WTP and have just started using WTP 2.0
all-in-one bundle on Linux.
I am trying to validate a WSDL 1.1 file that has a complex series of
direct and indirect imports of XSD files. The files use the XInclude
mechanism heavily. It appears that XInclude is still not ON by default
in WTP's use of xereces parser (which supports it):
< http://dev.eclipse.org/newslists/news.eclipse.webtools/msg10 048.html>
Since above message was posted a year ago I am hoping that one can turn
on XInclude in WTP 2.0 somehow. If this is still not possible then I
suggest adding a property switch to allow it to be turned ON. I would
gladly be a guinea-pig and try our a patch and report back.
Alternatively, would someone knowledgeable in the code base tell direct
me to appropriate source code and I will get it to work and contribute
the patch back for consideration by dev team.
Thanks for your help on this important issue for my project.
Farrukh
Re: How to turn ON XInclude support in WTP? [message #197711 is a reply to message #197693] |
Tue, 31 July 2007 19:48 |
On a related note, does WTP Schema Validatiuon support <xsd:include> from
XML Schema specification? If not, is there a way to turn this ON since
xerces supports it.
Based on my observations it does not seem to be supported by default in WTP
2.0.
Farrukh
Web: http://www.wellfleetsoftware.com
FUDForum. Page generated in 0.02822 seconds
