Home » Eclipse Projects » e(fx)clipse » org.eclipse.e4.core.di.InjectionException error(org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javafx/embed/swt/FXCanvas)
org.eclipse.e4.core.di.InjectionException error [message #1216906] Thu, 28 November 2013 12:36 Go to next message
Goodmorming,
I use e(fx)eclipse and I try to test this example
When I execute I have this error:
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:861)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:841)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:113)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:321)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:242)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:894)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:629)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:520)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:505)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:74)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:731)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:702)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:696)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:681)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1115)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:641)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:644)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:987)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.NoClassDefFoundError: javafx/embed/swt/FXCanvas
	at at.bestsolution.efxclipse.runtime.workbench3.FXViewPart.createPartControl(FXViewPart.java:25)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:138)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:155)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:313)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	... 99 more
Caused by: java.lang.ClassNotFoundException: javafx.embed.swt.FXCanvas
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:455)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	... 108 more
Please any help will be welcom.
Re: org.eclipse.e4.core.di.InjectionException error [message #1217086 is a reply to message #1216906] Thu, 28 November 2013 14:28 Go to previous messageGo to next message
So the problem is that the Adapter Hooks are not installed. Reading
through i don't see it getting mentionned which clear is a bug in the wiki.
Open the launch configuration and add the following value in VM arguments:
-Dosgi.framework.extensions=org.eclipse.fx.osgi
Then things should start working as advertised! I'll take care to update
the wiki.
Tom
On 28.11.13 19:05, Frederic PAPY wrote:
> Goodmorming,
> http://wiki.eclipse.org/Efxclipse/Tutorials/Tutorial2 When I execute I
> have this error:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> at
> at
> at
> ... 99 more
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 108 more
Re: org.eclipse.e4.core.di.InjectionException error [message #1217480 is a reply to message #1217086] Thu, 28 November 2013 18:29 Go to previous messageGo to next message
Thanks for the reply.
I did what you ask me to do and now this is the new error
!ENTRY org.eclipse.ui 4 4 2013-11-29 00:23:53.845
!MESSAGE Unable to create part
!ENTRY org.eclipse.ui 4 1 2013-11-29 00:23:53.848
!MESSAGE Plug-in "com.vendor.FxRCP" was unable to instantiate class "com.vendor.fxrcp.views.MyViewPart".
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "com.vendor.FxRCP" was unable to instantiate class "com.vendor.fxrcp.views.MyViewPart".
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:62)
	at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:112)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:262)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:299)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.handleEvent(PartRenderingEngine.java:130)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setToBeRendered(UIElementImpl.java:290)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:420)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:389)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:606)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:579)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:549)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:538)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1022)
	at org.eclipse.ui.internal.WorkbenchPage.showPart(WorkbenchPage.java:1171)
	at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1155)
	at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.java:3749)
	at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3746)
	at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3721)
	at org.eclipse.ui.handlers.ShowViewHandler.openView(ShowViewHandler.java:126)
	at org.eclipse.ui.handlers.ShowViewHandler.openOther(ShowViewHandler.java:99)
	at org.eclipse.ui.handlers.ShowViewHandler.execute(ShowViewHandler.java:67)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:231)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:212)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
	at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:515)
	at org.eclipse.ui.internal.ShowViewMenu$3.run(ShowViewMenu.java:141)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
Caused by: java.lang.NoClassDefFoundError: javafx/scene/Node
	at java.lang.Class.getDeclaredConstructors0(Native Method)
	at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
	at java.lang.Class.getConstructor0(Unknown Source)
	at java.lang.Class.newInstance(Unknown Source)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
	... 113 more
Caused by: java.lang.ClassNotFoundException: javafx.scene.Node
	... 118 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2013-11-29 00:23:53.861
!MESSAGE Plug-in "com.ongoladev.FxRCP" was unable to instantiate class "com.ongoladev.fxrcp.views.MyViewPart".
!STACK 0
	... 118 more
once again thanks for tour help
Re: org.eclipse.e4.core.di.InjectionException error [message #1217489 is a reply to message #1217480] Thu, 28 November 2013 18:35 Go to previous messageGo to next message
This means your import in the MANIFEST are not correct! You need to add
package imports for all javafx packages!
Tom
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 113 more
> at
> at
> at
> at
> ... 118 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 118 more
Re: org.eclipse.e4.core.di.InjectionException error [message #1219070 is a reply to message #1217086] Sat, 30 November 2013 17:54 Go to previous messageGo to next message
I add all the javafx package but still have the same problem.
I want to show someting I didn't put on the last message:
!MESSAGE Bundle org.eclipse.fx.osgi not found.
Here is the all error message:
!SESSION 2013-11-30 23:47:31.412 -----------------------------------------------
eclipse.buildId=M20130204-1200
java.version=1.8.0-ea
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=fr_FR
Framework arguments:  -product org.eclipse.sdk.ide
Command-line arguments:  -product org.eclipse.sdk.ide -data D:\eclipsefx\eclipse\MyWorkSpace/../runtime-EclipseApplication -dev file:D:/eclipsefx/eclipse/MyWorkSpace/.metadata/.plugins/org.eclipse.pde.core/Test/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.osgi 4 0 2013-11-30 23:47:34.016
==================> Initing with Display: org.eclipse.swt.widgets.Display@29876704
!ENTRY org.eclipse.ui 4 4 2013-11-30 23:47:57.492
!MESSAGE Unable to find Action Set: org.eclipse.jdt.junit.JUnitActionSet
!ENTRY org.eclipse.ui 4 4 2013-11-30 23:48:02.690
!ENTRY org.eclipse.ui 4 1 2013-11-30 23:48:02.691
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "com.ongoladev.FxRCP" was unable to instantiate class "com.ongoladev.fxrcp.views.MyViewPart".
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.switchPerspective(PartServiceImpl.java:514)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:124)
	... 103 more
	... 108 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2013-11-30 23:48:02.712
!STACK 0
	... 108 more
Thanks for the help.
Re: org.eclipse.e4.core.di.InjectionException error [message #1219123 is a reply to message #1219070] Mon, 02 December 2013 03:00 Go to previous messageGo to next message
Well this does not look good. Have you checked out something from our
git repo? The message above means that the adapter hooks are not found.
Does e.g. the fxml-Preview work in your host eclipse?
Tom
Re: org.eclipse.e4.core.di.InjectionException error [message #1219232 is a reply to message #1219123] Mon, 02 December 2013 14:37 Go to previous messageGo to next message
I'm afraid to not get you fearly well. You know english is not my usual language.
So what do you mean by Quote:
How can I test it.
Great thanks for your help.
Re: org.eclipse.e4.core.di.InjectionException error [message #1219297 is a reply to message #1219232] Tue, 03 December 2013 03:29 Go to previous messageGo to next message
I think I have spotted the problem. It looks like you are using the
0.8.1 release (i get that from your initial stack where
at.bestsolution.... shows up!).
I'd suggest you are using
http://downloads.efxclipse.bestsolution.at/downloads/nightly/sdk and
follow the tutorial http://wiki.eclipse.org/Efxclipse/Tutorials/Tutorial2
Tom
On 02.12.13 20:37, Frederic PAPY wrote:
> Hello,
> language.
> How can I test it.
Re: org.eclipse.e4.core.di.InjectionException error [message #1429237 is a reply to message #1217086] Mon, 22 September 2014 21:31 Go to previous messageGo to next message
Hello, Sorry for all the time I took for this another preocupation.
In fact everything work fine when I don't want to create a client application. When I want, the execution of the product "org.eclipse.sdk.ide" work verry well; but with every other product I have this error:
org.eclipse.core.runtime.CoreException: Plug-in "pmetest" was unable to instantiate class "pmetest.ui.view.fx.MyViewPart".
	at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:111)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:266)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:304)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:526)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:511)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:61)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1096)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:61)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:676)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1042)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at pmetest.Application.start(Application.java:23)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
	... 111 more
Caused by: java.lang.ClassNotFoundException: javafx.scene.Node cannot be found by pmetest_1.0.0.qualifier
	... 116 more
Please how can I fixe this. I want to embed JavaFX in my RCP application
Re: org.eclipse.e4.core.di.InjectionException error [message #1429379 is a reply to message #1429237] Tue, 23 September 2014 02:43 Go to previous messageGo to next message
a) Did you do the necessary package imports
b) when start in an inner eclipse don't forget to start with
c) to see if the osgi-hook is active run with
-Defxclipse.osgi.hook.debug=true
Tom
> have this error:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> at
> at
> at
> at
> at
> ... 111 more
> at
> at
> at
> at
> ... 116 more
> Thanks
Re: org.eclipse.e4.core.di.InjectionException error [message #1430910 is a reply to message #1429379] Wed, 24 September 2014 21:16 Go to previous messageGo to next message
I tried what you ask me without any succes. May be I didn't make it well.
When I use the configuration like picture forum2.png the application run well.
index.php/fa/19254/0/
But even with your suggestion, the configuration forum0 and forum1(two tabs of the same configuration) I have the same error.
index.php/fa/19255/0/
index.php/fa/19256/0/
May I didn't do it like you want?
  • Attachment: forum2.png
    (Size: 45.85KB, Downloaded 2309 times)
  • Attachment: forum0.png
    (Size: 44.12KB, Downloaded 2348 times)
  • Attachment: forum1.png
    (Size: 42.71KB, Downloaded 2325 times)
Re: org.eclipse.e4.core.di.InjectionException error [message #1431050 is a reply to message #1430910] Thu, 25 September 2014 02:39 Go to previous messageGo to next message
-D parameters go into VM-arguments and NOT into Program arguments!
Tom
On 25.09.14 03:16, Frederic PAPY wrote:
> Hello,
Re: org.eclipse.e4.core.di.InjectionException error [message #1472435 is a reply to message #1431050] Thu, 13 November 2014 16:54 Go to previous message
Oups!! Sorry for all this time. It's ok for me now.
Previous Topic:Log message during startup
Next Topic:Launch several JavaFX window from Eclipse IDE
Current Time: Sat Sep 27 07:31:19 EDT 2025
Powered by FUDForum. Page generated in 0.06589 seconds
