Home » Eclipse Projects » EGit / JGit » Compare with working tree
Compare with working tree [message #1216644] Thu, 28 November 2013 10:19 Go to next message
Eclipse Juno, EGit Version 2.2.0.201212191850-r
I'm looking for the easiest way to compare my working tree
a) against the index (output similar to `git diff`) and
b) an arbitrary commit in the History View (output similar to e.g. `git diff HEAD~2`).
For b) the user manual mentions an option "Compare with working tree", but I can't find it..?
Thanks.
Re: Compare with working tree [message #1216663 is a reply to message #1216644] Thu, 28 November 2013 10:26 Go to previous messageGo to next message
You should update to a newer version (latest release is 3.1.0, 3.2.0 will be released before x-mas)
The latest (developer build 3.2.0) version provides
Compare with > HEAD
Compare with > Index
Compare with > Git Index with HEAD (only enabled if some changes are staged)
Compare with > Previous Version
Compare with > Branch, Tag or Reference
Compare with > Commit
If you want to compare 2 arbitrary versions open the history view select 2 commits and click "Compare with each other"
Re: Compare with working tree [message #1216701 is a reply to message #1216663] Thu, 28 November 2013 10:43 Go to previous messageGo to next message
Ah, I forgot to add http://download.eclipse.org/egit/updates to the list of software sources.
So, not possible right now (using version 3.1.0)?
Thanks for your help!
Re: Compare with working tree [message #1216702 is a reply to message #1216701] Thu, 28 November 2013 10:44 Go to previous messageGo to next message
no, all these options should also be available in 3.1, I am just to lazy to check,
AFAIR we changed the order of menu entries but all should be available in 3.1
Re: Compare with working tree [message #1216738 is a reply to message #1216702] Thu, 28 November 2013 11:01 Go to previous messageGo to next message
OK, found it: it's not in the Team menu nor in a Git view but a separate entry in the context menu of the Package Explorer.
Thanks.
Re: Compare with working tree [message #1218316 is a reply to message #1216738] Fri, 29 November 2013 03:03 Go to previous message
yes, it was always there, the top level menu entry is provided by platform or team framework and we added
the additional entries for git based actions
Previous Topic:JGit/Android: prevent NetworkOnMainThreadException during commit
Next Topic:Set "core.excludesfile" outside, where does it appear in Egit?
Current Time: Sun Nov 09 17:50:30 EST 2025
Powered by FUDForum. Page generated in 0.04453 seconds
