Home » Eclipse Projects » P2 » Give me some references or advice about how to build and publish a p2 update site(How to build and publish a p2 update site)
Give me some references or advice about how to build and publish a p2 update site [message #1215936] Thu, 28 November 2013 03:55 Go to next message
I have to build and publish a p2 site for updating plugins of our ide product based on Eclipse v4.But I cannot find how to implement it.
I exported the product by "Eclipse Product export wizard" with checking "Generate p2 repository" item on product file page. After the exporting, I move the generated repository directory into a web server, open the menu Help > Install New Software, and add the web site into "Available Software Sites", but the response is "There is no categorized items"
I can not understand content.xml file and artifact.xml file structure. I've searched on eclipse.org, and only found the expired version info on http://wiki.eclipse.org/Equinox_p2_Metadata_Authoring.
Who can help me?
Best regards
Re: Give me some references or advice about how to build and publish a p2 update site [message #1229849 is a reply to message #1215936] Fri, 10 January 2014 06:04 Go to previous messageGo to next message
> items"
I don't know how your p2 looks like, but when you export a p2, there
should be a file named category.xml which tells how the features are
grouped in the p2 repo. (You can do file -> new -> pde -> Category
Definition). Although I don't know how the product exporter will use
this file though, I use it in a different way (read-on!).
There is also a checkbox in the installer, which says: "Group Items by
category", if you turn it off, you should see your features. (If your
product is feature based, as products can be plugin/feature based).
Another way to produce a P2 is to do file -> export -> Deployable
features. In the Options tab, you can specify a category.xml file.
The downside here, is that you already specifed all your features in the
..product, and will need to repeat re-specify your features which consist
your product. If your product is only to install plugins in an IDE, this
option is workable.
Finally, you can also produce old-style update site, with file -> new ->
PDE -> Update Site Project, but you might not want to use this...(It's
not P2).
Note that the PDE p2 tooling is very limited, I prefer to use the
headless P2 publisher, (Which is also used by build tools like
Buckminster or Tycho). You really tweak exactly as you want it.
http://wiki.eclipse.org/Equinox/p2/Publisher
Does this help?
Cheers / Christophe
> Who can help me?
> Best regards
Re: Give me some references or advice about how to build and publish a p2 update site [message #1229852 is a reply to message #1229849] Fri, 10 January 2014 06:07 Go to previous message
You can actually add your categories with this tool:
http://wiki.eclipse.org/Equinox/p2/Publisher#Category_Publisher
>> items"
> option is workable.
> not P2).
> Does this help?
> Cheers / Christophe
>> Who can help me?
>> Best regards
Previous Topic:p2 directory / mirror engine
Next Topic:FeaturesAndBundles p2 repo content not visible in target platform
Current Time: Sat Oct 25 16:06:33 EDT 2025
Powered by FUDForum. Page generated in 0.28983 seconds
