Re: Label not centered [message #196948 is a reply to message #196884] |
Mon, 14 July 2008 14:35 |
Originally posted by: nospam.nospam.com
I noticed the same problem after switching to the latest GMF/GEF/Eclipse.
Some labels are not centered when they were before.
I haven't tried anything yet. I was hoping some changes in .gmfgraph would
help if not I will try to modify the code.
Re: Label not centered [message #196963 is a reply to message #196948] |
Mon, 14 July 2008 15:38 |
> would help if not I will try to modify the code.
You can set this in the graph configuration as a facet on the label,
just as the example shows.
<labels
name="Callname"
figure="CallFigure"
elementIcon="false"
accessor="//@figures.0/@descriptors.23/@accessors.0">
<facets
xsi:type="gmfgraph:GeneralFacet"
identifier="Alignment"
data="PositionConstants.CENTER"/>
</labels>
Or by code :
fFigureCallnameFigure.setAlignment(PositionConstants.CENTER) ;
greetings, urs.
Re: Label not centered [message #197464 is a reply to message #196963] |
Wed, 16 July 2008 14:55 |
The change in code does work but the General Facet doesn't for me. There
is no difference in the generated code, the General Facet is ignored.
FUDForum. Page generated in 0.03924 seconds
