[MWE] Dependency issues in 2.4.1 release [message #1214289] |
Wed, 27 November 2013 16:27 |
Victor Roldan Betancort Messages: 524 Registered: July 2009 |
Hi folks,
first of all, not sure if this is the right place to ask abour MWE2. Could not find a dedicated forum. My apologies in advance.
We're moving on to Kepler, so that means, among other things, regenerating our Xtext grammars. My first build on jenkins failed due to a dependency with EMF 2.10. But wait... 2.10? How could that happen if I've only downloaded Kepler releases (actually SR1 releases).
Well, aparently bundle org.eclipse.emf.mwe2.language, on the 2.4.1 release, depends on 2.10 (emf.ecore 2.10 and emf.common 2.10). That seems as an inconsistency to me, as the 2.4.1 should not be breaking clients, and specially not to depend on a EMF version that has not been released yet.
I checked it, and in the 2.4.0, the dependency is over the 2.9 release
So, is this an unintended client breakage?
I fetched if from http://www.eclipse.org/modeling/emft/downloads/?project=mwe
2.4.1 (2013/09/03) release
Best Regards,
Víctor Roldán [Open Canarias]
Re: [MWE] Dependency issues in 2.4.1 release [message #1232747 is a reply to message #1232714] |
Fri, 17 January 2014 16:10 |
Aaron Digulla Messages: 258 Registered: July 2009 Location: Switzerland |
Dennis Huebner wrote on Fri, 17 January 2014 15:52If you use the Kepler update site you should already get a fixed version.
If you use emft download site (which was also fixed now) you should get a new zip file (feature qualifier ends with 201309030840).
Here is a direct link:
http://www.eclipse.org/modeling/emft/downloads/?showAll=1&hlbuild=R201309030840&project=mwe#R201309030840
That's the version I tried (2.4.1) and which has the bug.
My SHA1 checksums are:
139aa402ca831d56e9b6d1e54c42aa5c4edb09cd emft-mwe-Update-2.4.1.zip
95daf7f00ffe9ea5604b967d9757d00f6e139750 emft-mwe-2-lang-Update-2.4.1.zip
Features included are:
31730 Defl:N 31063 2% 2013-09-03 04:26 f46291db features/org.eclipse.emf.mwe.core.source_1.3.1.v201309030422.jar
32479 Defl:N 31813 2% 2013-09-03 04:26 10b86ea9 features/org.eclipse.emf.mwe.core_1.3.1.v201309030422.jar
31716 Defl:N 31045 2% 2013-09-03 04:26 7ed4e98d features/org.eclipse.emf.mwe.doc.source_1.2.1.v201309030422.jar
32382 Defl:N 31707 2% 2013-09-03 04:26 0e41094f features/org.eclipse.emf.mwe.doc_1.2.1.v201309030422.jar
31802 Defl:N 31122 2% 2013-09-03 04:26 40f27f99 features/org.eclipse.emf.mwe.sdk.source_1.3.1.v201309030422.jar
32377 Defl:N 31707 2% 2013-09-03 04:26 7ae2e13b features/org.eclipse.emf.mwe.sdk_1.3.1.v201309030422.jar
31740 Defl:N 31075 2% 2013-09-03 04:26 7eacecb4 features/org.eclipse.emf.mwe.ui.source_1.2.1.v201309030422.jar
32518 Defl:N 31848 2% 2013-09-03 04:26 50a1c244 features/org.eclipse.emf.mwe.ui_1.2.1.v201309030422.jar
31781 Defl:N 31109 2% 2013-09-03 04:26 e2c2f4e8 features/org.eclipse.emf.mwe2.runtime.sdk.source_2.4.1.v201309030422.jar
32531 Defl:N 31862 2% 2013-09-03 04:26 a4f543a9 features/org.eclipse.emf.mwe2.runtime.sdk_2.4.1.v201309030422.jar
These files are broken.
I then downgraded to 2.4.0 and those files work (same download link, just the next item in the tree).
[Updated on: Fri, 17 January 2014 16:11] Report message to a moderator
Re: [MWE] Dependency issues in 2.4.1 release [message #1232778 is a reply to message #1232747] |
Fri, 17 January 2014 18:14 |
checksum for emft-mwe-2-lang-Update-2.4.1.zip should be d4613a0fbebf1f93a81452e35a0f2034619afa4c:
dhubner@build:~/downloads-mwe/downloads/drops/2.4.1> sha1sum R201309030840/emft-mwe-2-lang-Update-2.4.1.zip
d4613a0fbebf1f93a81452e35a0f2034619afa4c R201309030840/emft-mwe-2-lang-Update-2.4.1.zip
checksum for emft-mwe-Update-2.4.1.zip matches:
dhubner@build:~/downloads-mwe/downloads/drops/2.4.1> sha1sum R201309030840/emft-mwe-Update-2.4.1.zip
139aa402ca831d56e9b6d1e54c42aa5c4edb09cd R201309030840/emft-mwe-Update-2.4.1.zip
*.v201309030422 features are not broken. This is because mwe build has to steps, so mwe and mwe2.runtime have an another timestamp as mwe2.languge. If you get both zips with checksums above, you are good to go.
+Dennis Huebner
Get professional support from the Xtext committers at www.typefox.io
[Updated on: Fri, 17 January 2014 18:40] Report message to a moderator
FUDForum. Page generated in 0.03786 seconds
