Setting Edit>Creation Icons to false causes generation of shouldComposeCreationImage in ItemProvi [message #1213922] |
Wed, 27 November 2013 13:03 |
I'm working with a fairly large EMF model where we do not want any "creation icons" to be generated (those in <edit>/icons/full/ctools16). So I went ahead and set the "Edit > Creation Icons" property in the genmodel to false. By the way, we are not using the any creation commands, so the "Edit > Creation Commands" is also set to false.
But when I re-generate the edit-code, every ItemProvider gets the following override:
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
protected boolean shouldComposeCreationImage() {
return true;
This sort of defeats the purpose of setting the property to false, since now I have to override this to return false in every ItemProvider.
This behavior seems to have appeared in EMF 2.6 and later.
Are there anyway of avoiding this, i.e. not getting the shouldComposeCreationImage method overide?
--Fredrik
Re: Setting Edit>Creation Icons to false causes generation of shouldComposeCreationImage in I [message #1214436 is a reply to message #1213922] |
Wed, 27 November 2013 17:52 |
Ed Merks Messages: 33142 Registered: July 2009 |
Fredrik,
Comments below.
On 27/11/2013 2:03 PM, Fredrik Attebrant wrote:
> following override:
> * @generated
> @Override
> return true;
This just means that when it needs creation icons, it will compose them
from the icons of the objects themselves...
Is there really a problem or are you assuming it's a problem?
> --Fredrik
Ed Merks
FUDForum. Page generated in 0.03580 seconds
