DND Exception [message #196489] |
Thu, 10 July 2008 14:43 |
Hugues Rérolle Messages: 60 Registered: July 2009 |
Member |
Hi all,
I have a problem with drag'n drop into diagram, I have the following
Exception when I drag an object in my diagram.
This problem occurs only when I drop an object from a different kind of
model.
Does anyone have an idea for solving this problem?
Hugues
!ENTRY org.eclipse.ui 4 0 2008-07-10 16:05:22.487
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Data does not have correct format for type
at org.eclipse.swt.dnd.DND.error(DND.java:257)
at org.eclipse.swt.dnd.DND.error(DND.java:208)
at org.eclipse.swt.dnd.FileTransfer.javaToNative(FileTransfer.j ava:67)
at org.eclipse.swt.dnd.DragSource.GetData(DragSource.java:465)
at org.eclipse.swt.dnd.DragSource.access$7(DragSource.java:431)
at org.eclipse.swt.dnd.DragSource$4.method3(DragSource.java:254 )
at
org.eclipse.swt.internal.ole.win32.COMObject.callback3(COMOb ject.java:92)
at org.eclipse.swt.internal.ole.win32.COM.DoDragDrop(Native Method)
at org.eclipse.swt.dnd.DragSource.drag(DragSource.java:358)
at org.eclipse.swt.dnd.DragSource.access$0(DragSource.java:284)
at org.eclipse.swt.dnd.DragSource$1.handleEvent(DragSource.java :168)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
FUDForum. Page generated in 0.02297 seconds
