Report Viewer PDF Problem [message #196406] |
Thu, 19 October 2006 08:10 |
Originally posted by: p.corbett.ecu.edu.au
I have deployed BIRT 2.1.1 on Tomcat 5.5.17 and I am having problems
producing a PDF from a report.
I have copied the itext-1.3.jar to
/WebViewerExample/WEB-INF/platform/plugins/com.lowagie.itext /lib.
and iTextAsian.jar to
but the problem persists. The downloaded example file did not have a lib
directory as described above so I have added it.
In IE I this error occurs:
org.eclipse.birt.report.service.api.ReportServiceException: Report engine
fails to create extension to handle this request.
In Firefox
File does not begin with '%PDF-'
Any help would be appreciated
Re: Report Viewer PDF Problem [message #196568 is a reply to message #196406] |
Thu, 19 October 2006 16:21 |
Does this fail on the test report?
When you click view example it should load a similar URL to this
http://localhost:8080/birt2.1.1/frameset?__report=test.rptde sign&sample=my+parameter
Select the print icon in the toolbar.
Jason
"Peter Corbett" <p.corbett@ecu.edu.au> wrote in message
news:d50be27d5bae93a6deb4ba64e756c346$1@www.eclipse.org...
> /WebViewerExample/WEB-INF/platform/plugins/com.lowagie.itext /lib. but the
> In Firefox
Re: Report Viewer PDF Problem [message #196675 is a reply to message #196568] |
Thu, 19 October 2006 23:37 |
Yes that fails too.
Error message is:
My URL is
http://localhost:7070/birt-viewer/frameset?__report=test.rpt design&sample
> Jason
>> In Firefox
Re: Report Viewer PDF Problem [message #196809 is a reply to message #196675] |
Fri, 20 October 2006 14:19 |
What OS are you running?
I will download the same Tomcat version and give it a try.
Jason
news:c713cabd5c85a2097b9d9fab5e0ed01f$1@www.eclipse.org...
> Yes that fails too.
> Error message is:
> My URL is
>> Jason
>>> engine fails to create extension to handle this request.
>>> In Firefox
Re: Report Viewer PDF Problem [message #198186 is a reply to message #197775] |
Sun, 29 October 2006 23:01 |
Ken,
Verify that you do have both iText files added the lowagie plugin.
Jason
"Ken Carroll" <ken.carroll@fmr.com> wrote in message
news:ehpabd$4jo$1@utils.eclipse.org...
> Was there any conclusion to this ? I am experiencing the same problem and
> am
> unable to resolve it.
> Ken
> "Jason Weathersby" <jweathersby@actuate.com> wrote in message
> news:ehalto$udt$1@utils.eclipse.org...
>> Jason
>> > Yes that fails too.
>> > Error message is:
> engine
>> > My URL is
>> >> Jason
>> >>> In Firefox
Re: Report Viewer PDF Problem [message #198704 is a reply to message #198318] |
Thu, 02 November 2006 10:53 |
Originally posted by: timgaulza.gmail.com
Will this work, I am experiencing similar problems with 2.2M1
news:ei4q2a$v9v$1@utils.eclipse.org...
>I definitely have added the itext files into the itext plugin folder
>exactly
> as directed in the installation instructions.
> I just now got a response from bugzilla (bug # 162313) saying that v2.1.1
> has problems with pdf's suggesting I should move to a later release.
> Ken
> news:ei3brn$7p2$1@utils.eclipse.org...
>> Ken,
>> Jason
> and
>> > am
>> > Ken
>> >> Jason
>> >> > Yes that fails too.
>> >> > Error message is:
>> > engine
>> >> > My URL is
>> >> >> Jason
>> >> >>>problems
> but
> lib
>> >> >>> In Firefox
Re: Report Viewer PDF Problem [message #198854 is a reply to message #198704] |
Thu, 02 November 2006 20:22 |
Are you using the Allinone or RCP download?
Jason
"Tim Gaul" <timgaulza@gmail.com> wrote in message
news:eicin0$6eh$1@utils.eclipse.org...
>>exactly
>> Ken
>>> Ken,
>>> Jason
>> and
>>> > am
>>> > Ken
>>> >> Jason
>>> >> > Yes that fails too.
>>> >> > Error message is:
>>> > engine
>>> >> > My URL is
>>> >> >> Jason
>>> >> >>>problems
>> but
>> lib
>>> >> >>> Report
>>> >> >>> In Firefox
Re: Report Viewer PDF Problem [message #198956 is a reply to message #198318] |
Fri, 03 November 2006 09:13 |
Originally posted by: reg.hill-labs.co.nz
I had this problem, and I had installed the itext jars, then I had another
look, and somewhere down the upgrade path, I picked up two other
com.lowagie.itext... versions that I had not yet added the itext jars to...
You may already have checked for muliple itext locatioins... just thought
I would mention it, as it solved my problem.
Colin
Re: Report Viewer PDF Problem [message #199317 is a reply to message #199166] |
Mon, 06 November 2006 17:18 |
Copy iText-1.3.jar and iTextAsian.jar to the lib directory.
Jason
"Mira" <mkaloper@ucdavis.edu> wrote in message
news:a96fca910eb59c079a742861c6e2d75b$1@www.eclipse.org...
> I was wondering if there was a solution to this problem, since I have not
> been able to create pdf files with the 2.1.1 or 2.1.0 version of birt.
> I am using Red Hat. I added itext-1.3.jar to
> /plugins/com.lowagie.itext_1.3.0.N20060628-1351/lib
> Is there something else that I should have done? I have downloaded the
> lates birt (full all-in-one installation with eclipse). I can create
> report, but I cannot create pdf files - eclipse crashes.
> Someone please help and let me know what should be done.
> Thanks a lot,
> Mira
Re: Report Viewer PDF Problem [message #200063 is a reply to message #200016] |
Thu, 09 November 2006 19:58 |
Can you post the error?
Jason
"Justin Knash" <jknash@gmail.com> wrote in message
news:83450d09a097b5a4554f492760b6b792$1@www.eclipse.org...
> I'm having the same problem. I'm running Birt on Suse Linux Enterprise
> Desktop 10. When I try to do anything with a PDF file, eclipse crashes
> and I get a window with a java error and an ok button. Any help is much
> appreciated.
Re: Report Viewer PDF Problem [message #201092 is a reply to message #200760] |
Wed, 15 November 2006 20:00 |
Justin,
Can you log a bug with the error and the version of BIRT you are using?
Jason
news:cdd8a3f2bf00bd90d997f666b8b2dcd0$1@www.eclipse.org...
> Here is the text I get in my terminal -
> # An unexpected error has been detected by HotSpot Virtual Machine:
> # SIGSEGV (0xb) at pc=0x99ea320b, pid=28966, tid=3084696416
> # Java VM: Java HotSpot(TM) Client VM (1.4.2_11-b06 mixed mode)
> # Problematic frame:
> # C [libxul.so+0x4e020b] _ZN18nsAString_internal6AssignERKS_+0x15
> # An error report file with more information is saved as
> hs_err_pid28966.log
> # If you would like to submit a bug report, please visit:
> # http://java.sun.com/webapps/bugreport/crash.jsp
> Here is the text on the window with the OK button -
> JVM terminated. Exit code=1
> /usr/bin/java
> -Xms40m
> -Xmx256m
> -jar /usr/local/eclipse-birt/./startup.jar
> -os linux
> -ws gtk
> -arch x86
> -launcher /usr/local/eclipse-birt/./eclipse
> -name Eclipse
> -showsplash 600
> -exitdata 900024
> -vm /usr/bin/java
> -vmargs
> -Xms40m
> -Xmx256m
> thanks,
> Justin
FUDForum. Page generated in 0.04086 seconds
