| problem with IBM JVM [message #196225] |
Tue, 17 February 2004 11:52  |
hi,
i am using IBM java sdk 1.4.1 and i am getting the following error,
(when i am trying to open plugin.xml)
what can i do to disable the xml.jar??
thanks,
Asaf.
!ENTRY org.eclipse.jface 4 2 ×€×ך 17, 2004 16:06:41.351
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoSuchMethodError: org.apache.xerces.parsers.DOMBuilderImpl:
method setFeature(Ljava/lang/String;Z)V not found
org.eclipse.pde.internal.core.plugin.XMLDocumentModelBuilder .initialize(XMLDocumentModelBuilder.java:71)
org.eclipse.pde.internal.core.plugin.XMLDocumentModelBuilder . <init>(XMLDocumentModelBuilder.java:67)
org.eclipse.pde.internal.core.plugin.XMLCore.createXMLModelB uilder(XMLCore.java:61)
org.eclipse.pde.internal.core.plugin.DocumentModel.<init>(DocumentModel.java:44)
org.eclipse.pde.internal.core.plugin.AbstractPluginModelBase .getDocumentModel(AbstractPluginModelBase.java:51)
org.eclipse.pde.internal.core.plugin.AbstractPluginModelBase .load(AbstractPluginModelBase.java:151)
org.eclipse.pde.internal.core.WorkspaceModelManager.loadWork spaceModel(WorkspaceModelManager.java:635)
org.eclipse.pde.internal.core.WorkspaceModelManager.createWo rkspacePluginModel(WorkspaceModelManager.java:161)
org.eclipse.pde.internal.core.WorkspaceModelManager.createWo rkspacePluginModel(WorkspaceModelManager.java:172)
org.eclipse.pde.internal.core.WorkspaceModelManager.initiali zeWorkspacePluginModels(WorkspaceModelManager.java:487)
org.eclipse.pde.internal.core.WorkspaceModelManager.reset(Wo rkspaceModelManager.java:717)
org.eclipse.pde.internal.core.PDECore.initializeModels(PDECo re.java:327)
org.eclipse.pde.internal.core.PDECore.getExternalModelManage r(PDECore.java:246)
org.eclipse.pde.internal.ui.launcher.AdvancedLauncherTab.<init >(AdvancedLauncherTab.java:137)
org.eclipse.pde.internal.ui.launcher.WorkbenchLauncherTabGro up.createTabs(WorkbenchLauncherTabGroup.java:32)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer$5.run(LaunchConfigurationTabGroupVi ewer.java:575)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.createGroup(LaunchConfigurationTabG roupViewer.java:584)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.showTabsFor(LaunchConfigurationTabG roupViewer.java:525)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.displayTabs(LaunchConfigurationTabG roupViewer.java:467)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.inputChanged(LaunchConfigurationTab GroupViewer.java:448)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.setInput(LaunchConfigurationTabGrou pViewer.java:428)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.handleLaunchConfigurationSelectionChanged( LaunchConfigurationsDialog.java:870)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$2.selectionChanged(LaunchConfigurationsDia log.java:641)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:159)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:157)
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:1290)
org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedViewer.java:1020)
at org.eclipse.jface.viewers.Viewer.setSelection(Viewer.java:36 2)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.doInitialTreeSelection(LaunchConfiguration sDialog.java:401)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.initializeContent(LaunchConfigurationsDial og.java:342)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.createContents(LaunchConfigurationsDialog. java:337)
at org.eclipse.jface.window.Window.create(Window.java:302)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.create(LaunchConfigurationsDialog.java:182 6)
at org.eclipse.jface.window.Window.open(Window.java:552)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.openDialogOnSelection(LaunchConfigurations Dialog.java:504)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:458)
at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:36 9)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:373)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:315)
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:70)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:456)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionContributionItem.java:403)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionItem.java:397)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionItem.java:72)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled
Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1838)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1545)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:79)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:41)
at java.lang.reflect.Method.invoke(Method.java:371)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
| Re: problem with IBM JVM [message #196791 is a reply to message #196329] |
Wed, 18 February 2004 01:35  |
hi again,
after changing the xml.jar to xml.jar.old and launching the eclipse - i
got the message: "Problems during startup...." (dialog..)
and here is the .log file:
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 ×€×ך 18, 2004 06:35:59.150
!MESSAGE Exception launching the Eclipse Platform:
!STACK
org.apache.xerces.util.ObjectFactory$ConfigurationError: Provider
org.apache.xerces.parsers.IntegratedParserConfiguration not found
org.apache.xerces.util.ObjectFactory.newInstance(ObjectFacto ry.java:252)
org.apache.xerces.util.ObjectFactory.createObject(ObjectFact ory.java:182)
org.apache.xerces.util.ObjectFactory.createObject(ObjectFact ory.java:123)
at org.apache.xerces.parsers.SAXParser.<init>(SAXParser.java:95)
org.eclipse.core.internal.resources.ProjectDescriptionReader .read(ProjectDescriptionReader.java:439)
org.eclipse.core.internal.resources.ProjectDescriptionReader .read(ProjectDescriptionReader.java:475)
org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(FileSystemResourceManager.java:450)
org.eclipse.core.internal.resources.SaveManager.restoreMetaI nfo(SaveManager.java:582)
org.eclipse.core.internal.resources.SaveManager.restoreMetaI nfo(SaveManager.java:623)
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:504)
org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1033)
org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1734)
at org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1537)
org.eclipse.core.resources.ResourcesPlugin.startup(Resources Plugin.java:268)
org.eclipse.core.internal.plugins.PluginDescriptor$1.run(Plu ginDescriptor.java:736)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:748)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:112)
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParentsSelf(PluginClassLoader.java:185)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf(DelegatingURLClassLoader.java:490)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:882)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.acce ss$0(DelegatingURLClassLoader.java:876)
org.eclipse.core.internal.boot.DelegatingURLClassLoader$Dele gateLoader.loadClass(DelegatingURLClassLoader.java:90)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassPrerequisites(DelegatingURLClassLoader.java:554)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:890)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:862)
at java.lang.ClassLoader.loadClass(ClassLoader.java:484)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 57)
at java.lang.Class.getConstructor0(Class.java:1835)
at java.lang.Class.newInstance0(Class.java:316)
at java.lang.Class.newInstance(Class.java:295)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:138)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:167)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExtension(ConfigurationElement.java:103)
org.eclipse.core.internal.runtime.InternalPlatform.loaderGet Runnable(InternalPlatform.java:578)
org.eclipse.core.internal.boot.InternalBootLoader.getRunnabl e(InternalBootLoader.java:471)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:854)
> A quick search through bugs.eclipse.org/bugs reveals:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=39187
> which says, "workaround for this problem:
> rename xml.jar to xml.jar.old in jre/lib
> This works fine if you don't need the xml parser in other Java application."
> Hope this helps!
> Andrew Jr.
> IBM Phoenix Labs (OTI)
> 11811 North Tatum Boulevard, Suite 2400
> Phoenix, Arizona, USA 85028-1614
FUDForum. Page generated in 0.04357 seconds
