Home » Modeling » QVT-OML » Posible enhacements in the QVT code
| Posible enhacements in the QVT code [message #1211634] |
Tue, 26 November 2013 09:45  |
Hi all,
we use QVTo for our stack of model transformations in our products. We historically had to modify some plugins to mainly avoid undesirable dependencies in our products and other issues. I'd like to share this improvements here, looking for a chance to contribute them and finally getting rid of them. Im using the Kepler release, btw.
- org.eclipse.m2m.qvt.oml.emf.util.ui. States depends on Java 1.5, but uses Java 1.6 API. This shows compilations errors when using Java 1.5 compliance in the workspace. Probably the original developer had its workspace improperly setup. Affected classes:
* Line 55, ResourceDesintationChooser.
* Line 64, ResourceSourceChooser.
* Line 38, ResourceSourceDestChooser.
Solution -> replace by String.length() == 0
- org.eclipse.m2m.qvt.oml.emf.util.ui. Dependency on org.eclipse.emf.codegen.ecore.ui. It does not actually depend in any specific API of that bundle, but rather depends in reexports. I'd suggest to change to the actual dependencies, however, that would imply breaking clients (unfortunately, it's reexported). If you're still interested, it should be substituted by:
* org.eclipse.emf.ecore.edit;bundle-version="[2.5.0,3.0.0)",
* org.eclipse.emf.edit.ui;bundle-version="[2.5.0,3.0.0)",
* org.eclipse.ui.ide;bundle-version="[3.5.0,4.0.0)"
- org.eclipse.m2m.qvt.oml.editor.ui. We do not include JDT in our products, but this plugins depends on the JDT API, and makes it mandatory to have the whole JDT feature in our RCP, basically just for icons and a view ID. I understand its not desirable duplicate icons, neither hardcode view IDs, but I'd like to put this out, maybe there are better options. For instance, refactoring those dependencies in a new bundle (org.eclipse.m2m.qvt.oml.editor.jdt.ui).
So thats all. If any of the above sounds reasonable, I could provide some patches.
Best Regards!
Víctor Roldán [Open Canarias]
| Re: Posible enhacements in the QVT code [message #1214055 is a reply to message #1211634] |
Wed, 27 November 2013 09:18   |
This was fixed by commit 355aa060932b4bfdca1dbdfe896be02dc177d274 on
2013-07-18 15:59:15
This is trivial; no need for a patch; just a Bugzilla for tracking.
QVTo already has image registries. It is probably easy to reuse
something already within QVTo to replace JavaUI.getSharedImages(); e.g.
CompletionProposalUtil.getImage(). If you got a few spare moments you
can see how many other equivalent registries have appeared through
diverse development.
The four *.gif files can then be copied to the local icons folder. No
need for an extra plugin.
Ed Willink
| Re: Posible enhacements in the QVT code [message #1229102 is a reply to message #1229090] |
Wed, 08 January 2014 13:19  |
Hi Ed,
that's quite unfortunate. I'll interpret your answer as "unfortunately, there's much to do before that could happen, and we are lacking on resources"
Can only hope you guys find some time for the maintenance builds.
Best Regards,
Current Time: Wed Nov 05 23:26:07 EST 2025
Powered by FUDForum. Page generated in 0.05372 seconds
