Re: [EMF/Edit][Teneo] Call to AdapterFactoryEditingDomain.getEditingDomainFor(eObject) returns null, [message #1211970 is a reply to message #1211308] |
Tue, 26 November 2013 18:03 |
Hi Marina,
I don't know that much about editing domains... But there is also a HibernateResource implementation, there are several
ways to load a resource:
http://wiki.eclipse.org/Teneo/Hibernate/EMF_Resource
For general questions on editingdomains and resources I think the EMF newsgroup is better. You should get a quick
response there.
gr. Martin
On 11/26/2013 12:16 PM, Marina Knieling wrote:
> Hey guys,
> in my e4/EMF/ECP application I implemented my own ECPControlContext and this includes a call to
> AdapterFactoryEditingDomain.getEditingDomainFor(eObject). I get a NullPointerException from that call as it seems that
> my eObject doesn't have a resource attached to it.
> I'm working with Hibernate/Teneo to store my model elements in a database and therefore don't create any resources for
> persistence. Is that wrong? And how would I incorporate a resource when working with Teneo?
> Here is the stacktrace of the Exception:
> !ENTRY org.eclipse.e4.ui.workbench 4 0 2013-11-26 12:06:03.561
> !MESSAGE Internal Error
> !STACK 0
> at org.eclipse.emf.ecp.internal.edit.ECPControlHelper.addModelElementInReference(ECPControlHelper.java:40)
> at
> com.vknie.comma.core.ui.views.internal.ecp.editor.ECPControlContextImpl.addModelElement(ECPControlContextImpl.java:94)
> at org.eclipse.emf.ecp.edit.internal.swt.actions.NewReferenceAction.run(NewReferenceAction.java:155)
> at org.eclipse.emf.ecp.edit.internal.swt.util.SWTControl$4.widgetSelected(SWTControl.java:368)
> at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
> at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
> at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:162)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
> This is line 94 from my ECPControlContextImpl class:
> ECPControlHelper.addModelElementInReference(modelElement, newMEInstance, eReference, getEditingDomain());
> This is the call to getEditingDomain()
> public EditingDomain getEditingDomain() {
> return AdapterFactoryEditingDomain.getEditingDomainFor(modelElement);
> and this is line 40 from ECPControlHelper where the actual NullPointerException occurs as editingDomain is null:
> editingDomain.getCommandStack().execute(AddCommand.create(editingDomain, eObject, eReference, newMEInstance));
> Thanks in advance
> Marina
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [EMF/Edit][Teneo] Call to AdapterFactoryEditingDomain.getEditingDomainFor(eObject) returns null, [message #1216333 is a reply to message #1211970] |
Thu, 28 November 2013 12:29 |
Marina Knieling Messages: 83 Registered: February 2013 |
Member |
Hi Martin,
thanks for your reply. I think, I got the groups mixed up. I thought all
of the EMF stuff was merged into this one. So I'll go and repost my
question in the EMF newsgroup. Thanks anyway.
Marina
Am 26.11.2013 19:03, schrieb Martin Taal:
> Hi Marina,
> HibernateResource implementation, there are several ways to load a
> resource:
> newsgroup is better. You should get a quick response there.
> gr. Martin
>> Hey guys,
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> return
>> Thanks in advance
>> Marina
FUDForum. Page generated in 0.02989 seconds
