Home » Archived » BIRT » pdf export for text element containing html table
pdf export for text element containing html table [message #195637] Mon, 16 October 2006 08:25 Go to next message
Originally posted by: thomaskr.segue.at
--------------080600080304020101000204
hi,
i have a text element which contains a html statement to create a table.
the table is rendered correctly in html. however when i try to export
the report to pdf, it is empty.
attached is a simple example for demonstration
Content-Type: text/xml;
name="bar.rptdesign"
Content-Disposition: inline;
filename="bar.rptdesign"
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.6" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.1.0.N20060628-1351 Build &lt;20060628-1537></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 &lt;&lt;Your Company Name here>></property>
<method name="initialize"><![CDATA[var width1 = 40;
var width2 = 60;]]></method>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="1369">
<property name="height">0.687in</property>
<property name="width">2.104in</property>
<column id="1376">
</column>
<header>
<row id="1370">
<property name="height">20px</property>
<cell id="1371"/>
</row>
</header>
<detail>
<row id="1372">
<cell id="1373">
<text id="1368">
<text-property name="content"><![CDATA[<table border="2" cellpadding="0" cellspacing="0" width="100%">
<tr height="10px">
<td bgcolor="blue" width="60%"></td><td bgcolor="orange" width="40%"></td>
</tr>
</table>]]></text-property>
</text>
</cell>
</row>
</detail>
<footer>
<row id="1374">
<property name="height">0.239in</property>
<cell id="1375"/>
</row>
</footer>
</table>
</body>
<list-property name="images">
<structure>
<property name="name">green.gif</property>
<property name="data"> R0lGODlhCgAKAIAAAACAAAAAACH5BAAAAAAALAAAAAAKAAoAAAIIhI+py+0P YysAOw== </property>
</structure>
<structure>
<property name="name">red.gif</property>
<property name="data"> R0lGODlhCgAKAIAAAP8AAAAAACH5BAAAAAAALAAAAAAKAAoAAAIIhI+py+0P YysAOw== </property>
</structure>
</list-property>
</report>
--------------080600080304020101000204--
Re: pdf export for text element containing html table [message #199217 is a reply to message #195637] Mon, 06 November 2006 04:05 Go to previous messageGo to next message
still no comments on this issue?
> hi,
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="1369">
> <column id="1376">
> </column>
> <header>
> <row id="1370">
> <cell id="1371"/>
> </row>
> </header>
> <detail>
> <row id="1372">
> <cell id="1373">
> <text id="1368">
> <tr height="10px">
> </tr>
> </text>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="1374">
> <cell id="1375"/>
> </row>
> </footer>
> </table>
> </body>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </report>
Re: pdf export for text element containing html table [message #199596 is a reply to message #199217] Tue, 07 November 2006 03:58 Go to previous messageGo to next message
Originally posted by: screek.gmx.de
I just checked this and I could reproduce the error.
Unfortunatelly I have no solution for this problem. Looks like a bug.
Christian
"Thomas Krupa" <thomaskr@segue.at> wrote in message
news:eimts0$ime$2@utils.eclipse.org...
>> hi,
>> the table is rendered correctly in html. however when i try to export the
>> <?xml version="1.0" encoding="UTF-8"?>
>> id="1">
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <table id="1369">
>> <column id="1376">
>> </column>
>> <header>
>> <row id="1370">
>> <cell id="1371"/>
>> </row>
>> </header>
>> <detail>
>> <row id="1372">
>> <cell id="1373">
>> <text id="1368">
>> <tr height="10px">
>> width="40%"></td>
>> </tr>
>> </text>
>> </cell>
>> </row>
>> </detail>
>> <footer>
>> <row id="1374">
>> <cell id="1375"/>
>> </row>
>> </footer>
>> </table>
>> </body>
>> <structure>
>> <property
>> </structure>
>> <structure>
>> <property
>> </structure>
>> </list-property>
>> </report>
Re: pdf export for text element containing html table [message #205533 is a reply to message #199596] Fri, 08 December 2006 03:41 Go to previous message
did you find a solution or workaround for this problem in the meantime?
Christian
"Christian Eckert" <screek@gmx.de> wrote in message
news:eiphs4$nfd$1@utils.eclipse.org...
> Christian
>>> hi,
>>> id="1">
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <table id="1369">
>>> <column id="1376">
>>> </column>
>>> <header>
>>> <row id="1370">
>>> <cell id="1371"/>
>>> </row>
>>> </header>
>>> <detail>
>>> <row id="1372">
>>> <cell id="1373">
>>> <text id="1368">
>>> <text-property
>>> <tr height="10px">
>>> width="40%"></td>
>>> </tr>
>>> </text>
>>> </cell>
>>> </row>
>>> </detail>
>>> <footer>
>>> <row id="1374">
>>> <cell id="1375"/>
>>> </row>
>>> </footer>
>>> </table>
>>> </body>
>>> <structure>
>>> <property
>>> </structure>
>>> <structure>
>>> <property
>>> </structure>
>>> </list-property>
>>> </report>
Previous Topic:Charts not appearing in WebSphere - works in Tomcat
Next Topic:No parameters in joint dataset
Current Time: Thu Sep 25 14:51:07 EDT 2025
Powered by FUDForum. Page generated in 0.04961 seconds
