Home » Language IDEs » C / C++ IDE (CDT) » missing GDB HARDWARE DEBUGGING
missing GDB HARDWARE DEBUGGING [message #194607] Sat, 30 June 2007 08:25 Go to next message
Originally posted by: thomas.schulte13.freenet.de
GDB HARDWARE DEBUGGING was an available item of CDT4 - early RC version.
Since I have the final stuff installed it is not there anymore.
WHY?? Can someone explain the background?
I started using it and I would like to see it again.
Kind regards
Thomas
Re: missing GDB HARDWARE DEBUGGING [message #194989 is a reply to message #194607] Tue, 03 July 2007 15:38 Go to previous messageGo to next message
Originally posted by: dschaefer.qnx.com
T.Schulte wrote:
> Kind regards
> Thomas
Not where? It's there on the update site and in the cdt-master zip.
Doug
Re: missing GDB HARDWARE DEBUGGING [message #195487 is a reply to message #194989] Fri, 06 July 2007 07:47 Go to previous messageGo to next message
Hello Doug,
I installed cdt (Twice before! Same like eclipse3.3) per eclipse update
manager. I did not improve.
What do you mean by update site - this link?
http://download.eclipse.org/tools/cdt/releases/europa
There is no seaparate item like GDB HARDWARE DEBUGGING to download.
Just to cover everything else I installed the Windows package: Same result,
no GDB HARDWARE DEBUGGING.
If everyone else is getting it but not me, well the problem must be with me
somewhere - but cannot not recognize the point.
Just to give a last excuse: my OS is Vista.
One thing I identified when running that specific windos package: It did not
had the Ixxxxyyzz Integration build number in the opener (eclipse start
image).
My current eclipse still opens with displaying the Integration build
number=I20070625
Thomas
"Doug Schaefer" <dschaefer@qnx.com> schrieb im Newsbeitrag
news:f6e8is$3ls$8@build.eclipse.org...
> T.Schulte wrote:
>> Kind regards
>> Thomas
> Doug
Re: missing GDB HARDWARE DEBUGGING [message #195510 is a reply to message #195487] Fri, 06 July 2007 10:17 Go to previous messageGo to next message
T.Schulte wrote:
> Hello Doug,
> result, no GDB HARDWARE DEBUGGING.
> me somewhere - but cannot not recognize the point.
> not had the Ixxxxyyzz Integration build number in the opener (eclipse
> start image).
> number=I20070625
> Regards
> Thomas
>> T.Schulte wrote:
>>> Hi,
>>> Kind regards
>>> Thomas
>> Doug
Do you get any of the features in the Optional Features category in the
update manager?
Re: missing GDB HARDWARE DEBUGGING [message #195534 is a reply to message #195510] Fri, 06 July 2007 10:29 Go to previous messageGo to next message
Doug Schaefer wrote:
> T.Schulte wrote:
>> Hello Doug,
>> update manager. I did not improve.
>> with me somewhere - but cannot not recognize the point.
>> did not had the Ixxxxyyzz Integration build number in the opener
>> (eclipse start image).
>> number=I20070625
>> Regards
>> Thomas
>>> T.Schulte wrote:
>>>> Hi,
>>>> version.
>>>> Kind regards
>>>> Thomas
>>> Doug
> update manager?
I just tried on Vista as well and I see it. It's in the CDT Optional
Features list and is called "Eclipse C/C++ GDB Hardware Debugging
4.0.0.200706261300".
Doug.
Re: missing GDB HARDWARE DEBUGGING [message #195542 is a reply to message #195534] Fri, 06 July 2007 13:30 Go to previous messageGo to next message
Hello Doug,
sorry for me looking like the fool here, but it looks like I am living on a
different planet.
What do you mean exactly by:
Where is it exactly?
I looked at properties, preferences and manage configuration. Null.
I search through the eclipse dirs: no file naming GDB***.
So, different planet?
By the way, the cdt internet page is not looking the standard way like most
other pages are made. One of the 2 links does not have a meaning.
I am wondering whether other users are experiencing the same like me.
Any response from other users? -DO YOU SEE THE "GDB Hardware Debugging"
STUFF?
Thanks indeed.
Thomas
Re: missing GDB HARDWARE DEBUGGING [message #195556 is a reply to message #195542] Fri, 06 July 2007 16:31 Go to previous messageGo to next message
T.Schulte wrote:
> Hello Doug,
> on a different planet.
> most other pages are made. One of the 2 links does not have a meaning.
> STUFF?
> Thanks indeed.
> Thomas
How about the update site that you mentioned previously. It's a separate
feature, you don't get it automatically when you install the CDT feature.
Doug
Re: missing GDB HARDWARE DEBUGGING [message #195594 is a reply to message #195556] Fri, 06 July 2007 18:00 Go to previous messageGo to next message
Hi Doug,
This is the cdt update site I am looking at
http://download.eclipse.org/tools/cdt/releases/europa/
CDT Europa Releases Update Site
This update site contains the following CDT releases for Europa based
Eclipse. The Ecilpse Platform Runtime Binary version 3.3 is the minimum
required runtime to run CDT 4.0.x.
Enter the URL for this site in the update manager to download the CDT
features
The CDT master update archive is available for each release as well
4.0.0 (June 26, 2007)
If you're curious, the site.xml file is here.
The first link (http://download.eclipse.org/tools/cdt/releases/europa ) does
not work
The next link (4.0.0 (June 26, 2007) ) works and brings you to the site of
a single choice only.
no GDB choice anywhere
Thomas
Re: missing GDB HARDWARE DEBUGGING [message #195699 is a reply to message #195594] Mon, 09 July 2007 03:57 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
Thomas,
You will not see this if you just look at the website, you have to start the
update and the option will appear in the Eclipse update manager during the
update process. So, just do as instructed (below) and eventually you will be
asked to select the features you wish to install.
HTH
Derek
>> separate feature, you don't get it automatically when you install the
>> CDT feature.
> Hi Doug,
> features
> does not work
> of a single choice only.
> Regards
> Thomas
Re: missing GDB HARDWARE DEBUGGING [message #195737 is a reply to message #195699] Mon, 09 July 2007 05:22 Go to previous messageGo to next message
------=_NextPart_000_0027_01C7C21B.61F5C230
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=response
Hello Derek,
what do you mean by "you have to start the update"?
Normally I click this:
Help ->
Software Updates ->
-> Find and Install (or)
-> Manage Configuration
I follow the complete paths and I tick everything! But the desired options
do not appear.
What am I doing wrong?
My be someone gets an idea when looking at the attached image showing my
"Manage Configuration".
Thomas
"Derek Morris" <dmsubs@NOSPAM.consertum.com> schrieb im Newsbeitrag
news:f6spos$367$1@build.eclipse.org...
> Thomas,
> the update and the option will appear in the Eclipse update manager during
> the update process. So, just do as instructed (below) and eventually you
> will be asked to select the features you wish to install.
> HTH
> Derek
Content-Type: image/jpeg;
name="ManageConfiguration.JPG"
Content-Disposition: attachment;
filename="ManageConfiguration.JPG"
/9j/4AAQSkZJRgABAQEAYABgAAD/4RByRXhpZgAATU0AKgAAAAgAA4dpAAQA AAABAAAIPpydAAEA
AAAOAAAQXOocAAcAAAgMAAAAMgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB6hwABwAACAwAAAhQ AAAAABzqAAAACAAA
dABoAG8AbQBhAHMAAAD/4QtdaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4w LwA8P3hwYWNrZXQg
YmVnaW49J++7vycgaWQ9J1c1TTBNcENlaGlIenJlU3pOVGN6a2M5ZCc/Pg0K PHhtcDp4bXBtZXRh
IHhtbG5zOnhtcD0iYWRvYmU6bnM6bWV0YS8iPjxyZGY6UkRGIHhtbG5zOnJk Zj0iaHR0cDovL3d3
dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIyI+PHJkZjpEZXNj cmlwdGlvbiByZGY6
YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgy ZjFiIiB4bWxuczpk
Yz0iaHR0cDovL3B1cmwub3JnL2RjL2VsZW1lbnRzLzEuMS8iPjxkYzpjcmVh dG9yPjxyZGY6U2Vx
IHhtbG5zOnJkZj0iaHR0cDovL3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYt c3ludGF4LW5zIyI+
PHJkZjpsaT50aG9tYXM8L3JkZjpsaT48L3JkZjpTZXE+DQoJCQk8L2RjOmNy ZWF0b3I+PC9yZGY6
RGVzY3JpcHRpb24+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6 ZmFmNWJkZDUtYmEz
ZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczp0aWZmPSJodHRwOi8v bnMuYWRvYmUuY29t
L3RpZmYvMS4wLyI+PHRpZmY6YXJ0aXN0PnRob21hczwvdGlmZjphcnRpc3Q+ PC9yZGY6RGVzY3Jp
cHRpb24+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJk ZDUtYmEzZC0xMWRh
LWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczpleGlmPSJodHRwOi8vbnMuYWRv YmUuY29tL2V4aWYv
MS4wLyI+PGV4aWY6RGF0ZVRpbWVPcmlnaW5hbD4yMDA3LTA3LTA5VDA5OjE5 OjIzWjwvZXhpZjpE
YXRlVGltZU9yaWdpbmFsPjwvcmRmOkRlc2NyaXB0aW9uPjwvcmRmOlJERj48 L3htcDp4bXBtZXRh
Pg0KPD94cGFja2V0IGVuZD0ndyc/PiAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAg
ICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgIAogICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAg ICAgICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAg
ICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAg
CiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAK ICAgICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAg ICAgICAgICAgICAg
ICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAg
ICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAogICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAg ICAgICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAg
ICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgCiAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAg ICAgICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAg ICAgICAgICAgICAg
ICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAg
ICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IAogICAgICAgICAg
ICAgICAgICAgICAgICAgICAg/9sAQwAGBAUGBQQGBgUGBwcGCAoQCgoJCQoU Dg8MEBcUGBgXFBYW
Gh0lHxobIxwWFiAsICMmJykqKRkfLTAtKDAlKCko/9sAQwEHBwcKCAoTCgoT KBoWGigoKCgoKCgo
KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo/8AA EQgEVgNWAwEiAAIR
AQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIB AwMCBAMFBQQEAAAB
fQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBka JSYnKCkqNDU2Nzg5
OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SV lpeYmZqio6Slpqeo
qaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX2 9/j5+v/EAB8BAAMB
AQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQEAwQHBQQEAAEC dwABAgMRBAUhMQYS
QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4 OTpDREVGR0hJSlNU
VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5
usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQAC EQMRAD8A6LwP4S8L
XPgGx1fXLHfI2/zZvNlH/LVlBIVsAAYycYAGT3Na7eFPh8kqRtYn513rIJbg xlePmDg7do3DJzgZ
GaPBLSJ8H7ExIjjLiRZPuGM3DBw3Bwu3dk4OBk1ZtIdU0zX4wI0n0iZZVubl bjdFHE2BOTP8rJKr
IMnH7zGThw71OGw1J0YNwTul0XY9nOM4x9PMMRThiJpKckkpSslzO2ly5D8N fB8qK8elB0YAqy3U
pBHqPnqrN4I+H8N+tjLBZpesQBbtqEgkJPTC78810vg0NHZ3UPlQw28Vy6QJ BIZI1TgkKxAJAYuO
gxjHasTULG61TXfENjFHbC1lltjJO8h3x7VVvkTbgnjqWGOvOK2eFoJpezX3 I89Z3mTV/rM//A5f
5gfhp4Rz/wAgn/yZm/8Ai6d/wrLwiR/yCP8AyZm/+Lqh/a+orAtxeaw9taTa hNbPP5UQW2jRnC8l
SMsQF3NkYxxnmnR+Irlvs8V5rRs9MMlwI9W8uMfadm3YuWUpzl+QPm2cYpfV aH8i+5D/ALazJO31
mf8A4HL/ADLdr8NvBtzEskGmpLGejpdysDjg8h/WnSfDLwkvTSf/ACZm/wDi 6ytE8QvpHh+Jbi9W
FH02aW23xhTJOJX+6CMluV+X9K1bTV5r7Unt9Q1ptOnCxC3tVEKm5Vo1bzBv UliWLDC4A29KlYeg
/wDl2vuXmv0D+2sytf6zP/wOXl5+ZEPhr4Tz/wAgof8AgTN/8VTLPwD4FvJ5 4LW0t554DtljjvpG
aM+jAPkdD1pPDa3D+ALm3sb17i+WKWJQWQNDJg/J8oGCDzzzzVmDWNJg8OKd BW0fVbK0bybcRbpr
fgb9yD5lweoOMkY6mq+rUFryL7kH9tZl/wBBE/8AwOX+Y4/DDwl20n/yZm/+ LqC7+Hfgmyt2nvbG
G3gXG6SW8lRRk4GSXxUd3r14tteLo2vDU4QlsVvWiifyZHmVCh2KqnKknafm HryKZqn264vY7C41
W5c2esQpHOI4Q5DQhxkbNuQSccDrzml9Xof8+19y7pfqP+2cytf6zP8A8Dl2 v3Iz4C8GzQ+bZ2EU
0eSu+O7lYZBwRkP2NMt/h94WdsNpX/kxL/8AFVWm8QXcoVb/AFY2EY+1FJxE mZnSdkWMZUg4UD5Q
NxzVRPFF5a6LcTXV6sd1JpcVxa5jUF5Tv3lRjn+HI6Ac8DNUsNQf2F9y/roH 9s5lt9Zn/wCBy/zO
kHwz8Jlc/wBk/wDkzL/8XUZ+G/hPP/IJ/wDJmX/4uludV1COLXbiTUZkhgu4 7SBEEUaRbkjYu8jI
2FG48kHAJ4JxjK0y+uNRutBvb/VwFjvbm2E8bRGOTAO0bjGAS33cgLkdADzS +r0P+fa+5f11J/tr
MrX+sz/8Dl/maVt8PfBlzbrPb6fHNC/KvHdysrfQh6p3ngDwsh/d6Xj/ALeJ f/iqQ+IbuS1hOo6z
/ZgNl50Mnlxf6VJvcMPmUg7QE+VcE7qp3eqavJHd3cly1q1rDbStaCJCCzgF 1YkFsdRwQR61LoUP
5F9yG86zJO31mf8A4HL/ADLNr4C8LucPpef+3iX/AOKrRX4b+Eymf7K/8mZf /iq27eEh844rUHCV
vHC4dr+GvuRm87zJf8xM/wDwOX+Zx3/CuPCmf+QV/wCTEv8A8VTZPh34TQc6 V/5MS/8Axdddnmqt
+SEOK0WCw7dvZr7kQ89zJf8AMTU/8Dl/mcdL4F8JqTjSx/4ES/8AxVLB4D8K yH/kF/8AkxL/APFV
dnlfe3Wr2mFmPNXPLKC1UF9yIjxBmTdvrFT/AMDl/mY8/gLwnEOdK/8AJiX/ AOLog8A+FJRxpX/k
xL/8VXU3VuZQMUtpbmLqKj6nh/8An3H7kV/bmZ/9BNT/AMDl/mcjc+A/C0R/ 5Bf/AJMS/wDxVVj4
J8MdtM/8jy//ABVdVqUbMTiqEULkjPrU1cDQUbqC+5DhnuZN2eJqf+By/wAz Mg8BeGHGTpf/AJMS
/wDxVRTeCfCsb7f7L/8AJiX/AOKrrrSMqvNQXFkZJd2P0p08HQcdacfuQSzz Mk9MTU/8Dl/mYEPg
HwtImRpf/kxL/wDFU2XwF4WQH/iWf+TEv/xVdZBF5ceKpahuKnFaLA4du3s4 /ciHnuZr/mJqf+By
/wAzlj4I8Ml8Lpn/AJHl/wDiqtr4A8L+XubS/wDyYl/+KrRtUbzPmFbQTdER 7Unl+Hi/gX3Iaz7M
2v8Aean/AIHL/M4weC/Cpk2/2V/5Hl/+Kq23gDwsI939l/8AkxL/APFVtrYk SlsfpVyeM/Z9o60f
U8P/AM+4/cgee5n/ANBNT/wOX+Zws/g3wwjYGmj/AMCJf/iqdb+C/DMjY/s3 /wAjy/8AxVad7FIH
4BqxpcD7ssKxeDot6U19yMocQZnezxNT/wADl/mZ8vgPwvGm46X/AOTEv/xV Qw+CvC0jYGl/+R5f
/iq7C4h8yLAqta2RjfOK2+pYf/n3H7ka/wBu5n/0E1P/AAOX+Zif8K+8L4z/ AGZ/5MS//FUz/hX3
hj/oGf8AkxL/APFV1pGBTRR9Tw//AD7j9yD+3cz/AOgmp/4HL/M4LVPBnhy2 U+XpmD/13k/+KrJs
vDOgSzbX0/jP/PaT/wCKr0a+sxODkVzd3YPby5Qd/Ss54TDxX8OP3IuGd5k/ +Ymp/wCBy/zHweAv
C7xhv7Nyf+viX/4qq83gvwtG+3+y/wDyPL/8VXQaQ8hjAepbiyMku7H6VUcJ h2r+zj9yJeeZmn/v
NT/wOX+ZgxeA/DEiZGmf+R5f/iqoXng3w3CcDTf/ACPL/wDFV3EEXlx4rM1K 2LnIFWsFh3/y7j9y
JlnuZr/mJqf+By/zOXtPCHhqRgG03/yPJ/8AFVqjwH4WEe46X/5MS/8AxVWL K0ZZBkGt1YyYdtOW
Cwy/5dx+5Exz3M3/AMxNT/wOX+Zy0Xgnwo77RpX/AJMS/wDxVXB8O/CxXP8A Zf8A5MS//FVs29mV
k3f0rUAwuKj6nh/+fcfuRf8AbuZ/9BNT/wADl/mcj/wrzwvn/kF/+TEv/wAV UV14A8LxRkjS/wDy
Yl/+KrsB1qK9j8yIij6nh/8An3H7kH9u5n/0E1P/AAOX+Z56fCXhkSYOmDH/ AF3l/wDiq0rTwN4V
mA/4lg/8CJf/AIqp7qzcS8Z61raRA6AFjR9Tw/8Az7j9yM459ml7fWan/gcv 8zFuPAnhWHrpf/kx
L/8AFUtv4D8KzdNK/wDJiX/4qunu7YzYp1nb+SKPqeH/AOfcfuRp/buZ/wDQ TU/8Dl/mcbfeCfC8
LYXTMH/r4l/+KqgfCHhwHnThj/rvJ/8AFV12sW7tJuWsZllZguKxnhKF9Ka+ 5HPPP80T/wB5qf8A
gcv8xtj4F8Lzrk6Zn/t4l/8AiqJvBHhSN9v9lf8AkxL/APFV0ejQskY3VLcW Rkl3YrWODw9tacfu
RtHPcza1xNT/AMDl/mc5/wAIF4WMJcaX2/5+Jf8A4qsi78IeG4ydunAY/wCm 8n/xVehJBtgK1g6t
ZMFYqKmeDoW0pr7kKeeZp0xNT/wOX+Zz9l4O8MzEBtOB/wC28n/xVab+APC6 pu/sz/yYl/8AiqoW
88sFwBg4z6V1tpIZ4MH0pQwuHe9OP3I2/tfNYxvLE1P/AAOX+Zyw8GeFjJt/ ss/9/wCX/wCKq4nw
/wDC7Ln+zP8AyYl/+KrYWxIlLY/StKNdq4rX6nh/+fcfuRH9u5n/ANBNT/wO X+Zyn/Cv/DGf+QZ/
5MS//FUybwD4ZRcjTP8AyPL/APFV1veo7gFk4oWCw/8Az7j9yE89zP8A6Can /gcv8zi/+EI8N5/5
Bv8A5Hk/+KqeDwJ4afrpn/keX/4qteUOG4q5YK3enLBYbpTX3ImOfZn1xNT/ AMDl/mY3/CvfC+P+
QZ/5MS//ABVIPh94Y/6Bn/kxL/8AFV1h6UzsaX1PD/8APuP3Iv8At3M/+gmp /wCBy/zOLvvA3hmG
MlNM5/67y/8AxVYLeHPDyS7W04Yz/wA9pP8A4qu91AM2RWI+nGWQHHf0rndL DxfL7KP3I0ecZo43
WJqf+By/zINP8F+F7hATpn/keX/4qrEvgTwuvTTP/JiX/wCKrd0y0MMX4VHd s4c4onh6EY39nH7k
TTzrM3o8TU/8Dl/mYK+BvDJb/kGj/wACJf8A4qrkfw+8LMP+QZ/5MS//ABVa ERZmHWta2BCc1dOh
hp/8u19yHLOczj/zE1P/AAOX+Zy83gLwrGP+QZ/5MS//ABVUj4J8MlsLpo/7 /wAv/wAVXW30bMvF
U7SBvM+aplhKMvhpr7kOOeZkt8TU/wDA5f5mVB8P/DLgbtM/8mJf/iqe3w98 Ljppn/kxL/8AFV1c
abQKG61tHBYe2tOP3Ih57mX/AEE1P/A5f5nKH4feFwM/2Z/5MS//ABVUZvBP hiNsf2Z/5Hl/+Kru
G+7WPexlmGB3qo4HDN/w4/ciJZ9maX+81P8AwOX+ZhW/gbwzKf8AkGf+R5f/ AIqrEngDwuq5/sz/
AMmJf/iq2dPUqRmr1zny6HgcOn/Dj9yCOfZm1/vNT/wOX+Zxj+CfDIPGm/8A keX/AOKp0Hgjww5w
dM/8jy//ABVa85YE8GlsVcyc1f8AZ+Gtf2cfuRP9v5nf/ean/gcv8yp/wr7w uRn+zP8AyYl/+Kpv
/CvvDGf+QZ/5MS//ABVdYg/d00daz+pYf/n3H7kaf27mf/QTU/8AA5f5nH3X gTwvDGW/sz/yYl/+
KrmbnQvDkVxsGnDGf+e0n/xVelarEZICFrgbvSpnvM84zXRSwGEa96nH7kH9 u5n/ANBNT/wOX+Zp
aX4L8MXcYY6ZnP8A03l/+KrS/wCFe+F8f8gv/wAmJf8A4qrvh+2aCJd1bhPF YTwWGT0px+5B/buZ
/wDQTU/8Dl/mcuvw88LH/mF/+TEv/wAVVe58B+FohxpmP+3iX/4quyjPNZ+q xMyHbSWCw7/5dx+5
Eyz3M0tMTU/8Dl/mcW/hLwusm3+zh/3/AJf/AIqtSy8BeFp1ydL/APJiX/4q oFs5nuec4zXXaXCY
ohn0pvBYdL+HH7kKGe5p1xNT/wADl/mYDfDvwsOml/8AkxL/APFUh+HnhYKT /Zf/AJMS/wDxVda9
IRlTU/U8P/z7j9yL/t3M/wDoJqf+By/zOIk8CeGFbA0z/wAjy/8AxVSxeAPC zddL/wDJiX/4qt+4
B8zipYQeKyhgqXNrTX3IuWe5jbTE1P8AwOX+Zgt8PfCoUn+y/wDyYl/+KqoP BHhQybf7K/8AJiX/
AOKrtdu6Mj2qktiRLuxWv1PD/wDPuP3In+3Mz/6Can/gcv8AM8g+LPh7StCX STpFr9n8/wA3zP3j
vu27MfeJx1NFa3x3XauhD/rv/wC06K+QzSEYYqcYKy0/JH7XwjXq4jKKNWtJ yk+a7bu/il1Z3Pwl
RZPhvpaSKGRhMCpGQR5r8GtdPDtvFLCbe6voIIY2hSCOUBVRipZQcbgCVXoe McYrC+DNrDfeFbKK
7kuhFFah0WG6khG5rm5DE7GGeEXr6V295Y6BZbPtt9dW+/O3zdYuE3Y64zJX 0mFqWoQVui/I/Hc6
pc2ZYh/35/8ApTG2FvBY2sVtaxLFBEu1EUYAFSSHdQmm6G5AS8vGJYIANXuD liNwH+s645+lT/2F
pn/PTUv/AAaXP/xyt/aeR5ns/Mp7OalU7RU/9haZ/wA9NS/8Gdz/APHKP7C0 z/npqX/gzuf/AI5T
9r5B7N9yIS4pkj7uoqx/YWmf89NS/wDBnc//AByk/sLTP+empf8Agzuf/jlL 2i7D9m+5UAGelPWU
LVj+wtM/56al/wCDO5/+OUf2Dpf9/Uv/AAaXP/xyj2i7C9m+5AZ6QzZFWP7B 0v8Av6l/4NLn/wCO
Uf2Dpf8Af1L/AMGdz/8AHKPaLsHs33Of1fTpL9dqahd2iFSrCAR/MD6l0Yj8 MVYsLSCxtYba2QJD
CgRFHYAYFbH9g6X/AH9S/wDBnc//AByj+wNL/v6l/wCDO5/+OU/aLsHs33Kf n4FIbirn9gaX/f1H
/wAGdz/8co/sDSv7+o/+DO5/+OUe1XYPZPuZk0u8VUKjd0re/sDSv7+o/wDg zuf/AI5R/wAI/pX9
7Uf/AAZ3P/xyk6kXug9k+5lxMoHSntKMVo/2BpX9/Uf/AAZ3P/xyj+wNK/v6 j/4M7n/45VKsl0Jd
FvqZW8Zpk2JFwRWx/YGlf39R/wDBnc//AByj+wNK/v6j/wCDO5/+OVSxFugv YPucu9krEnbU9vAs
XQV0P9gaV/e1H/wZ3P8A8co/sDSv72o/+DO5/wDjlU8W3pYX1bzMnzBSeYK1 /wCwNK/vaj/4M7n/
AOOUf2BpX97Uf/Bnc/8Axyp+seQ/YPuYkgV+oqPYi9q3/wCwNK/vaj/4M7n/ AOOUf8I/pX97Uf8A
wZ3P/wAcp/WPIPq77mEGUdKXeK3P+Ef0r+9qP/gzuf8A45R/wj+lf3tR/wDB nc//AByj6wuwvq77
mGXGKgkVX6iuj/4R/Sv72o/+DO5/+OUf8I/pX97Uf/Bnc/8Axyj6z5B9Xfc5 lIkU5ANWFYAVvf8A
CP6V/e1H/wAGdz/8co/4R/Sv72o/+DO5/wDjlH1nyD6u+5h7xSF1Ird/4R/S v72o/wDgzuf/AI5R
/wAI/pX97Uf/AAZ3P/xyj6z5B9Xfc5uSCNznFPjjSPoK6H/hH9K/vaj/AODO 5/8AjlH/AAj+lf3t
R/8ABnc//HKX1hdg+reZg7x6Um8elb//AAj+lf3tR/8ABnc//HKT/hH9J/va j/4M7n/45T+s+QfV
33MAuCKaHFdD/wAI9pP97Uf/AAZ3P/xyj/hHtJ/vaj/4M7n/AOOUfWfIPq77 nP7xjpUE0SSdRXT/
APCPaT/e1H/wZ3P/AMco/wCEe0n+9qP/AIM7n/45S+sJ9B+wfc5iKNI+gqbe PSuh/wCEe0n+9qP/
AIM7n/45R/wj2k/3tR/8Gdz/APHKPrC7B7B9znvMHpUb7W6iul/4R7Sf72o/ +DO5/wDjlH/CPaT/
AHtQ/wDBnc//AByn9Y8hfV33OYREXoKnGO1dB/wj2k/3tQ/8Gdz/APHKX/hH 9K/vaj/4M7n/AOOU
fWPIPq77mCrAdak8wEVtf8I/pX97Uf8AwZ3P/wAco/4R/Sv72o/+DO5/+OUv rHkH1d9zD3jPSlLg
jpW3/wAI/pX97Uf/AAZ3P/xyj/hH9K/vaj/4M7n/AOOU/rC7B9Xfc55oo2bJ FSJsQcCt3/hH9K/v
aj/4M7n/AOOUf8I/pX97Uf8AwZ3P/wAco+sLsH1fzMXePSjzB6Vtf8I/pX97 Uf8AwZ3P/wAco/4R
/Sv72o/+DO5/+OUfWF2D6u+5gyqsg5FVxaRhs4rpv+Ef0r+9qP8A4M7n/wCO Uf8ACP6V/e1H/wAG
dz/8cpfWF2D6tfqYUe1BgCn+YPStr/hH9K/vaj/4M7n/AOOUf8I/pX97Uf8A wZ3P/wAco+sLsH1d
9zF8welRTBJFIIrf/wCEf0r+9qP/AIM7n/45R/wj+lf3tR/8Gdz/APHKPrC7 D9g+5xkumRmTdtq3
AiwjAFdR/wAI/pX97Uf/AAZ3P/xyk/4R/Sf72o/+DO5/+OUlXS6FOlKSs2c9 vHpS7x710H/CPaT/
AHtR/wDBnc//AByj/hHtJ/vaj/4M7n/45VfWPIj6u+5zu4ZoLAiui/4R7Sf7 2o/+DO5/+OUf8I9p
P97Uf/Bnc/8Axyj6z5B9Xfc5lokY5Ip6BU6Cuj/4R7Sf72o/+DO5/wDjlH/C PaT/AHtR/wDBnc//
AByj6wuwfV/M58uMd6TeK6H/AIR7Sf72o/8Agzuf/jlH/CPaT/e1H/wZ3P8A 8co+s+QfV33ObdEf
qKasSKeldN/wj+k/3tR/8Gdz/wDHKX/hH9J/vaj/AODO5/8AjlT7aL15R+xf c54MoGMVE8SMc4rp
v+Ef0n+9qP8A4M7n/wCOUf8ACP6T/e1H/wAGdz/8cpuun0BUH3OaSJF7VMGA HSt//hH9J/vaj/4M
7n/45R/wj+k/3tR/8Gdz/wDHKFXS2iDoN9Tn2ZSOaauwHiuh/wCEe0n+9qP/ AIM7n/45R/wj2k/3
tR/8Gdz/APHKPrC7B7B9zC8wU0yCt/8A4R7Sf72o/wDgzuf/AI5R/wAI9pP9 7Uf/AAZ3P/xyn9YX
YX1d9zALqRiq7orHpXT/APCPaT/e1H/wZ3P/AMco/wCEe0n+9qP/AIM7n/45 R9ZXYPq77nMxoqnp
UrlWGK6H/hHtJ/vaj/4M7n/45R/wj2k/3tR/8Gdz/wDHKPrK7B9Xfc5V4EY9 KkiiSPoK6b/hHtJ/
vaj/AODO5/8AjlH/AAj2k/3tR/8ABnc//HKf1ryF9W8zA8wYpu9c5rof+Ee0 n+9qP/gzuf8A45R/
wj2k/wB7Uf8AwZ3P/wAcpfWV2H9Xfc55nVhg1XaCEtnFdT/wj2k/3tR/8Gdz /wDHKP8AhHtJ/vaj
/wCDO5/+OUfWfIPq77nOIUQcCneatdD/AMI9pP8Ae1H/AMGdz/8AHKP+Ed0n 11H/AMGdz/8AHKPr
C7B9XfcwElUU5mRxg1u/8I9pP97Uf/Bnc/8Axyj/AIR7Sf72o/8Agzuf/jlH 1hdg+rvuc+sUIOcD
NTqygcCtn/hHtJ/vaj/4M7n/AOOUv/CP6V/e1H/wZ3P/AMco+seQfV33MVnB 7UBxjpW1/wAI/pX9
7Uf/AAZ3P/xyj/hH9K/vaj/4M7n/AOOUvrHkP6u+5gMisc04BR2rd/4R/Sv7 2o/+DO5/+OUf8I/p
X97Uf/Bnc/8Axyn9Z8hfV/MxlYCl3itj+wNK/vaj/wCDO5/+OUf2BpX97Uf/ AAZ3P/xyl9Y8h+wf
c8P+PLbv7D/7b/8AtOirf7ROn2tj/wAI/wDZDcnf9o3eddSTdPKxjexx1PSi vkM0lzYqb9PyR+68
Gx5cmoL/ABf+lyN/4Mux8OwqpI22cfQ/9PN5XVamt02uaeLadY5PJm+aRC4x lOwYfzrkfg67xeH7
YxwvLvskztSRsYubv+6revfFegfaZ/8Anzm/78T/APxqvo8K17GF+y/I/JM5 X/CjiP8AHP8A9KZh
3NxcyapHHJIz+TfKqDpj/Ryf5k07w1f3t5I5ur2F2KbmgWYGSJs8grtBUduS 3bmtr7TP/wA+c3/f
if8A+NUfaZ/+fOb/AL8T/wDxqtlJLqea0S/vP77/AJ0fvP77/nUX2mf/AJ85 v+/E/wD8ao+0z/8A
PnN/34n/APjVVzxFZkv7z++/50fvP77/AJ1F9pn/AOfOb/vxP/8AGqPtM/8A z5zf9+J//jVHPELM
l/ef33/Oj95/ff8AOovtM/8Az5zf9+J//jVH2mf/AJ85v+/E/wD8ao54hZkv 7z++/wCdH7z++/51
F9pn/wCfOb/vxP8A/GqPtM//AD5zf9+J/wD41RzxCzJf3n99/wA6P3n99/zq L7TP/wA+c3/fif8A
+NUfaZ/+fOb/AL8T/wDxqjniFmS/vP77/nR+8/vv+dRfaZ/+fOb/AL8T/wDx qj7TP/z5zf8Afif/
AONUc8QsyX95/ff86P3n99/zqL7TP/z5zf8Afif/AONUfaZ/+fOb/vxP/wDG qOeIWZL+8/vv+dH7
z++/51F9pn/585v+/E//AMao+0z/APPnN/34n/8AjVHPELMl/ef33/Oj95/f f86i+0z/APPnN/34
n/8AjVH2mf8A585v+/E//wAao54hZkv7z++/50fvP77/AJ1F9pn/AOfOb/vx P/8AGqPtM/8Az5zf
9+J//jVHPELMl/ef33/Oj95/ff8AOovtM/8Az5zf9+J//jVH2mf/AJ85v+/E /wD8ao54hZkv7z++
/wCdH7z++/51F9pn/wCfOb/vxP8A/GqPtM//AD5zf9+J/wD41RzxCzJf3n99 /wA6P3n99/zqL7TP
/wA+c3/fif8A+NUfaZ/+fOb/AL8T/wDxqjniFmS/vP77/nR+8/vv+dRfaZ/+ fOb/AL8T/wDxqj7T
P/z5zf8Afif/AONUc8QsyX95/ff86P3n99/zqL7TP/z5zf8Afif/AONUfaZ/ +fOb/vxP/wDGqOeI
WZL+8/vv+dH7z++/51F9pn/585v+/E//AMao+0z/APPnN/34n/8AjVHPELMl /ef33/Oj95/ff86i
+0z/APPnN/34n/8AjVH2mf8A585v+/E//wAao54hZkv7z++/50fvP77/AJ1F 9pn/AOfOb/vxP/8A
GqPtM/8Az5zf9+J//jVHPELMl/ef33/Oj95/ff8AOovtM/8Az5zf9+J//jVH 2mf/AJ85v+/E/wD8
ao54hZkv7z++/wCdH7z++/51F9pn/wCfOb/vxP8A/GqPtM//AD5zf9+J/wD4 1RzxCzJf3n99/wA6
P3n99/zqL7TP/wA+c3/fif8A+NUfaZ/+fOb/AL8T/wDxqjniFmS/vP77/nR+ 8/vv+dRfaZ/+fOb/
AL8T/wDxqj7TP/z5zf8Afif/AONUc8QsyX95/ff86P3n99/zqL7TP/z5zf8A fif/AONUfaZ/+fOb
/vxP/wDGqOeIWZL+8/vv+dH7z++/51F9pn/585v+/E//AMao+0z/APPnN/34 n/8AjVHPELMl/ef3
3/Oj95/ff86i+0z/APPnN/34n/8AjVH2mf8A585v+/E//wAao54hZkv7z++/ 50fvP77/AJ1F9pn/
AOfOb/vxP/8AGqPtM/8Az5zf9+J//jVHPELMl/ef33/Oj95/ff8AOovtM/8A z5zf9+J//jVH2mf/
AJ85v+/E/wD8ao54hZkv7z++/wCdH7z++/51F9pn/wCfOb/vxP8A/GqPtM// AD5zf9+J/wD41Rzx
CzJf3n99/wA6P3n99/zqL7TP/wA+c3/fif8A+NUfaZ/+fOb/AL8T/wDxqjni FmS/vP77/nR+8/vv
+dRfaZ/+fOb/AL8T/wDxqj7TP/z5zf8Afif/AONUc8QsyX95/ff86P3n99/z qL7TP/z5zf8Afif/
AONUfaZ/+fOb/vxP/wDGqOeIWZL+8/vv+dH7z++/51F9pn/585v+/E//AMao +0z/APPnN/34n/8A
jVHPELMl/ef33/Oj95/ff86i+0z/APPnN/34n/8AjVH2mf8A585v+/E//wAa o54hZkv7z++/50fv
P77/AJ1F9pn/AOfOb/vxP/8AGqPtM/8Az5zf9+J//jVHPELMl/ef33/Oj95/ ff8AOovtM/8Az5zf
9+J//jVH2mf/AJ85v+/E/wD8ao54hZkv7z++/wCdH7z++/51F9pn/wCfOb/v xP8A/GqPtM//AD5z
f9+J/wD41RzxCzJf3n99/wA6P3n99/zqL7TP/wA+c3/fif8A+NUfaZ/+fOb/ AL8T/wDxqjniFmS/
vP77/nR+8/vv+dRfaZ/+fOb/AL8T/wDxqj7TP/z5zf8Afif/AONUc8QsyX95 /ff86P3n99/zqL7T
P/z5zf8Afif/AONUfaZ/+fOb/vxP/wDGqOeIWZL+8/vv+dH7z++/51F9pn/5 85v+/E//AMao+0z/
APPnN/34n/8AjVHPELMl/ef33/Oj95/ff86i+0z/APPnN/34n/8AjVH2mf8A 585v+/E//wAao54h
Zkv7z++/50fvP77/AJ1F9pn/AOfOb/vxP/8AGqPtM/8Az5zf9+J//jVHPELM l/ef33/Oj95/ff8A
OovtM/8Az5zf9+J//jVH2mf/AJ85v+/E/wD8ao54hZkv7z++/wCdH7z++/51 F9pn/wCfOb/vxP8A
/GqPtM//AD5zf9+J/wD41RzxCzJf3n99/wA6P3n99/zqL7TP/wA+c3/fif8A +NUfaZ/+fOb/AL8T
/wDxqjniFmS/vP77/nR+8/vv+dRfaZ/+fOb/AL8T/wDxqj7TP/z5zf8Afif/ AONUc8QsyX95/ff8
6P3n99/zqL7TP/z5zf8Afif/AONUfaZ/+fOb/vxP/wDGqOeIWZL+8/vv+dH7 z++/51F9pn/585v+
/E//AMao+0z/APPnN/34n/8AjVHPELMl/ef33/Oj95/ff86i+0z/APPnN/34 n/8AjVH2mf8A585v
+/E//wAao54hZkv7z++/50fvP77/AJ1F9pn/AOfOb/vxP/8AGqPtM/8Az5zf 9+J//jVHPELMl/ef
33/Oj95/ff8AOovtM/8Az5zf9+J//jVH2mf/AJ85v+/E/wD8ao54hZnkX7Q2 7/iQbiT/AMfHU/8A
XOimftBSPJ/YPmQvHj7RjdHIuf8AV/3lX9M0V8nmbviZW8vyR+4cH/8AIno/ 9vf+lSG+Bpryax0H
S7S6ntYriweWVoHKOdl1OANw5A+c9D2FdfJot6YbiS31XWpVg++RqMwGc4wD u6//AKvXHJ/C/wD5
C3hrIyP7Jm/9LJK7nxZ4QOqyb9PdLczMPPDg4xnJdQP4vbgHrkHOfo8FyckO fay/JH5RmnL/AGli
Ob+ef/pTKllo8t5AJYNc1llzgj+0JsqfQjfwaoWkusah4hv9Bn1a++z6aEKS RzNHJJ5i7hvdSCcd
Bz9a5ltT0iPwX9o0/X9QstaC5WwguCsX3++FGW2ck568cABR2vh/B+KXirAy Nlt/6KFdFej7L8Tx
oVVNvl2K7WaLezWj+IdXSeFd0ge/nVVHy/xFsfxL371NbaZ9plMdt4k1GWQD cVj1SViB643/AEqf
xNP/AGfrV9PaXVlYXclrbgNLDukkzI4O3GT0Cg/K3RemM1u6HetcJbrLf2dz IbWORo40xJkqpLn5
vunOcbB1FTKmlHmX9fgCm27HEafearrA1ZtR1W/WPSJJLb/RpmhMgj6s20jL H3q9rOlXej2X2m81
rVzsglnkjGoSLgRxl2EZMuZCMAfdXrk46U3wWjS/8JskUAndtRu1WJjgOT0U nIxnp1H1pmqXZu9T
WbxGDa3kb2qyw7dkccbTYBVweRjcScnByMjGBz/V6lV80ZWSX4/5G0a0KbSl G93+H+ZStIdU/tOK
Btb1KRJpWtkuIbyVo4rhUd2jBeQiYKEIZwqgNgYOTt9H8K6lcalbW01ywJl0 20uSoAADyCQsf/HR
+Vc34c0yO01k3FhBcSaeQ0cUk2WSFNzELDuf5YyPLPyKQfXjjX8A/wDIO0// ALAun/ylrnwlZ1oc
zTWvX+tjszB0nVXsVZW/E6usPTvEUV3DBJJCYVcHcS2QnJx2GRhSSe3PUK5W /rbSR6TdyQvseOMv
nnkDkjggjIBGQcjORWTJGINctNNS5jW1ki3PAVIeRgGwwYLgY2rjBGNowBgV 1HCdHSMwVSzEBQMk
noKoaErpZuryb0WaRIxjG1VYqB/46T2AzgAAAVZug4KSAF0Q5KDqT2Pvj0/H qBQA+GUS7xsdCjbS
GGD0B/kRUlZokiupJJFsFmOQDJtQ7uB3Jz0Iq5aI0cAVxg5JC/3QSSB+AwKS dwJqiWdWmePDAq20
MejHAOB+B/n6GoLpG+0b2tVuUKgAMFO0gnP3vXI6elRR3IIltY7JY2LcxgBe cA7sr0xxz14HtRcD
Rqlok8lzounzztullt45HbGMsVBJ496txhljUO29gAC2MZPriqHhv/kXNK/6 9If/AEAUwHahqsFj
JsmBAwpLF0Rec4GWYc/Kaqx+JNPaVEeaOMMcbmniIHBPOHOOlQ6q7jxBaLbr FJcnaY45H2K5Edxg
EgEgZIBIBxnoaTUpPED6XfjUNG0u3tfss2+WDUXldf3bYwpgUHnH8Q/HpWyg mrmEqjUrGnrk8lro
uoXEDbZYreR0bAOGCkg81ePU1meJf+Rc1X/r0l/9ANabfeP1rE3Mo3N/cLLN ZJEY0keNImXLSFCV
OW3AJlgR0bjB5ztFmK7kMyJPY3VsHJCtJsIJwTj5WOOAevHHriud1I31jpWr wyWcrwFLqTz0dNm1
97jgsG43AHjqD1HNQa3aWsUOpFbGFI0gnZSLZQFwjEEHyBjBxj5/xPfgoOvN yfbv19NDpqezjZd+
x2lFFFd5zBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFAHiX7Sv/ADLn
/bz/AO0qKP2lf+Zc/wC3n/2lRXzWYf7xL5fkj9t4Q/5FFH/t7/0qRL8LdKur nTdH1HTzA1zaWJTy
p3KK6PdXOfmAJBBRex716PnxF/0DdI/8GMn/AMYrkfgZavd6FEFup7cJZR/6 oId2bq767lPp2r0/
+yJP+gpff98w/wDxuvoKH8KHovyPyPOP+RhiP8c//SmcL/wjeof2x/av9l2f 2/p5v9vXf3d27Zjy
8bM87cbfaprbw5qtjrV1rVv9gmvb4AXNu8rxxptG1Nj7WJ465UZPp0rtP7Ik /wCgpff98w//ABus
2e3kigE0us3MUbDcAYo2OPwT+lbuTlvqeaopbIy7mDXLqFobnR9EmhbG5JL+ RlODnkGCnRR6/FEk
UWl6NHGgCqq6hIAoHQAeR09qitdc0y6vhaQ+Kn+0E7QrQImT6AlADW9/Zd3/ ANBi4/78xf8AxNEl
KOktBnLaT4d1XQrm8msBYXhvpDczrNM8ASVjltuEfK9MZwfrUl3pOqXd/b3t xomjPcwfcc6lL2OR
keRhsHkZzg8jBrQ0XUNO12WaPRPGVrqMkIBlWzlt5igPTcFBx0PWrV8qaf8A 8f8A4lFt+7eb995C
fu0xvfkfdXIyegyM0k3HVA1fRlNh4jcFRY6RGTxv+3SPt99vkjP0yPrV/RdI TSo4o45S6RWcFouR
g4i34P47v0qddNunUMuszspGQRFEQR/3zS/2Xd/9Bi4/78xf/E0gJrqBbm1m gkJCSoUYr1wRjis2
TQ1k1CK9e+uzdRrsR/3fA57bMdzVt9NukUs+szqqjJJiiAA/75rCGv6EdLOp Dx5pv9nCXyDdfabX
yvMxnZv6bsc4znFAHR2duLWARK7yfMzlnxklmLHoAOpPapqx7dobm2s7i38U JLb3jbbaWMwMs5wT
hCBhjhWPGeAfSprSIXJkNvr0l0sU3kS+T5JMcgIBU4U4IyMg80AaCIibtiqu 47jgYyfWnUf2RJ/0
FL7/AL5h/wDjdH9kSf8AQUvv++Yf/jdABTVRFdnVVDNjcQOTj1p39kSf9BS+ /wC+Yf8A43R/ZEn/
AEFL7/vmH/43QAVX022+xadaWu/f5EKRbsY3bVAzjt0qx/ZEn/QUvv8AvmH/ AON0f2RJ/wBBS+/7
5h/+N0AQXdpFdrGJt/7t96MkjIytgjIKkHoT+dV5dKt5Y3jlkvXjcFWVr2Yh geoI3Vf/ALIk/wCg
pff98w//ABuj+yJP+gpff98w/wDxundisitqdr9u027tN+zz4ni3Yzt3AjOO /WrR5JNJ/ZEn/QUv
v++Yf/jdH9kSf9BS+/75h/8AjdIZFd28V3azW1wu+GZGjdckZUjBGRz0qtca Rp9ysoms4WMqsjsF
wxDAhvmHPIJq9/ZEn/QUvv8AvmH/AON0f2RJ/wBBS+/75h/+N0XsAUUf2RJ/ 0FL7/vmH/wCN0f2R
J/0FL7/vmH/43QAUUf2RJ/0FL7/vmH/43R/ZEn/QUvv++Yf/AI3QAUUf2RJ/ 0FL7/vmH/wCN0f2R
J/0FL7/vmH/43QAUUf2RJ/0FL7/vmH/43VF7OdZ5EGpXeFPHyxf/ABFAHkH7 Sv8AzLn/AG8/+0qK
g/aLhkh/4R7zLmafP2jHmBBj/VdNqiivmsw/3iXy/JH7bwh/yKKP/b3/AKVI 7L9n8Y8PRn1so/8A
0qu67zxj4ksfCmg3Gq6mzeTHhVRfvSOeFUdhk9zwO9cD+z82dBVfSyi/9Kru vWK+gofwoei/I/I8
4/5GGI/xz/8ASmcN8IvFGoeLtB1DUtTWFcX7xQCEfIIgkZAB/iwWYbu+O3Ss zx3qjaZFBM8nlwi3
VSWZgOc56I3t2r0ysS/0OO9hMFzFDPDjGHYjI/KuinJQkmzz0z5W17U9CluC f7RHnM2RsuZQd2e2
LU19QaHNN/YGn/a932j7LH5uTk7tgzk4GefYfQVhaf8ACrwxYaqNStdEtFvF bcrtM7hT6hWyB+Ar
rfsE3on/AH8P/wATXRjK8a8VGP4mcYtO7PF/A/i24tPhRALHxBol5cWlraq0 VnDmbTYSwWWSYea+
4opLfdQZU5BHFWvEmt/ZzZ6poviI61LbaFrEsGpbreX518gj/VIsZ2kdNvbn NetRWxm3+VJDJsYo
22XO1h1B44PtUn2Cb0T/AL+H/wCJrlbu2/X8rGqdpXseR3fjHUx4l1C2XxGs d3BfWUVlo4gh3XaS
RQGXORvYDe7ZQjZyWJGAGaj421a1svFYstZTUdQtJEO+CW3ls7GFrjYTlIjJ HIkeSwlDgbSw3gEV
6fp3hsWGoapeQsWl1CZZ5Q0uQrLGsY2/L0wg655zWh9gm9E/7+H/AOJpdv67 f1/kStPwOB0W8TX/
AIbarF4l12wv7KVJ4ZtQ0+9juAkRXktIkUablBOf3YAAGc8k8zceL7aW60O4 1TVNHuLHTtcjj/ty
3ZYra4U2c+AWLFQyk4OGIywxjO0eyfYJvRP+/h/+Jo+wTeif9/D/APE07639 PwBbW9fxR4j4hiu7
2QXPhOVLaHUfEnn2EwXakrfYJBJLGecB2DYkwRn5wGB59S8F3+nXmgWkekwt axWzrBJaP/rLaRWG
6OTk/MD1OTnO7JBBO59gm9E/7+H/AOJp8NjIsilyoUEHhiehz6D0pLRW/rZI JatP+t2/6/q2jRRR
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUU
UUAFFFFABWRduY5rp1jeVlG4RoQGcgdBkgZPTkge9a9YF1duL+6WC0nuPLYK 7RlAAdoOPmYdiKAP
nv4zP4llOmS+KIrOASy3D2tvbkN5CYiGwv8Ax9Ad2Bks3QYAK2f2ibl5zoAe 2lgKfaP9YyHP+q6b
WP60V81mH+8S+X5I/beEP+RRR/7e/wDSpHZfs/LjQFb1sov/AEqvK9Yryn9n 858OxD0so/8A0qu6
9Wr6Ch/Ch6L8j8jzj/kYYj/HP/0phRRRWp5xyt14402LxxYeF4A9xfXBcSvG RstysbSBWPdiFPA6
ZGeozu61BdXOl3MOnzrBdMuI3bIGfQkcjI4yORnI5FYej+APDWj62NX0/Tmj 1AM7iVrmWTDPncQr
MQCdzc47muppp2dwWh5DpWqa9pGtXNxJpUsSqBEbOK2mImIGNzFFk2qOcOAQ xBC5G4j0PwnrU+uW
d1Lc2LWUkE/k7CX+b5Ebd86Iw+9jle1Pv9Ov31R7uwvreASQpEyTWpl+6zkE EOuPv/pU+i2E9it2
13cx3E1xN5xaOIxqPkVcAFm/u56962qVVUjdrUmTnOpzN6HP6pE+v+NbnRry 9vbXTrOxhuhDZXMl
q9w8jyKWaSMq+1RGPlVgCXO4H5cO146jptkzwR3Ys9FEN2lw92Xa8jG8TROP vNtj5BbO5ip6gmtf
XvDWl67LbzahFOtzb7hFc2t1LazIG+8okiZX2nAyucHAyOBUum6Fp2mzyzWc BWWaGO3kd5HkLpHu
25LE5PzsSepzyTXPstNynq/L+rnmXxCvJ7jxnf2+m3PiF7/+xbabSY9LkuvI Fy004V5RGfK2nCZM
3ylQfSulv/HF9ZXWtxHR4ZU02e2sVkF5tNxdTiHYu3YdiZm+ZiSQBkK2cDpN E8O2GjyJLarK062y
WYlkkLN5KMzInphd7AHGcdSaS88NaReQ6rFc2YdNUkSW6/eMC7qqqrAg5RlC JgrggqCOearbT+t/
8v0He7u/L8l/kc+3jLVEY6c+h23/AAkP21bNbZb8m2OYTN5nn+VuC7Fbjy87 hjGPmqHSvHd/qWoa
XZR6HDFPdT30dx5t9hbdbWZInYERncTuJA45ABIByLmt+DrVPD4stH0tLyb7 Ut1vvNYurebzANvm
/alEk28LhRz935c44p3gbwXb6HpNgNQigl1SH7UzPEzmNPtMvmSIu4/MuQo3 MMnbnjJFJf193+f9
dAdtP67/APAMGH4pTPbatJ/YnntaNaG3NvPKI7uO4n8lWR5oYwf7wK7kIIw/ erZ8eavb3FymoeHb
WGKw1C30+/ki1IybGnMflvEDEPMGJkLbthHON2K2rHwD4csoZIoLKYo4gUiW 8nlIWGTzIlUs5Kqr
chRgdsY4rSufDek3P27z7Td9uuYbu4/eON8sWzy24PGPKTgYBxznJy1ZWv8A 1t+lxb3OQ+JL3Enj
Hw1Zpa6/fW0treySWmj6kbJ2ZTAFdm86IEDcwxuP3ulQX2tMniaxs7X7faJb a/FbXHmX0kvnKdNe
XBBJAAyuVBILLu6nNehTabaTapa6jLFuvbWOSGGTcRtWQqXGM4Odi9R2471T fw3pL6ib9rTN2btb
4v5j/wCuWHyQ2M4/1fy46d8Z5pLRf13v+RV117NHDaT8UL7VNJutQtfC159n 8uKa0d0ukR43cLul
c2wC4Vg58rzhgMc4GT0Ph7V5G1YS3N1bTWur2gvrc214bqBHjCrKsTlVyhUx sMAZO84qxa+BtEs7
a4t7L+1bW2m/5Y22r3cUcQ3bsRKsoEQz2QKMcdOK0E8PWENnpdtarLBFpsgk t9shZgdpUhmbJbcG
YMTknJOc80PbT+v63Je77HE6L8U5NS02e/fw7ew20iwnT2ZJ0Fw00ixxo7yQ oikl0OY2lGNxycDJ
4y1vVdPvLSfWYBAI9E1W5nsdP1OXy5fL8griUJGwbBbDBcruOK6e28C6BbWd 5ZxW1z9hukMb2jX0
7QRgtu/dRFykRB5BjCle2Klfwbostotvcw3d0gt7i03XV9PPJ5U+3zVLu5Y5 2r3yMcYo/wCD+T/r
9CotKV3tf+v6/EwZvHd7BfX6R6GjaVptza21zdPfYk/fpEwKIUO8qZRuBZeA CCxJUR3nxGksbPXL
i80uFJLGZYILJbiRryUvN5MbyQ+TlI2OCGTzMjO0MRir1h4Dsx4p1fVtRQyr NdwXFpEl1MEAihiR
fNiBCOyvGWUsGxwQQa0pvBWh3C6kLu3ubv8AtBds32q9nnKgNvAjLufKw2GH l7cEKR90YH0/rt/w
f+CStEr+X/B/r8ibwZrdzr+jfa73TZtOuFlaNoZI5lBx0ZfOjjcqQRyUXnI5 xk7tUdG0u30iz+zW
kl5JHuL5u7ya6fJ/25WZscdM4q9TduglfqFFFFIYUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABR
RRQAUUUUAFFFFABWDb/8fusf9fQ/9ExVvVg2/wDx+6x/19D/ANExUAeHftCn /SNG+tx/7Too/aE/
4+dG+tx/7Tor5rMP94l8vyR+28If8iej/wBvf+lSO2/Z9B/sIen2KL/0pu69 Zryn9n/H/COxev2K
P/0qu69Wr6Ch/Ch6L8j8jzj/AJGGI/xz/wDSmFFFFannBRRRQAUUUUAefeIr 22tbWW4vYGuNQmup
oYOVSRVR2AKMQSgVVByo+8QerE1q6LrRurvTvJ1C5uFu+WguokR0Ty2YOAqq eoA3cryRycVh+KvD
EukXEmr6Qtzei5umkvIPJErKGDEGMKN2AzAEYY4OcgA5u6R4Rvb3SdPj194r YwW8SeRAElbciEZZ
mUr/ABMCoU8gENXLicNKjThLD+9K+utr+uv+e5pSq885KporaHYavfw6VpV5 f3RxBawvM/8AuqCT
/KuZ0bxiLfw1d3/jI2+mXNhcJb3nlhjHGZChj9TgiVAT0znoBxr+LtCHiTR/ 7Mlupbe1kmje48os
ryxqwYxhlYFN2ACwOcZ9a4bxj4EfTtPv7jw7c6lLJey6ekkM809/JvivI2Eo aV2bCqXyvTAzxg11
LfXrp/wf0/4GpHb+v67/ANWOyh8Y6PPplxfwHUZYreYW80UemXLXETkAgNAI /MHBByVxgg9DSt4w
0QjTfIuZ7o6hEs9utpaTXDGNsBZHEaMY1JONz4HB54Nc7qnw/vdVtJW1PVdP u764vlu7lJ9ML2Uy
rF5Sxm3MuSF4cEufnGccACzofgm+8Otpb6Hq9rG0FhBp94LmwMi3EcLMUKBZ E8pvnkH8Q5HHHIvP
y/LX8f6e4n5f1r/kSeFfHllqmoT6ZfzLFqf9o3lnCsdvKImEMjgKZCCnmeWm 4puzjnAFbeheJ9K1
24lh0yeaRo13hntpYklTON8TuoWVM/xIWHI55GcmHwUESwRr7ctrrNzq5/c4 3+d5/wC7+9xjzvvd
9vQZ4rfDrwDF4Ld0t10R4BF5Ec9vpC2146hsjzplciU4Aydi5PNNefb9Bz3f L3/V/oXNP1PX9du5
rvSX0y00e3upLYR3VvJLNdeW5R2Dh1EQ3KwGVk4AbvtF6Dxhoc+tnSoruQ3X mvAGNtKIXlUEtGsx
Xy2cAHKBiw2txwcU7Xw5q2l6lcf2JrVtb6Pc3DXMlnPYebJG7sWk8mQSKFDE lsMj4JPbAFbT/Bl1
a6lGr6tHJokF/NqUFoLTbMJpC7EPNvIZA0jkAIp+6CxAOZ1sv67f8H/gA+tv 63/4H/BFg+JvhS5i
SS2v7qdZIvOiEOnXLmZP4mjAjJkC5w23Oz+LFWb74heF7HyDPqeVmtI79Wit 5ZFFtISFmYqpCx/K
cs2AvG4jIzH4f8Gf2R/wjH+n+d/YmnS6f/qdvnb/ACvn+8duPK6c/e68c5tl 8OPsug3um/2ru+0+
H49C8z7Pjbs8397jdznzfu5/h688U7f18/8AgfeOy7/1dfpc24fHPh+W11G4 F7JHHYBGnE1rNG21
yRGyKygyByCFKBgx4XJpj+PPDyWCXcl3cIr3X2IQvYzrcefsLiMwlPMDFRkA r82RjORmnrngb+1L
q5uU1EwTvaWUMB8jcI5badpkkI3fMpZgCvHAPzc5DoPBtzJf2eo6nqkVxqUe pLqEzw2piicLbvAs
aIXYoAH3ZLMSc9iADS5PT+u3+eheh8baHPFp8ltPd3H28uIUgsLiVxscI/mI qFogrHaS4XB4NP8A
Eeq38eqWGjaIlsuo3kcs5uLpGeK3ijKhmKKVLsS6ALuXqTnjBwbnwDct9nW0 1S1gKahc3zXIs3F0
izT+aY4pVmXYMfK2Q6txlccV0HiXQrjUbux1HSb9dP1ey3pFNJB58Txvt3xy JuUsp2qeGUgqDnGQ
V2/r+vMezZHdeIU8OWVrH4oukuNQmL7BplhPI0yryWECeY6gAgE5IGRyNwFZ njH4haTo3hu6vbC7
jurttNk1C0EcEk0RUKTG8jIMIjMMAsVyQQDkGp77w3rlxdabqkOu2MevWkU1 u8zaazWzxSlCVEPn
BlIMaEEyH+LIORjK1L4dXbaXcado2vCztbzShpV4bizE7yAB8SIQ6BGzK+Rh gQRgLjNDu1/Xn/wP
8uo42TV/61Oki8WaX/aVvpss0v2+QIH8u2laGN3XcEeUKY0YgghWYE5XjkZt aJ4i07W5p00x7iZI
es5tJUgk5IzHKyhJBkHlGNcqnw4gh8YvrkQ0Sfznhkl+3aQJ7mNkjWMmC4Ei mMEKpwQ2Dkjrit7w
boeo+HrFNMn1K2vNKtY1gsUW0aKaONeFEknmFZCFwMhE6Z709H/X9f12IV0v u/4P9fmc54V8bNqO
tayuqeJPDMMOn3N5G+mJGUu4ooZGUSu5nOBtUMT5YHPaujg8ZaRPps17Cuqv HC6o8Q0m788bhlW8
ny/MKn+8F28Hng1DF4Qgbwprmg3d08lvqst48kkahGRbh3YgZyMrvxnvjp2r mE+FzjRY9P3+FYlS
4SaSK38OiK2uwqMuLiETYlILBlOQFZQdp4xOtvkv+CU7XbXd/d0NiH4k6NJr V5agXX9n2+lR6t/a
C2s7RNEwdjyI8ABUBznkkqBuUitrVfFuiaSJzf3vleRDBPJ+5kbCTSGOM8Kc 5cEYHI74Fc3Y/Dlr
WyFiNUjewm0JdDuk+ybXdFEm142D4Q/vTkFWHAxikPgHU7yS4n1nXra4uJYr CFTbaeYUVbW4Mw+U
ysSWyQTnjrjtVaXt/W7/AEsDt/X/AG7/APbHRxeL9Gl1O3sFluxczBOGsZ1S NnXcqSuU2xSEEHY5
VuRxyMwXOs6pB8QNO0d4LJdKu7O4nSUOzTM8ZhHIwFUfvDx82cA5XocuT4fw r49n8SQLokpuJori
T7dpKz3MTogT9xcB1MYIVTgq2DkjritHU9A1i78b6brcGrafFZ2UUkAtH093 kZJDGZMyiYDP7sYO
zjJyGoXS/n+X+Ynuyv8AETXtR0G2hn0vUNHjuGVvJ028hd59RkGMRQlZFIY9 M7H+8DjA5s+K9W1e
LUdM0nw/9ii1G8inuDLeQtNHHHEFyNquhJLSIM7uBk4PSq+v+G9d1rTLvSrr XrF9LvfOjuVk0wmf
yZHbEcbiUKpVCFDMjcjcfSnax4Y1W61Jb+w1yK3uoGaO086yEywW7xIskZw6 sxLxiQMTweMEcVLv
y6f1/T/D8Xpzf1/X5f5X9F8T2eoeGdC1e43WqaskPloQWCySLkISBgc8ZOAT gdSKzPGPiLULXR9R
1Lw5c6cyaWzpcQ3dvKxuZV24gjYMoViSFDYcbjjGQRUzeDynh86Hbak8elxa fBa2cbQqz280RJW4
38FmyIzjgApkdaoXngzVwdEGn63p4j05WleO/wBNe4We7ZtzXJCzphsliAcg FieuCKlbmdtr/wBf
15rzEtF/X9f8M/Izb/4g6jpjTavfW9t/wj32q8sY4FjYXKyW8Ujl2k3FSrNB Ku0IMZU7jyK0NM1f
xVd3F5pV1eaJZ6rBbW+ofaDp8skIhl8xTGU89TvVoz8+4Ag/dFOn+Hy3tzND qd/HPojTXF2llHbe
WyzzxukpMm85T97KwXbkFuWIAFOXwTfy6VrEV9rqyanqNnFpxvIbPyhHbJu4 Cbz858yTLAgZIIUY
xS6edv6/H8Nuw9L/ANd/8vx+85638d+JpPDw1Dy9KZrLSzrd5/osqC4tmkfy kjBlPlu0cTsSxcAk
DBrcsPFOp3Hju70u6ubSxsmfbp0NxpVwrXq+Qkm5LouIiQzNlApbCH6i74l8 FHVZGSwvk0+0urAa
XfRfZ/MaW2BJCxtuHlsAzjcQww33eBU174c1W/1m0urvVrEWWnSPPp9rDYMh SUxtGhmcynzAqu3C
iPJPXinp+f5/5bf56i/r8F+t7/L0Oal8Z+IYvD/im80+48Oa6mlWv2iLUbVJ IbYsEkMkRUPLvdNi
EgOv+sAJUjn0q0lMtnDM4AZ41c46cjNcNqfgnWdSsNfNzrmmjVdZtF0+a4i0 t1hS2USDCxeeSZMy
ud5cjoNvr0MHhu1urXS28SWmk6rqen8w3ZsQvlMCMNGHZ2Q8LyG6jP0XR/IH 0t5/pb9f60Oc8NeK
9c1W5slmTTki1ywmv9LxC6m3VHQBZjvPmZWVG+UJ0I7gje8F6pqWoLq0GrtZ zzWF61qt3ZxtFFcA
IjEhGdypVmZCNx5Q/QYcHgPUbS2eOx1+OCW1s5bDSJVsebKKR1Zi48z944CI oYbMAcgk5rT0nwdb
t4fh0jxRaaBq9nbOGtoU0spHHweSsskuXJLEtkE5OeSTTVv69fzS+8Hv/XY6 PU7+20yxlvL6Tyra
IAySbSQozjJwOnPJ7dTVCTxHphnvLaK9j+121xHZyIVY7ZpACi8DkHcORwOc kYOI7/wpod4+pTNp
VjHe6hbta3F5Hbos8kbKBguBuIwBwT2HpWDpngGSwvNNvv7VE9/bRO08stt8 tzcnzNkzKHGApml+
QH+JeRtpev8AX9fm15h00/r+v0MmXxn4hi8P+KbzT7jw5rqaVa/aItRtUkht iwSQyRFQ8u902ISA
6/6wAlSOek1rXtVstW8Kxw29idP1S4FvcSO7mUMYZZMIoAAH7sfMWPUjb3rM 1PwTrOpWGvm51zTR
qus2i6fNcRaW6wpbKJBhYvPJMmZXO8uR0G31s6r4Y8R36+HSNe0iOXSZhcEn SJGE0gSSMcfaRtXZ
J0yTkZzjimt9fL/gg9tOz/S343/4GxQtfGmqXHxAutBhOlyyxvOv9mNHJHcQ xpGrJcSTZZTG7MgA
EfG/qxRhUcvjvUrbwd9rvILNdYn1e40mFYYZZokaOWQbti/vJMJEx2rguQAA u7jQh8E30OrpcR6v
amyt7641O1iewJmS4mWQHfKJBujBlb5QqtgKC3HNew8DaxBpnlXGvWD30GqP q1nPFpjokc0jSGRZ
EM7b0IldQAykDuTzSWyv2X5q/wCv6Ddtbf1o7fp/Wri1Tx5cWnhvRbjT7mw1 S+vLqNJpVtZLaNIf
tKQyHyWcujq0iptZshs5HBFbupanrVh4w0m1L6dPpmoyyRC2SJxcwqsTOZjI X2su4KpXYMb1+Y9D
g3/wpsNR0wLeahe/2vJOlxc3tvPNbpKRc+ey+THIFxksFJ3MuQckjNbOneHN atPF93q8mr6bc205
EYil06Q3ENuBxCk3n4A3fMTsJYnnoMNefd/p/X3+Qntp/X9f5dLnXUUUUgCi iigAooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACsG3/4/dY/6+h/6JirerBt/wDj 91j/AK+h/wCiYqAP
Dv2hP+PnRvrcf+06KP2hP+PnRvrcf+06K+azD/eJfL8kftvCH/Ino/8Ab3/p Ujtv2fSToQHYWUX/
AKU3des15T+z+MeHYz62Uf8A6VXderV9BQ/hQ9F+R+R5x/yMMR/jn/6Uwooo rU84KKKKACiiigDk
9U1maC2uL6TUFs4453giiKhkYoxX5hsZ2JKkkKV+X0wWOpZ6tPJcWiXNvbLF dHEUlvcGUE7S4PKK
NpCnkE9vqOB8V2WoadqCvrRSbTLm+lNoIJABEWEj/vF2jLEZwfmxhuRnmfwz ZahfaZpFzodvJaBL
aKQyynyY2cxkMQrI2WIZfn2EEAjdXLiYVcLThNNybettdPLT/I1pTjVlKLVk l/X9anps0iQxPLKw
SNFLMx6ADqayvC2v2niXSE1GwSeOJmZDHOmyRCD/ABDJxkYI9iKqeP7LU9U8 MXGmaKI1uL5ltpJp
BlYYWOJHK7lLfJuGAQckV5z420bxBpmja8uqPZ6hY6jcaZMh0+FrJVmW6hjZ MNM7AsgjwwIA2noe
vUtXb5f1/W+hnbb+v6/yPaKK8bvfCWoS6De2tn4UFnot9qiTHR0isZZraJYA DIiSs9srNKoJA3fK
SQNxOLeieF9Qsm8M/wDCSeG38QRW2l21rHG0lvN/ZtxGx3ykSuqncCnzx5b9 1jHSha/h+V/6/pCf
9ffb/gnpGhavb61bXE9qkqJBdT2jCQAEvFI0bEYJ4ypx7elaNeV6Z4HurLVt P1aHTkh1X/hIL6e4
u/MUyCyl+0bBnd9wlom8sdGOcA5NL8HfCV94bu7l9Vs9Vi1GSDy7u6lNiba7 kD58xWhAnkY8kNMN
wDEE5Jy1r936Dno3bv8Aq0dFbePrWW+Mc+katbWB1B9MXUpEia3a4WQxhcJI 0iguNoZkUZIyRkV2
NeYWWja5dWN94euNFntbWbW5r+TUZp4TC1v9rM6iNUkMhdhtGGVQMkk8ANzt z4D1hr7xfLNYatca
rfwajHb3sbWAtp45kfyo3chbngFFCsSilBg7QMStvl+i/W/+Q7Lmav1t8rvX 7j2CLV7eTxFc6MqS
/aoLWK7ZiBsKSO6gA5znMbZ47itGvGfE/gNxqNxHY+EI761k0WGzs2jmhjjt LzzJ2MzKzqQQZAxk
UM+WO3JLV0Flo9wvjj+xnMdxpURi1ydj1FztMYUr2DOhm/3gaq2tv63/AMtf u+UN9f62X6u339te
r1zxFHpt5FY2thfarqUiecLSyEe9Y843s0joijPAywJ5wDg41bGc3VpFO0E1 uzqCYZgA6HupwSMj
2JHoSOa5bVodU0fxdNrenaTNrFrfWkVrPBbSxRzwtE0jI481kVlPmMD84IIG AcnHNeNvD2o65qst
5d+FzqZu9MS3sA9xDnSLndIWkLMwKE7oiXh3tmLAzhSZW39ef9f1Yq2v9eX5 HqlUde1OHRdE1DVL
pJHt7K3kuZFjALFUUsQASBnA7kV5l4g8Cand2njOeG2WTVL2a0ENyGiEt1bJ FbiaNS4ZV3mJ12uN
rHG4Fa1NO8M3Fv8ACTxBoenafqdvcXVtdx29pf8A2ONg0kZACi2IhRSx7Y5J J65pvZ2HCzcb9Tsv
D+q3GrWrTXOjahpQ42LePAxkBGcjypHGPqQa1a8u8a+BbiTwlplhpS6teQR3 kc9/ZyXy3cs0YjZd
qC9MkRCsUbY2F+XIwwBrC1TwZrFxP4bjtNF1AQ6YLVrW4nGmieDbc7pUmkXL IoQLsW3wuCQx7Buz
dl3t/wAEzV+VN9r/AI7HsemalaapDLLYy+bHFPJbudpXEkblHHIHRlIz0Par deQaZ4Ru9AiWTS/C
gjksPEc2olLL7LGb23cXCx+WS6j5FmXiTZgAhc1Z8P8Ag/ULnW9Hvdc0dIo4 LjV7vZO8cvkSTXMc
kDYBILYBIIztI7HFJa/15J/8AtpJ2Xf9X/kvvPVq5aHxxpkmn67eGDUIotIl WCVZrcxSSuyIyhEb
DfN5igbguSfTBrlfg74SvvDd3cvqtnq0WovB5d3dSmxNtdyB8+YrQgTyMeSG mG4BiCck5STTNd1R
/GAfw7fWZu7611KzNzPalZjbi3/dHZK5UsYTgkYwRkg8U7a/L9V+lw6s7rQ/ EMGq6fe3DWl5Zz2M
jQ3VnMgeaF1UNjERcMSrKw2Fshh34p/hfXrbxHpjX1nDdQRrPNblLmPy3DRu UbK5yOVPBwfUA8Vg
aEmtafcapqz6FO0msaiJnszcQia1hS2VFLEMUZ2aIDaHx+8Bzwag8EPr2naF qaz+Gb2C6fVZriOG
4urcb4p7lmLBo5HAKI24g4yRgZzmhfovv0E9tO/4am9Y+Jo7jxGdGudN1Gxn eKSa2luVj8u6RGVX
ZNrswwXThwpw2QOuJdO8SWmoeJNR0WGC9S5sYkmkkmgMcbh2dRsLYLcxn5gN p4wTzjmdHufED6tr
Graj4U1QaksEsdhHLdWgt1jU5SJWWVmDykKWdkwMAdFGbOlnV2+Jt9e3Hh7U LfT59Pgs1u3mtmjD
xvM5OFlL7T5igfLnOcgDmlHpf+t7f13B7N/10udvRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFY
Nv8A8fusf9fQ/wDRMVb1YNv/AMfusf8AX0P/AETFQB4d+0J/x86N9bj/ANp0 UftCf8fOjfW4/wDa
dFfNZh/vEvl+SP23hD/kT0f+3v8A0qR2/wCz62dBVfSyi/8ASm7r1ivJ/wBn 5ceH1b1s4/8A0pu6
9Yr6Ch/Ch6L8j8jzj/kYYj/HP/0phRRRWp5wUUUUAFFY+uXU1rcwPFOIgsMk hRhlZCGjAU4GedxA
xzk9+lasDtJCjvG0TMoJRsZU+hwSKAMLVb1L6C4hfSotQ09XKSRygsZWRuQs ewg4YYG4r8y9hhjp
WurWlzOsKGdJGztE1vJEGPXALKATjJwOcAntXmfiG7mubqbRrqKSwtzezuhn Dj7YN7t8nABUZBP3
v4Tkd72navdxx6G6yPqcqwRXflFWMo3xOpYlFJKDI5Kk5YZauTETq4SEZ1n8 T2tsvk/8zWnyVpOM
Fstz0yqanT9asUdTaahZM4ZWG2WMsjZBHUZVl/Aj1FY3xF1SfS/Cd4bCOWbU brbZ2cUO3e00p2Lt
3EDjJbkgYU8159b6rdeHNL17SIIz4QiiNve2T6rdWseIWZY5lRw0sQbcpxvz 80oyB1rqT/rz/wCA
tTJ/1/XroezUV4jqvjm7JDQeLLrTYToMF/Yx3dvaNcX9yzzgIcKUfeEUbIsF uChAznTbxX4if4mH
TrnU9J0yGKSBI9Lu72OGS8R4lZmjjaBnlbezqCkygFMFeDufW39dgemvz/BP 9T1uolurdrt7VZ4j
dIiytCHG9UJIDFeoBKsAfY+leI67qz698PJ7u88ZypqcV3Yz6lp0X2RRpRF0 m9GVojIgQ5OZCeYw
c4yD3HhS7tdU+IOr3ml6hFqlnDpVnZyXsUiSK0yyTsylk+XfhlJAAxuHAyKa V/68v6Q3on/XVf8A
DnSWfifQL3V5dKs9c0u41SIsslnFdxvMhX7wKA7hjvxxWvXi1pfaZqekXOhW dzbXPiSHxVPcQ20T
LJPa7b9maZlBzGoj3ZY4BDbeSwBfY+JfFmqeKNds4Nd0m0vYZbuK30eW7iFw BESYWFubffh1VSXM
rqVkYqAcbUtV8r/gn+oSVm152/Fr9D2as+wg0qyvryDT4rG3vZiLu5jgVEkk LZAlcDk52kbj12n0
rzDxL411m48Ow69ot8mn6NqN/FaxXF2yW6WkKxvvlaVopQhaYeXl0ZcAYALb qoNr2qW0t/qianY3
F2dF02OfVLF1uoY4mvbhJLgMEVGKRlmJ2BQVJK7RihLX8PwuHT8fxse3UV45 e+Lr63srXyPGCSaJ
Jra2Y8QPFbsHgNrJJJ84UQnY64EgUKCMMG2sDa0vWPEOt3Wg2Fr4kmhtbqPU 2GpRWsDSXcUMsSwy
rlCgyGPIXawJIAypUv8A18r/ANf5Bbbz/wCD/kes0V43p/irxVDo2m6oL1tV u9W8OXepR2BtUEcV
zEsRQRBFDkHzCCrMxJxgjpUGgeJfEGp2ek28PjDTbo32qx273Wn3NvfTQxtb TOyNi2iRDmNSoZCQ
Qclh8tPld7f1vb9BNWV35/grntdYWr+MfDGi3rWeseI9G0+7UBjBdX0UTgHo drMDg15ppV7eXXjr
wnca34injeGTVtMV2W3iW7eK6jRFOY/vyKoyEIz5eVC/NnuvHf8AyGfBP/Ya /wDbS4pJXs+/+f8A
THa10+if4X/yOshkSaJJYXWSJ1DK6nIYHkEHuKdXluu+J9Sg8Y6haJrv2S+t 721g0/QvKiP9oQOI
zJLhl81uWlG5GCp5XzDhst0nxPqV14sS3fXfM1FtUubW58PeVF/o1onmBJ+F 81cqsbb2Yo3mYA5X
Cb0uv62/z+XWwNWWv9b/AOR6faXMF7axXNnPFcW0qh45YnDo6noQRwR70S3M EM8EMs8STTkiKNnA
aQgZIUd8AE8dq8a8Aa9NZL4D06XWttvc6ZbJFplnNbGZnKOWknikUy+VgDDR MMFTkYya7HxBqyaL
4s1rU7xGkSw0OOS1QfekZpZPMVfUkpAPqR61Ulyt/P8AAGt16fi7HZ213bXX nfZbiGbyZDFL5bhv
LcdVbHQjI4PPNZF14w8M2ktpHdeItGgku0WS2WS+iUzIxwrIC3zAkYBHWvPP COrf8IbqPl+KNPuf
D9lf2AmuLzUp7ZY5b1DmRgY5X5cSZ+bB+QAZ7Z3g3UNI0CW00/xbNa2rXHhK wh+w3RHmXHz3AaJY
j80jHIGwAkkgYyaX9fn/AJAtU3/W6/K+p6pq/jHwxot61nrHiPRtPu1AYwXV 9FE4B6HazA4Natjf
Wl/EZbC6guYg20vDIHAPpkd+RXnMVpd2GgfCy01FXS6hvokdJPvJizuMKevI GB17V0+l/J8Q/EEc
X+pexs5ZR280tOufqURAfZV69m1a/wAxPp6J/jY6C2vbW6luIra5hmltn8ud I5AxifAbawH3Tgg4
PYiqS+I9EbXDoy6xpp1gdbEXSeePl3f6vO7pz06c1wXgLxD4V0/WPH50zUdJ SwtLhbwxWLowSFLW
HzHVI8kgMGBwPvZHWpLfUbO1+I8a+FvEK6k+q3jSavpKGKVbVVtwvnEqvmRE GOJcOxB3kAZ6JdL9
Vf8Ar8RtWTO/n1jTLfVrfS7jUbKLU7lS8Fo86rNKozkqhO5gMHkDsabqut6V pElrHq2p2Ni90/lw
Lc3CRGZuPlQMRuPI4HrXk+o6pY6tqWofYLlZtR1fVNJvtJXlZJbRDCTIikBt q7bgt6ZOcZ52viH4
w8MX1m/h+XVtJtZNUE9lc3F/MtusECOY5yC+NzbgyqBwW+bopNHRd7/5f52f awNW3PQI9Y0yTWJd
Jj1GyfVIo/Nks1nUzInHzFM7gORzjuKz38ZeGE059QfxHoq2CTfZmuTfRCJZ cZ8stuxuxztzmvI9
aSS8sp9G0OXzfE8ep6pdOkUm6VbeS2uBDIe+xle3VW5BOADkcdDpHiLTbGTx F4i0No7jRbTRLKBf
IOUe6QzYhGP4wHiUjgjcoOKOl/L+v8vXsFtbf1vb/g+n3nfx+LPDskFjNHr+ kvDfyGG0kW8jK3Dg
4KRnPztk4wMnNWpNb0mLWY9Ik1OxTVpE8xLJrhBOy8/MI87iODzjsa8d8Q6b F4c0nUNK1OVXv77w
x9ksNxw11ftJK0yxjvI0kkLYHPGcccUpLjWYDr+mWGrvL4l1G61GK60fyo94 i8mTybncF8wcCBVY
tsIIUDdzQ9L/AD/B2/4Lf/Dgle3y/K//AAPVfI9hfxl4YTTn1B/EeirYJN9m a5N9EIllxnyy27G7
HO3Oakj8WeHZILGaPX9JeG/kMNpIt5GVuHBwUjOfnbJxgZOa4DSPEWm2MniL xFobR3Gi2miWUC+Q
co90hmxCMfxgPEpHBG5QcVjeIdNi8OaTqGlanKr3994Y+yWG44a6v2klaZYx 3kaSSFsDnjOOOG1a
Vv66/wCX4rcS1V/66flf8GexSa3pUesx6RJqdimrSJ5iWTXCCd15+YR53EcH nHY0k2u6RBpc2pT6
rYR6dC5jlunuEEUbBthVnJwCG+XBPXjrXknh6/l0/wASXVnqesQy3d5qt4us aRcxRFRZhHKXLtt3
hQiwqGZvLKkLjdzUWiaxoQ8ILdaRrvheJNJ8S3VxHBd6hHBaurS3AjQuobZl GLoQp+4CBjkLp935
r/P5/gP+vwf+Xyue12V1b31pDdWU8VzazKHimhcOjqehVhwQfUVNXHfCeK6T wj5t3EsP2q9urqGJ
FZVSKSZ2XaG52kHIyBwRwOg7Gm1YlMKKKKQwooooAKKKKACiiigAooooAKKK KACiiigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigArBt/+P3WP+vof+iYq3qwbf8A4/dY/wCv of8AomKgDw79oT/j
50b63H/tOij9oT/j50b63H/tOivmsw/3iXy/JH7bwh/yJ6P/AG9/6VI7j9n5 s+H0X0s4/wD0pu69
Xryb9n1caCD62cX/AKU3des19BQ/hQ9F+R+R5x/yMMR/jn/6UwooorU84KKK KAIpLeGWeKaSNWli
zsYjJXOM4/KpaKKAOc8WwaVq1t9i1Ce5hNvIJftFujEW7bTyz7Si/Ixzv6K2 eODWvpGl2Oj2SWmm
WsVtboAAkYxnAAyT1JwByck4rz/VtYYxXWnaUElvEvpxO5g3iFTJIw+8MEng dCOvTirWkajBbSaP
dSadFYtMqyySWcRZZEeJyFwo3feGduCBtB3E1zVa9SjCMq6tFvTy83p/kaQh CcnGm9UvvPQqK474
uXFxbeBrl7RrwStdWceLKcwTOrXMSsiOGXaWBK53Dr1Fc7pPiW58O6NrCrFd S3UepLDbaTqt1cXF
1CrQo+zzIkuHlJw8gCbwqk5YbSF6U9G30/4H+ZFtLnoUWkW8fiK51lXl+1T2 sVoykjYEjd2BAxnO
ZGzz2FaNeRf8J1q+otrF9Lp0a+Hl8MRat9nW/eC5RmWYkBliDKxKbMhxtChh ySo1PDHim5m+IGv6
HbK93L9oguGjuLplS0tTawZK5DbmLscKAMkkkrkZdnfl/rf/AIdg+7/rRf5p HpNFcbqH2uD4qaIB
qV69pdafeMbMuBChRrcAhQBk/M3LFiMnGBxWB8RtS1I+J54Ibe6uNK0fTF1O 5htdVl095NzyAkNG
NzsqxHbGWVDuO48LS7Pvf8L/AOQWfT+uh6jRXE+Ld+ta5oGlLe31np11aXV5 JJaXEltIzIIhGC6E
MB+9LYyMlRnPSn6D4nuh8O/DOuajCJ2u4rX7ZKG2eWJAqmXGMYDMCRwApJzx y0v69br80LpdHZ0V
5x4wvW13RJJbKfUrTUnuZbLRBY30iefKp2+e6JgNGrKxIfcuxc/xYrm9d1zW NHs5/EsN9dy6jJqO
pWBtGmkNv5UEFwY9sJOwENbo+4DJ3MCSDU30v/XT/P5FKN3Zf1v/AJM9a1bS LfVLnS57h5VfTrr7
XEEIAZ/LePDZByMSN0xzitGvEtWutY0jVovCukahf3q6olizS3OoyiVXdblp ds7bniVxbL90fICx
QA4rZtru5d/BUsFzq1iqazNpt1p8l+1yjOkdzuLTOPMmG5ARubGAPlBHF21t 5/5L/gf5Et6X8r/L
Vr9T1SiuI1G2eT4h2A0jUdT+1IGm1NPtMj20duY2VE8ony1cvtZSF3YRiSR1 ztKt7RV8TTyazrK+
Eo1jTz5tRnZ2mjL+c8UxbzFQ5RMIQCyMF75i+lw/r+v62PSKK43wlqM2j6Bp NrrY1mW5vJZPs/mW
dxcyRRNITElxIqsFZUZAWkI6HJOCar+FI5zf+OLDUdY1C4hgvUQXE84V4ka1 hZtpUKsYyx+6Fx16
80+/9dv8wWp3VFeX2cVuvg7U7u/1DxC2iS3pfSIkv7hbyZCioirIH81w8m9k Vm6MueMAT3tjqUae
ErWbVtSk8Xhbbz/JuXEAijKm4eWJSI2VhuXcwJLMu3HYWr+78f8ALr2Ff9f6 +fQ9JqrPp9tPqFtf
SRn7XbK6RyKxUhWxuU4OGBwDg5GQD1ANcf4r1pdWudN0ayfVrRLjVEtLyb7N c2ZMYjlkIimKrkMY
gu6NujdRkV53qOr6zLaSRwXWsXa6Ot1H9ptr6SM2SR3rxpdXCg5uh5cT/Id5 JibKnzCwI6tf10/r
/himrf13bt+X9M9+oryez8aWur/GK0sbXxBAtstve2QsY7pdzyxmE+Y0efvZ MoUEdI2I4JrQ0q3t
FXxNPJrOsr4SjWNPPm1GdnaaMv5zxTFvMVDlEwhALIwXvk6J/wBbiPSKqWOn WtjNeS20bLLdy+fM
7Ozl3wF6sTgAKAAOBjgV4nrM3iCz0+2V59elNpZSXgK3skUulwvcsYprpQc3 O2FSCh3tmIgqd5Yd
b4lvotA8YWGrTT6zY6exlkubqe+eWzu0FtI/lRwB2EbDYH3FI/8AVkAsWwTZ Xfn/AF+H/DhbWy/r
+r/52R6VRXh3h74i2o07xPPd+KNPM95qVvFBI2oRvDYia3jYhW3bQseJe4DN Ge5rOuviHbr8PfBd
sPFUMN4YbG7u7mTUFEs4FzHG0ZYtub/lqX64EZDcGmld29Px1/APP+vI+gqK w73U7PUXv9Jjh1eS
ZYC7G3gnt1kXAOIrrCx7jkAbZARzyMEjyDxN4sOgeC/EelHWrzSb+aa5FtFq WoFruxRLWOTyxOzk
yO7su3Y74E3B+QgTf+vmNK7SR73RXjusePrC58a+ELK08SWkVvFcwLPGl8gN 2ZraVgSN2WQfusHk
FpB3FXvhz4ztvE3xG1s2+uQXVtPYQy21jHdq4hVZpkJ2AnDlRGzcZG9Qegq+ XW3r+BN9L+Sf3s9U
oooqRhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRR
RQAUUUUAFFFFABRRRQAVg2//AB+6x/19D/0TFW9WDb/8fusf9fQ/9ExUAeHf tCf8fOjfW4/9p0Uf
tCf8fOjfW4/9p0V81mH+8S+X5I/beEP+RPR/7e/9Kkdz+z+QfDsY7izj/wDS m7r1avJf2fAf7Cz2
+xxf+lN3XrVfQUP4UPRfkfkecf8AIwxH+Of/AKUwooorU84KKKKACiiigDkf FvhFL9I7rQ4bS01O
OYysxBjW43AhhIVByfm3BiGOQRxuJqzovg7T7GwtoL8nVJYYUh33SgphQAMR /dHfBOW+Yjcaw/EV
7bWtrLcXsDXGoTXU0MHKpIqo7AFGIJQKqg5UfeIPVia1dF1o3V3p3k6hc3C3 fLQXUSI6J5bMHAVV
PUAbuV5I5OK5qmI9rCHto+63ZXtv/X6mkaahKXI9bam5r2j2WvaXLp+pxySW sjI5EczxMGRg6kOh
DKQyg5BHSsk+BtANilsba6+S4+1faBf3AuWl2lNzT7/Nb5Tt5YjbgdABUvj7 Vr3RfDUl3pZtheG4
treNrmNpI182eOMkqrKTgOTjcOlUdM8Q6jYalqumeJ1guJ7K3ivI7nS7SY+f E7MpH2cGRwyshGAz
ZBB45A6V1/rbX/g/8MRrb+vT/gFk+BfD3kJCtlIkC2B0vy47qZEa2IYeWyhw GwHbBbJGSQRVv/hF
dGF99tS0ZLvz0ufOjnkVt6xrGOQ33SiKCv3WxyDWPF8QtLufEei6XYwX1xHq cVw4nFlcL5LxSLGU
dTH8p3Fg24rs2jdjcK3NG8RadrF7d2lm10l1ahWlhurOa2cKxYBgJVUspKsN y5HHWnrv/W/+Yv6/
r7iC98J6Ve+IrfXLj+0DqVuMRMmo3KRoPlyBEsgTB2rkbcNgZzVW98BeG705 uNPY5klkkCXMqCbz
ZPMkSQKw8yNnJPltlPaqGnX/AIqbx9c6Pealob2Ftaw3rGLS5UldJJJU2Bjc EAjy87tpznoK0tP8
c+Hb95xBqBRIYXufOngkgikiQ/PJHI6hJEHGWQsACDnkUk7JP+vMbTvb0/4H 5kmp+DdC1KS4kurS
QSzzi4klhuZYXLiIRcMjAgFAFKggEdQaszeGtHmF0HsYwtzZLp0qKzKpt13b YwAcKBvbkYPPXgVg
ap4+spNFlutCZ3uormzjeG+s5rdvLnuEj3hJFRipDNtYfLkd8EV0Wka/Yaxd XcGnm6kNsxR5WtJo
4mYMVISVlCSYIIOwnGKLaW/rb/Ji8zOvfA2hXclg5j1C3exthZ27Wep3VsUh 4+X91IufurknJOBn
pVmDwnosOrS6ktozXUoIbzJ5JI8lQjMI2YoHZQAXA3EcEnJrltI8Xa7Jrlr9 ubS5dMvdXvdLht4L
aRLiLyDLtkZzIwcYiwwCLgsOex0/D3jm1m8M+HL7XRLb3WrW8MheCyna2SSQ hQplCskeWIADsOoo
3X9ddfxBqza7fpp+hdh8C+HodLlsI7ObyJHjk3m7mMyNH/q9kpfzEC/whWAX JxjJqK4+H/h6aLTo
/Jv4k09i9uLfU7qHa5LFpDskG6Q73y7ZY7jknJrl7v4pteWtjHpFjeWt3d6z LpYkutJvJo0SMyZf
aETcxEY+TcCu45+41dnb+MNEn1o6VHdyG7814A5tpRA8qglo1mK+WzjBygYs NrccHBfr/Wy1/FA1
bR/1q1+jIR4I0VdRvL5P7VjnvHaW4WPVrtI5GZdpJjEuzO0ADjjAxjAqsnw5 8OppiacF1c2UbRNH
E2tXpERjOY9mZspg4xtx0HoKRfiT4Xe0tLmO9univFd7YJp1yzXCoELmNRHu cAOuSoPRv7rY0ND8
Y6Frt+LPSr1p5Xg+0xMYJEjmiBALxSMoWQAsoJQnBIBxQl0X9W/yB+ZqaTps GlWS2lq93JEpJDXV
1Lcyc+ryszH8+K58fD3w95WrRPHqckeqrtvVl1a7cTD5Rk7pTg4VVyMHaMdO Kx9X8S+Jre+8WXdh
/ZEumeH5E3WUtvIs9wn2eOZ8T+ZtVsO2AYyOACRnI6GXxtoMWoxWUl5KJpDE C4tpWhiaUAxpJKFM
cbNlcKzAncvHIyLX+u+33jehXm8AaHPHbJM+tyG2laaGRtcvjJGxXaSr+duH y5GM45PqakTwLoqa
kuoI+sLeBIo2kXWrweYsedgcebh8ZP3s5yc5yann8YaLBNqSPPcFNOjklup0 s5ngiEYy4MyoULgd
UDFu2M0/VvF2h6QJzqV+tusEMFxKzRvhI5pDHGxIGMFgR7dTgc0J9UK3T+v6 1Rf1vSbPWrA2eoxu
8JZZAY5XidGU5VldCGVgR1Ug1i3fgHw3dRW0clhIkcEP2fbDdTRCaLcWKTbX HnKWLEiTcCWYn7xy
y3+IXhu4uIYEvLpZZJ1tSsthcR+TKxARJd0Y8otkbQ+3dkYzmrE/jbQIJ7+K a7mUWMcsk832Sbyc
RDMirLs2OygHKKSw2txwcG2v9f1YOtv6/q5pahothqF1FcXULGeK3ltkdJHQ rHLt3gbSMZ2Lz1GO
CKwU+HPh1NMTTgurmyjaJo4m1q9IiMZzHszNlMHGNuOg9BVPWfidollpE97Y re3zw3FrC8K2Vwjb
J5NqygeWSyEBirAFXKhQckVt3ni7SrO8htbn+0Y5po/MiDabchZP3Zk2K3l4 Mm1WPlg7+CMZ4oei
v/Xf9bhuirceAPD9yka3UOoTlEMTNLql07TRlt3lysZMypknCOWUZIA5OdC3 8M6ZDrf9rbbyW8BZ
k+0X080UJYYJjidykZxkZVRwSOhIrC8M+PrLW9L0jVJ5l0uC7sZryS2u7aVG AjEZdxM4Vdihxk7S
GzkH5TV6Px/4cbTrq9kvZ7aC18oyi6s57d1WVgkb7JEDFGY4DAFeDzwadmtP 6/pha5u2em2lnd39
zbRbJ76RZbhtxO9gioDgnA+VFHGOlVF8OaUugWuiC1/4llr5Pkw+Y/y+UyvH 82dxwyqeTzjnNJo+
v2mvafd3GiFpZbd2haG6iltWSUKGCSK6B0yGU5K9CCAaq+BNYv8AW9GuLjVo 7WK7hvrq0ZbbcUAi
meMYLcnhevGeuB0oX+X/AAAvpf5GzqVlFqNlLa3D3CRSjDNb3EkEg5zw8ZVl /Ais638MaTBoV7o6
28j2N6si3XnXEkss+9drF5WYux28ZLZAAAwAKwPBPibU9U8RanYa3cWttPC8 /kacdLuLaYwpMUSV
ZpHKTKVCklFwC4yR3ZZeLNUl8R2zTR2Y0K81O40iBFicXCywq5MrPu2lS0Mi 7QgI+U7jyKSV/mN3
Xyf9fhc6660qyum09p4d50+UT23zsPLcIyZ4PPyuw5z1p6abaJq82prFi+mg S3eXceY0ZmUYzjgu
3OM8/SsDxfqmtaPeafcWT6dJYS3UFq1nJC5uJzI4VmjkDhV2qS+0o2Qjcjty n/CwtZgsrS7ubaxk
TXLQ3GkRJE6tExniijWYlzvyLiJiVCYww54NCblt3/G36oVraen3X/RnqtFe dXfiLxHFo3iCSTUt
Ftrrw9JIL2VtMlljuU8lJkMaC4Uxna+0gs+SOMdKhj8YeIoWSfUIdNS2sJrC x1OJIJN73FwI9xiY
yYVUM0fBDFvm5HFCV9vL8dv66X1B6fj+B6XRXmereJ/FOh6vf2lzc6LqYhtI WX7Pp8tuUuLicQwK
xM8mVJ3lsAHCj1pda8d6povhfxILlLC68R6VNJBF5cTxwXGLcXIfYXZlAjJy N5yV4I3Cjpf+t7f5
ffcaTbsv66npdFcmuvaqPGukaZNb2K6ZfWE1ysiu7TF4/J6jACD96Rj5s4By Oh6ym1b+vkSndXCi
iikMKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACii
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKK
ACsG3/4/dY/6+h/6JirerBt/+P3WP+vof+iYqAPDv2hP+PnRvrcf+06KP2hP +PnRvrcf+06K+azD
/eJfL8kftvCH/Ino/wDb3/pUjuf2f8f8I7H6/Y4//Sm7r1avJf2fCToWOws4 v/Sm7r1qvoKH8KHo
vyPyPOP+RhiP8c//AEphRRRWp5wUUUUAFFIWUMFLDceQM8mloA838VeGJdIu JNX0hbm9FzdNJeQe
SJWUMGIMYUbsBmAIwxwc5ABzd0jwje3uk6fHr7xWxgt4k8iAJK25EIyzMpX+ JgVCnkAhqv6prM0F
tcX0moLZxxzvBFEVDIxRivzDYzsSVJIUr8vpgsdSz1aeS4tEube2WK6OIpLe 4MoJ2lweUUbSFPIJ
7fUc+IrUsXCMaydr6PWzNKdOVGTcHr+Qzxnok3iHQJLC2u47OczQTxzSQmZV aKZJBlAykglMfeHW
sLU/BN7q2m6l/aerwTatfeQkkosyLTyYn3iE2/mEmNstvBkJbcRkLhR0finX IvDuiyajPbXN0qyR
RLDbbPMd5JFjUDeyr95x1IqHw94ii1m5vbOSxvtN1Kz2NPZ3qpvVXzscMjMj KdrcqxwVIOCMV0JX
vb+tv+ARdpHN6D8PptDfRnsNSs4TYveCRIdP8uJo7mRXZIkWQCIqUAUncMdQ am+HngI+Eb+7u5Lu
yuJri3it3a2sPszSlGc+bM29jJK2/wCZieSM4FddNqVpDqlrp0su29uo5JoY 9pO5Yyoc5xgY3r1P
fjvVumn1E9rf13MZNDA8VX2stPuW6sYbIwbMbdjytu3Z7+bjGOMdea5a1+HM kmkDR9X1gXWl22nT
aXYpBa+TLFFIoQtI5dhI4VVAIVF6kqcjGvY+MJ7rxQ+ht4Y1y3uI40mkmle0 MSRMzqsh2zliCUbg
KW45Arq6XT+v66sd2peen9fkcLP4J1DUoJn1zWre5v2NmiS21iYI0ignWbGw yMSzEEFt2BxhRg50
/DXhq50jXtU1CW9tfs92cpZ2Vs9vEpLsxkdTK6tKcjLqEzySDxjW8Qavb6Hp 3227SV4vOhgxEAW3
SyrGp5I4y4z7Z61o00+q8/x3FbS39aHMeFfBml+H7rUb6K1spNVvbm5nkvlt VSYpLKZPLL8swXIH
J52jgVyj/CcumhRyapZzx6Xb2kKNc6aJZI2gk3loGMmIfM4D8MSAOeK6TTfH Vre6yLFtL1O1gku7
iwgvphD5E88JYOi7ZC4P7tyNyqDtPfArd8O6vBr+hWGrWaSpbXsKzxrKAHCs MgEAkZ/E0LSzXS36
2/Ubvqn13+//ADOcs/BVxBeW7PqkT2ltrU2sQRi1KuPNWbfGz7yD802QwUYC 4IOc0af4MurXUo1f
Vo5NEgv5tSgtBabZhNIXYh5t5DIGkcgBFP3QWIBzo6j4v0+2s4JrSK61GSe/ fTIoLZAHedC4df3h
RQF8tySSBheM5GejpWuv68v+BqEm27P+tX+rZyPh/wAGf2R/wjH+n+d/YmnS 6f8A6nb52/yvn+8d
uPK6c/e68cnh7wb/AGOfC5+3+d/YmnS2H+p2+dv8r5/vHbjyunP3uvHPXUU7 u9/66/5sLnEX/gzU
bvVdfxrUMOi63Ij3dslkftO0QpEyJP5m1QwTk+WSAxwQcMH3ngq4l1S/+zap FDomo3MN3d2ZtN0p
kiWNQI5d4CIRFHkFGP3sEZGNK28Tm68T3uj2mi6nMllKkNxfq1uII2aNZBwZ RIeHXoh5NdFSWiVv
6QPszjY/B90llrejnU4G8OamLo/Zvsh+0xNcFmfE3mbSu53IBjzyBnis8+Ad TvJLifWdetri4lis
IVNtp5hRVtbgzD5TKxJbJBOeOuO1djq2r2+l3OlwXCSs+o3X2SIoAQr+W8mW yRgYjbpnnFFzq9vb
69YaQ6Sm5vYZp42AGwLEYwwJznP7xccHoelEdGmv6sDu9/X8f80YWpeDPtv9 uf6fs/tPUbPUP9Tn
yvI8j5Pvc7vI68Y3dDjnAb4VwpP4gFtJoiRasl4Bcvoytfwm4Vt3+kiQblDO cArnbhc969Noo8v6
2S/RBzP9fuOK8QeB31Sa7nh1JYJpbSyt4y9v5io9tcNMrsN43BiQCoI4HXni q3w+mn8b2/iK91Cw
nminW43f2d/pAxAYjEkxkJSHJLhAOGJyTk139VL/AFK0sJrKK7l8uS9n+zwD aTvk2M+OBx8qMcnA
4o3/AK7i6W/ra35HDW/w1Z9FsNK1PVlntbPTLvSUNva+U7QzCIAkl2G9RH1x gk9BjBtT+CdQ1KCZ
9c1q3ub9jZokttYmCNIoJ1mxsMjEsxBBbdgcYUYOeg1fxJaaXrWk6XPBevPq UvkxSRwExIdjv80h
wvSNvlBLdDjHNN8UeIV0H+zkXTr7Urm/uDbQW9mYgxYRvISTK6KBtRu9O70l /X9ajd3o/X+vu/AX
TtEl0/UPEN7b3SGbVZlnQSQkrCywJEAQGBcZj3dV6496yfDfhnXtI0i9tJPE Fk01xfm9We300x7N
85lmQq8rghgWUHgqDnk1sazryaTpNtd3FjePc3Lxww2Eflmd5X6RglwmRySd +0BSc4p2l69Bqnh4
atZ29064cG12jzlkRirREZ27gylTztyOuOaW2vbT7v6Qr3svn/X4/iY7eGtb utSn1PUNetf7Ris5
7TTntNO8pLUylSZGV5H8xgUj4yq/KeOc02w8GS2+uQXM2pJLptteS6jb2gtt jrcyoyuzSbsMuZJG
C7QQW+8QAKjb4hWwjeIaJrLavHO8EmlKsH2hNkays5Pm+WV2OhyHOdwA54qZ fH+ky3tnHaw3lzZX
Atw2oRqnkQtcDMKPlg+WyvRSBvXcRmheX9X1/Hp5+YN6a+f/AAf6/wAytH4W 8SjXrDUrnxHpl81r
bpABdaQxYH/lrIhSdVR5OmdpwAAOM5qL8Ny9sLe61VXhsrdrbSAloFNmvmpK pfLESsrRRAEBOFII
JOavT/ECOyvLi31fw9rWmvDaNdgzG2kEih1RVXypnO5mYBQQMnPPBqZvGzHT Z7qDw5rM0lpJJFfW
yyWiSWbIqv8AvC84UgqwYFGYYPOOlF7e9/Xb+u3zHZ3t1/r+vMjPgue4064h v9USW5v9Sh1DUpIr
YolwI9gWFELsUXEUYOWbo397iTVfBr32uzXA1BI9Ku7m3vLyz+z5eWaAqUKy 7htU+XHuUq2dnBXJ
qO0+IWn3E9gv9nanHBcrbebcSJGEtJLgZhil+fdvbKj5QwG5ckZrQbxhpw1v WNLSK9muNLgimnMF
uZQ3mFgFQJlmYbeeMDPXg4b935fpb8rL8yVqr/1qVrnwcLqz8QpcXxe71W6S 6S48kf6OYtnkKFJI
YIY1PbJJ6ZrI1X4Y2ut6Tqo1m/mk1zUBOXv7N5rWNGkiSLAiSX5kCxR/I7MD g+tdl4b1eDX9A0/V
7SOWO3vYFnjSYAOqsMgMASM/QmtGk420+X9fcUm07o4weE9Vh8S6Hf2ms2i2 GlWzWiW9xZyzzSRv
5e8tM0+Sx8oYJU4yc7q7Oiim22SlYKKKKQwooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooA
KKKKACiiigAooooAKKKKACiiigAooooAKwbf/j91j/r6H/omKt6sG3/4/dY/ 6+h/6JioA8O/aE/4
+dG+tx/7Too/aE/4+dG+tx/7Tor5rMP94l8vyR+28If8iej/ANvf+lSO5/Z/ GPD0Z9bOP/0pu69W
ryb9n1s6CF9LOL/0pu69Zr6Ch/Ch6L8j8jzj/kYYj/HP/wBKYUUUVqecFFFF AGH4gjMl9aCOKWSb
ypREYzgo+6PDbsYA69e2Rg5wdmASLCgnZXlCjeyrtBPcgZOPzp9FAHlPiuy1 DTtQV9aKTaZc30pt
BBIAIiwkf94u0ZYjOD82MNyM8z+GbLUL7TNIudDt5LQJbRSGWU+TGzmMhiFZ GyxDL8+wggEbq6/V
b1L6C4hfSotQ09XKSRygsZWRuQsewg4YYG4r8y9hhjpWurWlzOsKGdJGztE1 vJEGPXALKATjJwOc
AntXPiZUMXCNK/Lyvpp93/ANKUKlGTna9++v3/8ABMb4kWN7qHhSSLTLSS9u kurScQRuiM6x3Mcj
AF2Vc7VPUiub8Q6Trmt22taodD8t7y3ttPTTbj7NPOYFlLTOQzNb7yHOxWZl +UFupUeg6pqNlpNj
Le6peW1lZxY8ye5lWONMkAZZiAOSB+NM0fVtO1qyF5o2oWmoWhYqJ7WZZUJH UblJGa3t0/rt+WhF
7L+vU8l8LeBLvS9R8LXt34aW5exbUIlaYWhltFknWS3dthVFVRv4iB2lyFXk 1r/CTw3q2ja3q99q
Wlvpq31tAZowtpHE1yHkMhjS3/g+cYaQmQj7x4r1CiqTE9VY5uHTLxfiBqmp eXss5tKtraObcD+8
SWdmGM54Dqc4xz9a880XwTrUelzW9hpP9ha0ukXNneat9ojH9qXTqAk26Ni7 fMGffIFdd3A5OPR7
Txt4VvNRTT7TxNoc9+7mNbaK/iaVm/uhQ2c+2K6Cptdf15/5/wCZXM1K/p+H /DHkEXhC8fT7z+xf
C3/CO2zvpoOnebAvmyQ3SySz4idk4QY3E7228jhc9H4D0S40rxRr8o0T7HZ3 DtL9uu4rYXdzI0js
R5kLsXiAPy+YFdQQPm/h7e7urezh827nigi3Km+Vwq7mYKoye5JAA7kgVLVX 6+v4kW0t/WhwHhDw
XcW99cX+tXd85i1W+vLKwdofs8Rllk2zDYu8sUc8O5A3ngHGOKl8E+I5LTwb bzaKwn0m1sAlxB9j
3QyJMDOskr5lACqNohIBywYkHFevWXiXQr/VZ9Lsda0y51O33edaQ3UbzR7T htyA5GDwcjitG0uY
L21iubOeK4tpVDxyxOHR1PQgjgj3pLSz7W/C5Td+a/X/ADueP6b8NreO+sI3 8HadEtn4kuL17kwW
2yW1cTmMrg7sKWhG0gEEDAIXI0tI8KX8Pi1LiXQ/K1GPVLi7n8Q+bF/pVq/m eXBkN5pwrRpsZQi+
XkE4XPpOqalY6TZtd6re21laqQpmuZVjQEnABZiBkkgCrXXpStpb+un+SCTv e/X/ADf+bPIfDvwz
hW08G2usaBatbW2mXK6nE5Rle5cW4XzADiQ4jOD8wGxemFrQ8A+DrzQtQ8LX z6etvef2RNb6zcCR
WkmnzAY/NbJMhG2TDc4GRkA16dRV82t/66/5/kDd9zzvT9IvLP4ma5qE+i65 LDe3MT295b6kqWao
LaOMmWDz13EMrcmJj0I6DHP6D4G1Xw9o+jzaNolnHq//AAj11a6gJWRluLki Hykm+b94PlkAOSAO
MgGvTpPE2gx62NGk1vTE1gkAWLXcYnJI3D93nd056dK1qlbfh+DX6j5rP7jw qw8C6naaTDC3hu9u
tMj15L86bLJYwu8H2No3HlwFIBlzgoOGB+bOWNa0fgzxB/Z1vHptsNJY6frE VtGJ1H9nG4eM28WV
JxgKfuZVcYHAGfX6KHr/AF5WFF2afb/g/wCZ4poHw+c2ek2k2hanBZLqsV1f Wt+dPSEoLaZGKpab
VcFmRW3LuYYyCM41NE8BT6Vd6NeWWlQ2t9a61eBrhGTfHpzC4EUYOc+UN0OI x93jgYOPUobq3nmn
ihniklt2CTIjgtGxUMAwHQ4IOD2INS027/16f5C6W/rr/n+CPBdE+Heqw6Be WV3purtqk72gvZ5J
bBLe8Md3G8kqvDtndtodg03zYJGdx52dT+HqQaoHt/Clnd6PZ6+l5a2MUdvh bdrMJJ5aOyqo84Bi
uRkruAJxn1CbXdIh1mLSJtVsI9WlXfHZPcIJ3XBORHncRhTzjsfSodF8T6Br s00Oia5pepSwjdIl
ndxzMgzjLBScfjQpW1X9ar/L8xvrfr+qsYPj4arJrPhhtM0HUNShsb/7ZPLb y26Kq+TNHtxJKhLZ
kU9MYzznil8Zxvqttd2OqeBG8QWqS4tQZLV0b90D5hErqY8MzpldzfKT3FdP Dq2nTGyEN/aSG9Uv
a7JlP2hQMkx8/MAOcjPFTJe2sl7LZpcwteRIskkAkBkRWJCsV6gHacHvg+lS 1dcr/r+rBfW/y/r7
zgJNK8RWeleFreawfVZ/D621zJPHdIXvJfLlhljXzCOVVw4ZyN2cZBzVjS18 R+HPDcostA/tC/u3
vtRaFbuJPJmln3xwncQG4kOWDYHlnBORXVX3iPRLDVbfS77WN
Re: missing GDB HARDWARE DEBUGGING [message #195754 is a reply to message #195737] Mon, 09 July 2007 06:10 Go to previous messageGo to next message
This is what worked for me:
Help->Software Updates->Find and Install
Search for new features to install (next)
New Remote Site
URL: http://download.eclipse.org/tools/cdt/releases/europa
(ok)
(finish)
It should now present you with a list - look under "Options features"
HTH
Derek
T.Schulte wrote:
> Hello Derek,
> Help ->
> Software Updates ->
> options do not appear.
> Regards
> Thomas
>> Thomas,
>> start the update and the option will appear in the Eclipse update
>> manager during the update process. So, just do as instructed (below)
>> and eventually you will be asked to select the features you wish to
>> install.
>> HTH
>> Derek
Re: missing GDB HARDWARE DEBUGGING [message #195767 is a reply to message #195754] Mon, 09 July 2007 10:00 Go to previous messageGo to next message
THAT'S IT !!
Hi Derek,
thanks indeed. Found it at last.
Honest, how clever one has to be to discover that the cdt upgrades/options
are hidden in such a way?
Was it communicated somewhere - did I miss the train at some point - how to
find out things like these next time?
However, I always thought that such an obviously reputable premium project
for eclipse like CDT is managed more automatically.
Curious to know, thanks for your advices.
Glad to have it fixed after days of 100s of download/update scans.
Best regards
Thomas
----- Original Message -----
Newsgroups: eclipse.tools.cdt
Sent: Monday, July 09, 2007 12:10 PM
Subject: Re: missing GDB HARDWARE DEBUGGING
> New Remote Site
> (ok)
> (finish)
> HTH
> Derek
Re: missing GDB HARDWARE DEBUGGING [message #196132 is a reply to message #195767] Tue, 10 July 2007 14:15 Go to previous messageGo to next message
You are certainly not the only one who finds the Update Manager
confusing. It is truly brutal. I am going to work with the Eclipse
Platform guys who have started a task force to see if we can improve the
experience.
Sorry about this Thomas, and I'm glad you found it, even if it took way
too long.
Doug
T.Schulte wrote:
> THAT'S IT !!
> Hi Derek,
> upgrades/options are hidden in such a way?
> to find out things like these next time?
> project for eclipse like CDT is managed more automatically.
> Best regards
> Thomas
> ----- Original Message ----- From: "Derek Morris"
>> New Remote Site
>> (ok)
>> (finish)
>> HTH
>> Derek
Re: missing GDB HARDWARE DEBUGGING [message #196569 is a reply to message #196132] Thu, 12 July 2007 04:16 Go to previous messageGo to next message
Hello Doug,
just a final comment. Actually after getting the helpful hints I mayself
found the helping link :
help->helpcontents-> c/c++->getting started->update cdt
I remember myself looking always at the previous chapter "before you begin".
I am sure I came along that other page "getting started->update cdt", too.
But I could not recognize easily how this could help me. It has lots of
links for pics. However, my Vista is very much terrifying me going through
all that as Vista has all these nasty protection mechanisms. To look at
approx a douzen pics it takes more than 100 clicks. And boring 30 minutes of
stop-and-go waiting. Again, this is the fault of how Vista anf my Laptop is
configurated by Dell. Nevertheless, I think I am not the only one. For
reasons of clarity it might be helpful to mention in the "before you begin"
link not to forget to look at the link "getting started->update cdt" as I
believe this should be held close together.
Maybe you just forward this to the responsible.
BTH: I think the current eclipse+CDT is a great thing!!! I joined the club
when 3.1 came up. Since then I see the improvements. With the actual version
I am absolutely delighted by the functionality. CONGRATULTIONS!!!
Thanks for your patience and best regards
Thomas
news:f70ibp$p2v$4@build.eclipse.org...
> You are certainly not the only one who finds the Update Manager confusing.
> It is truly brutal. I am going to work with the Eclipse Platform guys who
> have started a task force to see if we can improve the experience.
> too long.
> Cheers,
> Doug
> T.Schulte wrote:
>> THAT'S IT !!
>> Hi Derek,
>> Best regards
>> Thomas
>>> New Remote Site
>>> (ok)
>>> (finish)
>>> HTH
>>> Derek
Re: missing GDB HARDWARE DEBUGGING [message #196865 is a reply to message #195556] Fri, 13 July 2007 04:35 Go to previous messageGo to next message
Hi Doug,
why isn't the CDT update URL already available in the update manager (at
least if basic CDT stuff is installed)?
Once I added the Subclipse remote site and installed it via the update
manager I noticed that it added it's own update site as well. Now I have
Subclipse twice in the update dialog but I could delete one much faster as
adding a new one ...
Jens
Re: missing GDB HARDWARE DEBUGGING [message #196979 is a reply to message #196865] Fri, 13 July 2007 11:22 Go to previous messageGo to next message
Originally posted by: dschaefer.qnx.com
Jens Seidel wrote:
> Hi Doug,
> Jens
That's a great question. I noticed that with the CDT for Windows distro
as well. Something is fishy with our update site. I need to take a look.
Re: missing GDB HARDWARE DEBUGGING [message #198388 is a reply to message #195487] Thu, 26 July 2007 17:19 Go to previous messageGo to next message
Originally posted by: losborn.asset-intertech.com
Hello Doug,
I read through this post. I can not see GDB HARDWARE DEBUGGING in the list
of features install on my machine. Is this needed to connect JTAG hardware?
Also I went through the update process and there are not any updates
available. So I selected both the Europa Discover Site and The Eclipse
Project Updates and scanned the lists and did not see the GDB Hardware
Debugging. I did see under the Remote Access and Device Developemt some
features for debugger servers but nothing about HARDWARE Debugging. Let me
know what I missed please.
Larry
"T.Schulte" <thomas.schulte13@freenet.de> wrote in message
news:f6la4j$ufr$1@build.eclipse.org...
> Hello Doug,
> I installed cdt (Twice before! Same like eclipse3.3) per eclipse update
> manager. I did not improve.
> What do you mean by update site - this link?
> There is no seaparate item like GDB HARDWARE DEBUGGING to download.
> Just to cover everything else I installed the Windows package: Same
> result, no GDB HARDWARE DEBUGGING.
> If everyone else is getting it but not me, well the problem must be with
> me somewhere - but cannot not recognize the point.
> Just to give a last excuse: my OS is Vista.
> One thing I identified when running that specific windos package: It did
> not had the Ixxxxyyzz Integration build number in the opener (eclipse
> start image).
> My current eclipse still opens with displaying the Integration build
> number=I20070625
> Regards
> Thomas
> "Doug Schaefer" <dschaefer@qnx.com> schrieb im Newsbeitrag
> news:f6e8is$3ls$8@build.eclipse.org...
>> T.Schulte wrote:
>>> Hi,
>>> GDB HARDWARE DEBUGGING was an available item of CDT4 - early RC version.
>>> Since I have the final stuff installed it is not there anymore.
>>> WHY?? Can someone explain the background?
>>> I started using it and I would like to see it again.
>>> Kind regards
>>> Thomas
>> Not where? It's there on the update site and in the cdt-master zip.
>> Doug
Re: missing GDB HARDWARE DEBUGGING [message #198458 is a reply to message #198388] Fri, 27 July 2007 09:38 Go to previous message
Originally posted by: paul.mcconkey.net
I got mine by adding an update site:
GDB Hardware Debugging is under the optional components.
Paul.
"Larry" <losborn@asset-intertech.com> wrote in message
news:f8b352$hus$1@build.eclipse.org...
> Hello Doug,
> hardware? Also I went through the update process and there are not any
> updates available. So I selected both the Europa Discover Site and The
> Eclipse Project Updates and scanned the lists and did not see the GDB
> Hardware Debugging. I did see under the Remote Access and Device
> Developemt some features for debugger servers but nothing about HARDWARE
> Debugging. Let me know what I missed please.
> Larry
>> Hello Doug,
>> start image).
>> number=I20070625
>> Regards
>> Thomas
>>> T.Schulte wrote:
>>>> Hi,
>>>> version.
>>>> Kind regards
>>>> Thomas
>>> Doug
Previous Topic:Build Projects with a script.
Next Topic:assert errors in CDT - Solution
Current Time: Fri Sep 26 10:05:48 EDT 2025
Powered by FUDForum. Page generated in 0.07127 seconds
