Leading whitespace is not removed when parsing list element [message #1207169] |
Sun, 24 November 2013 12:26 |
Jan Schoubo Messages: 13 Registered: May 2010 Location: Stilling, Denmark |
I believe there is still a problem with parsing list elements - leading whitespace is not skipped.
This problem is very similar to http://www.eclipse.org/forums/index.php?t=msg&goto=846629
and the resulting bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=376967 .
The solution was to change pattern used in the EFactoryImpl method split method
from "[ \t\n\r\f]" to "[ \t\n\r\f]+" - however, Pattern.split will return a leading
empty String, if the pattern is found in the beginning of the target string,
so the solution is not quite adequate?
Please see example below, and the enclosed Eclipse project.
I have validated the XSD/XML successfully at http://www.freeformatter.com/xml-validator-xsd.html
EMF is 2.9.1.v20130902-0605 and Eclipse is 4.3.1.M20130911-1000, under Linux Mint 14 (64 bit).
- Jan
XSD:
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns="http://www.example.org/testmodel/" targetNamespace="http://www.example.org/testmodel/">
<xs:simpleType name="ListOfFloats">
<xs:list itemType="xs:float" />
</xs:simpleType>
<xs:simpleType name="float2x2">
<xs:restriction base="ListOfFloats">
<xs:minLength value="4" />
<xs:maxLength value="4" />
</xs:restriction>
</xs:simpleType>
<xs:element name="matrix">
<xs:complexType>
<xs:simpleContent>
<xs:extension base="float2x2">
</xs:extension>
</xs:simpleContent>
</xs:complexType>
</xs:element>
<xs:element name="root">
<xs:complexType>
<xs:sequence>
<xs:element ref="matrix" minOccurs="1" maxOccurs="unbounded" />
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
XML - first and second matrix is ok, third and fourth fails validation:
<root
xsi:schemaLocation="http://www.example.org/testmodel/ ../../model/testmodel.xsd ">
<matrix>1.0 0.0 0.0 1.0</matrix>
<matrix>1.1 0.1
0.1 1.1
</matrix>
<matrix> 1.2 0.2
0.2 1.2
</matrix>
<matrix>
1.3 0.3
0.3 1.3
</matrix>
</root>
Jan Schoubo, schoubo reasoning
Re: Leading whitespace is not removed when parsing list element [message #1207478 is a reply to message #1207169] |
Sun, 24 November 2013 16:03 |
Ed Merks Messages: 33142 Registered: July 2009 |
Jan,
Please open a bugzilla.
On 24/11/2013 1:26 PM, Jan Schoubo wrote:
> - Jan
> XSD:
> </xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> <xs:complexType>
> <xs:simpleContent>
> </xs:extension>
> </xs:simpleContent>
> </xs:complexType>
> </xs:element>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> <root
> <matrix>1.1 0.1
> 0.1 1.1
> </matrix>
> <matrix> 1.2 0.2
> 0.2 1.2
> </matrix>
> <matrix>
> 1.3 0.3
> 0.3 1.3
> </matrix>
> </root>
Ed Merks
FUDForum. Page generated in 0.03084 seconds
