Home » Eclipse Projects » Eclipse Platform » Eclipse M7, linux gtk , starting problem
Eclipse M7, linux gtk , starting problem [message #194294] Fri, 13 February 2004 19:02 Go to next message
I try eclipse 3.0 M7, linux gtk and get this error on start (library
runtime.jar and class org.eclipse.core.IStatus.class exist in runtime
plugin) :
!SESSION Feb 14, 2004 01:00:39.864
java.version=1.4.2
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
!ENTRY
reference:file:/u2/buildScripts/result/eclipse/plugins/org.e clipse.core.runtime_3.0.0/
0 0 Feb 14, 2004 01:00:39.867
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.runtime.PlatformActivator.start()
org.eclipse.osgi.framework.internal.core.BundleContext.start Activator(BundleContext.java:1071)
org.eclipse.osgi.framework.internal.core.BundleContext.start (BundleContext.java:991)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:403)
at org.eclipse.osgi.framework.internal.core.Bundle.resume(Bundl e.java:386)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1220)
org.eclipse.osgi.framework.internal.core.StartLevelImpl.resu meBundles(StartLevelImpl.java:565)
org.eclipse.osgi.framework.internal.core.StartLevelImpl.incF WSL(StartLevelImpl.java:479)
org.eclipse.osgi.framework.internal.core.StartLevelImpl.doSe tStartLevel(StartLevelImpl.java:269)
org.eclipse.osgi.framework.internal.core.StartLevelImpl.disp atchEvent(StartLevelImpl.java:439)
org.eclipse.osgi.framework.eventmgr.ListenerList.dispatchEve nt(ListenerList.java:135)
org.eclipse.osgi.framework.eventmgr.EventThread$EventThreadI tem.dispatchEvent(EventThread.java:59)
org.eclipse.osgi.framework.eventmgr.EventThread.run(EventThr ead.java:118)
Nested exception:
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/IStatus
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:1647)
at java.lang.Class.getMethod0(Class.java:1893)
at java.lang.Class.getMethod(Class.java:976)
org.eclipse.core.internal.runtime.CompatibilityHelper.getPlu ginDescriptor(CompatibilityHelper.java:41)
at org.eclipse.core.runtime.Plugin.start(Plugin.java:873)
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:55)
org.eclipse.osgi.framework.internal.core.BundleContext$1.run (BundleContext.java:1054)
org.eclipse.osgi.framework.internal.core.BundleContext.start Activator(BundleContext.java:1050)
!ENTRY
reference:file:/u2/buildScripts/result/eclipse/plugins/org.e clipse.update.configurator_3.0.0/
0 0 Feb 14, 2004 01:00:39.890
!STACK 0
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start()
Nested exception:
java.lang.Exception: Can not start
org.eclipse.update.internal.configurator.ConfigurationActiva tor.initialize(ConfigurationActivator.java:86)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:58)
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Feb 14, 2004 01:00:39.998
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.IllegalStateException: Bundle
[3] is not active
org.eclipse.core.runtime.adaptor.EclipseStarter.ensureBundle sActive(EclipseStarter.java:129)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:99)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Re: Eclipse M7, linux gtk , starting problem [message #194327 is a reply to message #194294] Fri, 13 February 2004 18:50 Go to previous messageGo to next message
Originally posted by: newsserver_mails.bodden.de
Could you file a bugreport please?
Eric
Eric Bodden
ICQ UIN: 12656220
Website: http://www.bodden.de
PGP key available
Re: Eclipse M7, linux gtk , starting problem [message #194370 is a reply to message #194327] Fri, 13 February 2004 21:00 Go to previous message
> Cheers,
> Eric
I do
https://bugs.eclipse.org/bugs/show_bug.cgi?id=52035
regards
Previous Topic:Looking for Select folder dialog
Next Topic:Exception in runEventLoop
Current Time: Sun Nov 09 04:11:52 EST 2025
Powered by FUDForum. Page generated in 0.05295 seconds
